Question about Frigidaire FWS833A Top Load Washer
Frigidaire Washing Machine model FWS645 GFT 0 broken bearing in transmission base
    Sergeant:
  • 311 Answers
Bottem bearing on tranie only comes with the traniee.200$ or so
Posted on Jan 02, 2009
Fws645 washing machine how many cubic feet
Around 3.5 cubic feet, give or take a quarter.
Mar 04, 2015 | Washing Machines
How many cubic ft. in a 2001 Frigidaire Galley model #FWT647GHS washing machine
Hello friend, that's a great question!
I understand you would like to know the cubic footage of your Frigidaire washer. Based off the model number you have provided your washer appears to be a 4.4 cubic feet washer. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
Jul 25, 2010 | Amana Washing Machines
Loud clunking sound during the spin cycle, washer is balanced and on 2nd floor
If you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Frigidaire GLTR1670A Front Load Washer
I have a Kenmore model 42182 top loading washing machine which makes a roaring sound during the spin cycle. It works all actions during the wash portion so I don't think it is the transmission. I am asking...
your model should begin with a c110 or just 110. it sounds like you have a mounting stem and bearing problem. this can get alot worse as time goes on and is a somewhat costly repair. it involves taking out the entrie tub and replacing the critical center bearing and seal. you can check for fine particles of rubber at the base of the transmission as it has been ground down from the spining cycle of your machine.
Thanks.
Oct 10, 2009 | Kenmore 42182 Top Load Washer
Frigidaire washer topload, Agitates but the tub spins
yes the problem parts of the transmission if your going to keep it have new transmission installed
Jan 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Washing Machine Model 975FS2
all wsher have bearings which hold the drum centrally if these are worn than the machine will make a noise and get louder on spin and will only get worse sometimes cheaper to replace washer than it is to fix your bearings sorry m8
Aug 11, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FWS833A Top Load Washer Logo
152 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
