Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
I HAVE WASHING MACHINE (SAMSUNG HAND WASH-SW70A1 FUULY AUTOMATIC WASHING MACHINE , I HAVE PROBLEM MACHINE CAN NOT RUNNING BECAUSE ERROR 1E IS APPEARE,WHAT IS TROUBLE SHOOTING ABOUT THIS CASE,THANK YOU
Jimster
  • 240 Answers
SOURCE: Kenmore Elite Oasis HE Top Loader washing machine
That would the user interface board (touch panel)behind the dash. Sorry, but not a cheap fix at all. Maybe search Ebay for the part, sometimes you can find it cheaper. Very expensive part and repair. Good Luck to you. Jim
Posted on Sep 08, 2007
SOURCE: washing machine broken, kenmore model 110.92274100
I have the same problem as posted on mar 30, 08. seems like the clutch will not engage, the motor turns but the drum won't spin (wash. move). would you give us follow -up instructions for clutch & gear case on how to replace it.
Posted on Jul 27, 2008
vanni7
  • 163 Answers
SOURCE: Washer making noise during the spin cycle
Hi!!! it looks like your motor coupler is failing..Good luck..
Posted on Jan 04, 2009
jsrock516
  • 5911 Answers
SOURCE: wash cycle stops, F21 error message appears
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Posted on Sep 11, 2009
  • 4 Answers
SOURCE: our washing machine kenmore elite stops spinning
"5d" is actually, "Sd." It means "Suds." If you pop the top on the washer (there should be some tabs along the front were the top joins it. Take a flashlight and check it out. Use a thin screwdriver, pop the tabs, and lift the top up. Once you pop its top, look inside the front panel. There should be a service manual there unless someone has removed it.) Once you get your service manual, you can join the rest of us Kenmore Elite owners in Kenmore Elite H*ll. If this is the Oasis machine, even though you paid a truck load of money for it, it's a piece of junk. The service manual is the most confusing waste of paper I've ever seen. Odds are, you need to replace either the top computer module (they're defective and were recalled) or the RPS. Check eBay for the best prices on these items. If you believe it's your computer module, call Sears--talk nice--and maybe they'll still honor the recall, which has expired. Once you get it fixed, sell it and get something less computerized because the next thing that will go out is your stator. This is the most cheaply built piece of junk washer I have ever owned. Once you look inside it, you'll see what I mean.
Posted on Nov 30, 2009
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
My samsung automatic washing machine wa7584c1 is giving me a 1E error why
You can sometimes solve issue by unplugging unit from wall for ten seconds to reset sensors.
CERACOAT-NANOTECH.com
May 14, 2015 | Samsung Washing Machines
Fix error 1e on Samsung wf875
That's a pressure sensor error. The pressure sensor detects your water level.
If you take the top off of your wash machine, you should see a clear, plastic air tube (like the type used for aquariums) going from your outer tub to a sensor mounted on the top right of the washer (well, I think that's where it is on yours. Your model number isn't anything I have in my records). Remove the air tube from the sensor and blow through the tube to clear any obstructions. Then, put the tube back on the sensor and try to run a wash cycle. If the error code pops up again, change the hose and the sensor. If you still get it, make sure you aren't using too much soap and your drain hose isn't siphoning water from the stand pipe. Because, the next thing you are looking at is a new control board.
Oct 20, 2014 | Samsung WF8704RSW
Error during start for samsung automatic washing machine
E1 = Not filling in allocated time
This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed.
Nov 28, 2012 | Washing Machines
My Samsung fully automatic washing machine Model # WA13G2Q showing 1E error code.What do I do?
My Samsung fully automatic washing machine Model # WA13G2Q showing UE error code.What do I do? THIS IS MY EMAIL engrabih12@hotmail.com
Apr 13, 2011 | Samsung SW62ASP Top Load Washer
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
