Question about Brother CE4000 Computerized Sewing Machine
How do i get my bobbing case to turn - Brother CE4000 Computerized Sewing Machine
  • Brother Master
  • 1,564 Answers
The case doesn't turn. Are you talking about the shuttle not turning? Or the bobbin not turning while seated in the case?
Posted on Nov 06, 2012
How do I get my singer sewing machines bob-in to work properly
Verify that you have threaded the bobbin case correctly.
Be sure you have installed a brand new needle.
Remove the top thread completely from the machine.
ALWAYS RAISE THE PRESSER FOOT and rethread the top from the beginning.
May 07, 2018 | Singer Sewing Machines
How do I replace the bottom bob in on my Easy home sewing machine?
Not familiar with that model, but there may be a small flat door that slides to the side to expose the bottom bob.
Mar 05, 2018 | Sewing Machines
How to fit my bobbing casing?
Use your hand wheel and turn it. Monitor under the throat plate. The part you see moving will eventually show an opening. Stop there and install your bobbin casing. If it has a little metal piece across you will have to lift it slightly. After it is snug you can install the bobbin.
Mar 20, 2015 | Sewing Machines
MY THREAD GETTING WRAPPED AROUND THE BOBBING WHEN TRYING TO SEW THE TOP THREAD WRAPPING AROUND THE BOBBING CASE AND DRAGGING CAUSING THE TOP THREAD TO BREAK ?
It sounds like the lower shuttle is out of place. You should be able to take out the bobbin case and unlatch the shuttle. It will probably be in 2 pieces. Clean out the dust behind it and replace the shuttle pieces. You may have to fiddle with it a little to get them back in place. Then you can test it by manually turning the wheel. Make sure the bobbin is placed into the bobbin case and that the bobbin turns in the direction that you pull the thread.
Good luck.
Nov 11, 2014 | Brother Disney PE-180D Computerized Sewing...
Bobbin case for 7462 singer how do u put in the machine
Open Up The Door Below The sewing Foot. Lift Lever And Then Pull Out the Bobbing Case Replace Bobbing And Put Back Together
Feb 02, 2014 | Singer 7462 Mechanical Sewing Machine
Brother vx1440
Try changing the needle
Try rethreading the machine top and bobbin
Make sure the bobbin is turned the correct way In the bobbin case
It's possible that the machine needs to be checked for a timing problem
Sep 05, 2013 | Sewing Machines
Bobbin won't wind on Sears Kenmore model 1756
You need a bit of oil on you bob winder shaft and then work it in turning your bob winder or your bob winder rubber ring could be worn.
Jan 19, 2010 | Sewing Machines
Thread keeps knotting up in bobbing casing
Make sure the bobbin is wand correctly. It also need tension. you have a bobbin case be sure it inserted correctly.
Aug 08, 2009 | Sewing Machines
Bobbin Case Popping Out
I had the same problem with my singer 20u professional. I tried to find the answer here but no help but I made a call & she said the bobbing might be too big fer the bobbing holder. the bobbing holder is the round metle thing that fits in ure machine. u have to make sure the bobbing ( the thang that holds the thread is the exact same size as the bobbing holder. Hope this helps.
Dec 05, 2008 | Singer 7422
Elna 1600
On a 1600 the bobbing case should not turn. the metal around it should. It should remain stationary.
The part thet turns is called the hook. Is the hook spinning. Is a new needle in the machine? That is where I would start.
Feb 18, 2008 | Elna 2007 Mechanical Sewing Machine
Brother CE4000 Computerized Sewing Machine Logo
57 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
