Question about Dell Latitude D610 Notebook
Charging problem I have a Dell D610 laptop and it will not take a charge. When I plug in the charger the green light comes on on the power pack but goes off as soon as I plug it into the socket on the computer. I've tried another charger which I know works and the same thing happened. Dell tech support thinks it's a mother board problem but the computer just went out of warranty 20 days ago!
  • dukyana May 11, 2010
    Does the laptop power up at all?
  • JDTec
    JDTec May 11, 2010
    Did he ask you if the power jack on the laptop is loose? You can check by plugging in the power adapter (don't plug it into the wall) into the power connector. Then move and see if it feels loose. If it feels loose, then you may have to solder the connector back onto the system board.
    Let me know.
    Scholar:
  • 155 Answers
It's definitely the motherboard based on the symptoms. You can send it to their out of warranty depot. Or you can purchase the motherboard from their spare parts sales dept, then look for a local tech who can install it for you.
Posted on Jan 02, 2009
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
My daughter has a dell latitude d610 and we can't get it to power on. I Have tried every trick I could find on the internet. This is what we have: green light comes on power supply and stays on, when...
You might want to check the ac adapter port.Plug in charger and wiggle it around,if there is alot of play chances are the connecting pins on the port have broken loose from the circuit board.replace port if necessary.
have you tried a different battery?
Jun 28, 2011 | Dell Latitude D610 Notebook
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
LIGHT COMES ON AC ADAPTER BUT GOES OFF WHEN PLUGGED INTO NOTEBOOK
This is possibly an internal power Supply fault. take the battery out, plug in the adapter, IF the unit works now, you have A: A battery problem, or B: a charging circuit problem. If the unit still fails to work, the power supply in the PC has faulted. You need to get a "Quote: for a repair.
Mar 17, 2010 | Dell Latitude D610 Notebook
Dell D610: Does not charge w/ any a-c adapter/battery pack.
This seems to be a shot in the charging circuit of the motherboard. If in warranty call Dell hardware supoprt and they will do the needful in warranty. If the warranty is out try a local technician and maybe they can repair the board.
Aug 10, 2009 | Dell Latitude D610 Notebook
My Dell latitude d610 charging circuit not working on board
What needs to be done is the jack that your adaptor plugs into has solder points underneath it. All the solder points need to be resoldered to make sure that there are no cracks in the solder that are preventing the jack from charging your battery.
After this is done if the laptop still isn't charging then if you know for sure your using the correct ac adaptor with your laptop then at that point the moterboard would have to be replaced.
Jul 31, 2009 | Dell Latitude D610 Notebook
Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Jun 03, 2009 | Dell Latitude D610 Notebook
My dell lattitude D610 laptop wont charge battery
before you come to that conclusion, try it on AC power only
get back to us if the problem is still the same
regards
Dec 22, 2008 | Dell Latitude D600 Notebook
I have a dell lattitude d610 that it wont turn on at all i already check voltage on the charger it gave me 18 volts and battery is fully charge when i plug it nothing turn on neither lights does this...
Laptops are notorious for having the adapter plug come loose from the motherboard although, most laptops will power off of the battery if this happens (if the battery has a good charge). Some laptops have a DC power board that can burn out. Or in some cases, It can be the power button bar. If you are not comfortable trying to repair it yourself, I suggest taking it to a reputable repair shop but it will probably cost you quite a bit to get it fixed. If you know someone who does this type of repair you might check with them.
Dec 06, 2008 | Dell Latitude D600 Notebook
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Dell Latitude D610 Notebook Logo
178 people viewed this question
Alun Cox
