Question about Whirlpool LER5636P Electric Dryer
Maytag Dryer # 7500
How do I take front of dryer off?
    Problem Solver:
  • 8 Answers
If I'm not mistaken, there are two screws located along the bottom edge of a countour on the front panel, about 4 inches up from the floor. Remove those two screws. Then pull the bottom of the front panel out, away from the dryer, allowing it to "hinge" along the top edge. Once it's pulled out far enough, the top edge will disengage and come off the dryer. Keep in mind there are wires leading to the door switch. So even though the front panel comes off the dryer, it's still connected by those wires.
Hope that helps!
Posted on Jan 09, 2009
I have a 7500 AWQ dryer that I purchased used. It is not heating.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 22, 2011 | Maytag Neptune MDG7500AW Gas Dryer
Maytag LD 7500 dryer squeaks for 20 seconds or so when first started. Then stops and is okay till the next load. Dosen't seem to be the belt.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 09, 2011 | Dryers
Old Maytag LDG 7500 AAL. Where is the correct placement for the fiber and spring washer on the two rear pulleys ?
Hi there the spring washers for the two rear pulleys have been superseded for quite some time now. The current replacement kit contains two fiber washers for each pulley. However, if memory serves me right the spring washer goes on first, then the pulley, followed by the fiber washer and the circlip.
Jul 06, 2011 | Maytag SDG4606A Gas Dryer
Model MDC 7500 AYW control board touch screen not
try an technician as u cant solve it urself
Nov 01, 2009 | Maytag Dryers
How do I access the drum to replace the screws on one of the agitator fins in my Neptune Dryer MD 7500?
four door screws hinges and other side
top botom both side
take off the door
take off the white cowel around the door
you should se two top dogs remove the bolts and the top will lift open
Sep 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Changing dryer belt
pop up the lid and you will notice a short heat element with blue thermastat, you will also notice 2 white wires that goes down to a fuse, that fuse is blown out, it is round on the side of the element housing. you need to get a Maytag fuse kit which will come in the package as a thermastat blue in color and 2 fuses, you will only use one of the fuses, one is for a gas and one is for electric, pink dot for electric, yellow dot for gas.
Sep 15, 2009 | Dryers
Contol panel has gone blank and contol panel is hot on right side
try unpuging for awhile then plug back in if doesnt work need to replace board and panel
Apr 06, 2009 | Maytag Neptune Washer
I have a noisy Maytag LDG 7500 gas dryer.
thats your blower wheel.pop the hood take off the frount the blower is at the bottem.if you are able to turn it and the drum dose not turn thats your problem
Dec 31, 2008 | Maytag PYE2300AY Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
70 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
