Question about Lenovo Z580 15. 750gb I7 Win7 Hp64 Mpn
My lenovo z580 laptops is not connecting to wi-fi
I am facing problem with wifi connection. it is not accpecting incoming wifi connection were other laptops are working . there is no problem with my wifi connection it is working properly only
  • Lenovo Master
  • 32,281 Answers
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address
For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Oct 25, 2012
Why isn't my wifi able to connect to any of my net works or any net work for that matter?
There can be several reasons why you are facing issues with wireless connection. To troubleshoot the same, you can refer to the guidelines mentioned on the following link:
http://windows.microsoft.com/en-IN/windows/network-connection-problem-help#network-problems=windows-xp&v1h=win81tab1&v2h=win7tab1&v3h=winvistatab1&v4h=winxptab1
GuruAid.com
May 08, 2015 | Computers & Internet
Improper shut down
try to refix ram,remove ram clean ram and refix it.If its not ok then remove wifi card and switch on laptop with out wifi card.if the laptop is shutting down with out wifi card then clean the lead of wifi card and refix wifi card and if the same problem persist try to update bios with out wifi card and check with wifi card connected back again.If the problem persist replace wifi card.Follow this link to refix ram in that vedio http://www.youtube.com/watch?v=Q1m0SBQu7iU .Follow this link to refix wifi card http://www.youtube.com/watch?v=54VS4bFM-qI
Jan 12, 2014 | Dell Inspiron 15 (N5050)
What is the restore factory setting code of Micromax X250
im not able to dial from my mobile.actually i faced this problem during working with wifi.after connecting it im not able to dial cals.but incoming is there
Feb 27, 2011 | Health & Beauty
I've a Edimax 7284WnA Wireless N150 ADSL/+2 Modem Router. The problem is, whenever I use its wifi functionality with my sony laptop, the connection keeps disconnecting. Please note that the internet...
You are right, if your laptop has no issues except in your home, your laptop is not the problem. You should read the "Communication Failures" section of my tip entitled "Understanding Wireless Networks". You can read it here. You should troubleshoot this starting with the obvious... Are you in Range? Is there a device causing interference (cordless phones, other access points, microwaves)? If there are other WiFi Access Points in your range, verify that they are on a different channel than your router (you can do this with a free WiFi Scanner called "NetStumbler" or "InSSIDer"). If you follow my advice given in the article, and you still have issues, there is a possibility of the router's transmitter/receiver starting to fail.
I hope this helps,
Livingmentor
Feb 03, 2011 | Edimax BR-6216Mg Wireless Router...
We've got the Dlink DES-1008D setup in our office. Since the past 3 weeks, we've been facing disconnection problems. 5 desktop computers, all new and very recent, are connected to this. We've got an...
Ok, the next time when the disconnection occurs. Try the following:
Open command prompt. And try pinging www.google.com, if the ping is successful and you are still unable to access the internet, then you may want to check the proxy settings on your web broswer, or possibly repair/reinstall the browser. You can also try accessing the internet on a different browser.
If you are unable to ping google successfully, then try to ping the IP address of your wifi modem, this is your default gateway. If you are unable to ping this address successfully, then check the cable from the DES-1008D switch to the wifi modem. As a local area connection 'connected' just shows that the link from your PC to switch is fine.
Please try these steps and let me know the results.
Regards..
Apr 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Acer aspire 4736z wifi problem
1.format and reinstall the Windows 7(or) Vista.
2.install the drivers using motherboard disc
Note: some of the acer laptops doesn't work with windows xp with efficient manner like this.
Mar 10, 2010 | Computers & Internet
Dell latitude d520 wifi connection cuts out
Reinstall the wifi drivers and also check if you are facing the same problem the wired connection also..
Thanks
Oct 24, 2009 | Dell Latitude D520 Notebook
Won't connect to WiFi home network, keeps coming up with ünable to connect". My other laptop connects automatically
Go to device manager, network adapters, select your wifi adapter, right click then uninstall it. If you're with Vista, do not delete the drivers. Then when its gone, select action on device manager and scan for hardware changes. It will re install the wifi adapter back. Now try to reconnect back to your router, put in your security key and once connected, save it. When you boot it up again it should connect back automatically again.
Hope this helps.
Oct 02, 2009 | Lenovo IdeaPad S10e Netbook
NOKIA N-73 MADE IN CHINA AFTER INSERTING SIM CARD RESTARTS
plz solve my prob my n 73 accpect any sim if accpect **** give no signal
Apr 24, 2009 | Nokia N73 Cellular Phone
Lenovo Z580 15. 750gb I7 Win7 Hp64 Mpn Logo
456 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
