Question about Breville SHM2 Twin Hand and Stand Mixer
Breville beater cog stuffed. Breville as much use as a chocolate teapot.
Unbelievably, Breville don't do spare parts for their products. [Quote] Unfortunately, we are unable to obtain the parts required; these products are manufactured in the Far East, therefore whilst we are careful in selecting our suppliers the item in question is beyond our direct control.[/quote] So, if anyone knows of any other makes that use the same sized cogs let me know. Tried Kenwood, they are no good.
Do you have a lid for a Breville FP2A please ?
No This site is not a parts store
contact the manufacturer spares department and order on
Apr 12, 2015 | Food Processors
I can't get the dough attachment off my Kitchenaid stand mixer. I have tried oil, filling up the bowl with soapy water and letting it stand overnight, pouring teapot after teapot of boiling water ove
Hi Georgette
You need to encourage movement between the beater and the silver shaft it locks on to. There is nothing that you can unscrew to make it easier. Get a can of CRC and try & get it around the silver shaft at the top of the beater plus you should be able to get a bit in that side slot where the beater engages with that driving pin. Rock (twist) the beater side to side and slowly the grip will loosen and you will be able to encourage it off. Once you have it off you will need to clean out the CRC and polish up that silver shaft. Next is the more difficult part, you need to polish up that hole in the beater. What you are trying to do is remove the build up of flour in the hole so that it is pretty much shiny in there again without being significantly bigger than it was originally. I use a rat tail (round) file to do this job, you are just removing the darker build up in there. When done a good wash and dry and it will be like new again. Keep the hole clean of flour and it may not happen again.
Nov 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
I need a apart part for kenwood major a 171C. The shaft where the beaters connect to machine is broken cogs etc are fine
This is the only thing I could find in order for you to get parts...This is their phone number in UK..Kenwood Spares Distribution Centre on 0870 241 3653 If I uncover anything else I'll let you know...
Jun 27, 2012 | Kenwood Food Mixers
Breville mixer
A long screw driver for sure and a magnet
on a stick to pull the screws up.
Once the bottom is off the rest is easy.
Take your time, a lot little things to undo
but easy. Enjoy
The Gears
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-0.jpg Remove and fit the bearing caps one at a time to keep the head in
swing position.
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-3.jpg Use needle nose pliers to remove this plug, just wiggle it out.
Don't pull on the cable
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-6.jpg Opps
breville-mixer-5cd23g4f5wgf02ym52jckcyw-5-15.jpg A belt sander works for this.
Apr 03, 2012 | Breville Food Mixers
I was bought it for christmas last year forgot to check it and now find it does not have a manual please can you help
Hi Valerie:
The Instruction Booklet for the Breville SHM2 380 Watts Stand Mixer can be downloaded from the following address:
http://ecx.images-amazon.com/images/I/A1Qx-DxXTMS.pdf
Thank you for using FixYa!
Oct 16, 2011 | Breville SHM2 Stand Mixer
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Where can I get replacement Beater Blades for my Breville SHM2 mixer?
Call Breville or look on their website at http://www.breville.com/. If you are in the US, call 1-866-273-8455 for replacement parts.
May 26, 2011 | Breville SHM2 Stand Mixer
Please can u tell me if i can get the blades for this mixer and how much they will cost.
Yes the blades are available as spare parts for the Mixer. I suggest that you contact any nearby dealer of the Mixer.The price depends on the Quality and there are many makes of blades which is compatible with your mixer.
Mar 27, 2011 | Breville SHM2 Stand Mixer
K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
  1. Next to where the K-Beater attaches in the middle of the circular plate is a lug with a pointed-shape bolt on the end. Remove this with a spanner and the beater plus gear cog can be removed.
  2. Place some mole grips or wide pliers on a worktop and sit the cogged gear in to it and grip so that it won't turn.
  3. Now you should be able to remove the K-Beater!
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
Feb 15, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Breville wizz stick professional doesnt operate.
If you can feel anything when you press the button, unplug it and try to turn the mixer. Once you get it freed up, put a drom of cooking oil where the shaft comes out through the case.
Jan 14, 2009 | Food Mixers
Breville SHM2 Twin Hand and Stand Mixer Logo
87 people viewed this question
Top Breville Food Mixers Experts
jwinter716
Level 1 Expert
Bill Boyd
Tom Chichester
Are you a Breville Food Mixer Expert? Answer questions, earn points and help others
