Question about Hisonic Audio Players & Recorders
Hi, I have HT-1001 mic, the volume from the mic is low, any possibility increase the volume? do i need to use the external Amp?
I have HT-1001 microphone, when used to communicate for a transmitter application, the received volume is very low, do I need to have a external AMP or any volume control available??
  • samp Oct 26, 2012
    I tried connecting it to an external amp too, but still it sounds low, when it receive it in FM receiver. I am using it for FM transmitter
    Scholar:
  • 87 Answers
The mike can be a mismatch with your CB A booster mike amplifier with a volume control will suffice.
Posted on Nov 27, 2014
5 Suggested Answers
  • 8 Answers
SOURCE: Sony Wireless Mic (Transmitter) UTX-B1
Sounds like some type of manufacturer's flux problem. As an ex-Sony pro dealer we saw something like this years ago. You might want to contact Sony support (industrial or broadcast, not consumer) and see if there is a technical bulletin out on this problem.
Posted on May 26, 2007
SOURCE: Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Posted on Mar 28, 2008
djxtreme979
  • 151 Answers
SOURCE: my microphone sounds muffled
Check wind screen. Make sure output level is not higher than volume level.
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: shure sm58 mic does not have full power
You should consider a microphone with more power to get the volume you need. I can personally recommend the CAD C195 Cardoid Condensor microphone. It has great output. The only downsidefor most people is that they don't have phantom power. This is what gives the mic its boost. In order to get the most out of any micrphone, you need to have a preamp, an equilizer, and an output. The output is your PA system that drumbanger mentioned.
But since you are using a Peavey, here is my strong recommendation. Get a mini preamp, and hook it up to your Peavey. You can use a Behringer 2mic mixing board for your preamp. It's small, and it can sit right on top of the Peavey.
XENYX 1002
http://pro-audio.musiciansfriend.com/product/Behringer-Xenyx-502-Mixer?sku=631262
CAD C195
http://pro-audio.musiciansfriend.com/product/CAD-C195-Cardioid-Electret-Condenser-Microphone?sku=270775
The reason why I suggest the two-mic XENYX 802 and not the 1 channel 502, is that the 1 channel doesn't have phantom power.
In order to connect the XENYX to your Peavey, this is all you need. You can get one at radio shack for pretty cheap.
http://accessories.musiciansfriend.com/product/Mogami-Pure-Patch-RCA-to-14-Mono-HiDefinition-Patch-Cable?sku=339031
Posted on Mar 22, 2009
People can't hear me durring calls. I can hear them.
Three possibilities: you have muted your microphone (sometimes by using an external mic it turns the internal one off), you have turned the mic down to the point where it's so low it isn't picking anything up, or the mic is broken.
Look around under settings and check the mic volume and mute settings. If they are okay then I'd say the mic has gone south.
Mar 06, 2014 | Samsung SCH-U380 Brightside Verizon Phone...
Low volume from Fishman Loudbox Mini mic input, using brand new XLR cable and dynamic mic. Mic works just fine on instrument input using a Hi-Z cable so problem is not mik
I have seen defective XLR cables so check it with an ohmmeter. It is possible the mic input preamp has been damaged. If that is the case, the unit will have to be repaired.
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
Can you please tell me how to increase the volume on my husbands phone as it not very loud thank you
most of the times there are side keys in mobile placed on either side of the mobile by pressing them up and down we can increase the volume. but if a pair of keys is not present on one you are talking about then certainly in setting-----sound settings you can increase the volume of the mobile. but keep in mind some time if a mobile previously working fine suddenly started to transmit low sound there may be a problem in mic as well. try the above mentioned steps and if the problem remains focus on the mic. it may be replaced by some mobile repairer.
Also it may be possible that the output sound of your mobile is low as you listen from your own mobile its volume if increased could also give you good results. thankx
Feb 10, 2011 | Cell Phones
I get the signal but listening very low Listening low noise and the voice is very low
This radio has a mic check. Turn on radio with out mic plugged in when you plug it in the volume should increase.
Possible causes.
  1. Solder or wire in mic cord broken.
  2. Bad switch in mic .....Astatic mics are bad for this
Jan 13, 2011 | Uniden Radio Communications
When im recording,the voice is to low
DEAR SIR,
R U USING LINE IN OR MIC , IF MIC , INCREASE MIC VOLUME FROM VOLUME CONTROL PANEL, & IF U R USING LINE IN INCREASE VOLUME OF LINE IN FROM CONTROL PANEL ..
Jan 05, 2011 | Computers & Internet
President Harry 2 classic does not listen (receive)
Hi and welcome to FixYa,
Initial tests:
  • if there is likewise no TX modulation, check / replace audio IC4 TDA1905;
  • if RX signal strength (S meter reading) is low, check RX + 8VDC;
  • try using an external speaker in case of a faulty internal speaker;
  • exercise the AM/FM switch.
If all of the above checks good, then signal tracing from the front end down to the audio amp. Would the schematics help?
Good luck and thank you for asking FixYa.
Jan 30, 2010 | Radio Communications
Need more mic volume
Plug webcam into USB
Right click on speaker icon in the system tray by the clock.
Select 'Recording devices'
Click on your mic to highlight in blue
Click properties
Click 'Levels' and adjust slider
Click OK
Click 'Playback' tab
Click on Speaker to highlight
Click 'Properties'
Click 'Levels'
Increase speaker level if low
Click OK
Aug 22, 2009 | Microsoft LifeCam VX-1000 Webcam
I have a LG Shine KE970, and the mic is very low
when u make a call ensure the volume is @ max press the increase volume key when u r in a calll or press the right arrow key or move the joystick towards the right to increase the volume
Jul 12, 2009 | Cell Phones
Compaq C773:Internal Mic very low voice,External Mic not detecte
1. click on the start button on the windows screen
2. program, then accessories, then Entertainment, then volume controller
3. select option,then properties
4. select mic check box to activate your mix option in the volume controller then ok
5. you can increase your mike volume and you can put it on mute option etc..
try this, hope this will help you out.
Jun 19, 2009 | Compaq Presario 700 470024-192 Notebook
Increase external speaker volume
when the speaker phone is on, try pushing the up arrow, unless you have the button on the side, But I think it is the up arrow while talking.
Also go into regular menu settings, go to sound settings, speaker volume and headset volumes should both be turned all the way up.
May 30, 2009 | Nokia 2600
294 people viewed this question
Top Hisonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hisonic Audio Player and Recorder Expert? Answer questions, earn points and help others
