Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
What replacement lamp/bulb do I need for a Toshiba 51H83
After the television has been on for a little while (a couple of hours) the colors start to get darker and darker on it. I believe that I need a replacement lamp for it but I can't identify the lamp number that I need for the Toshiba 51H83
2 Suggested Answers
milkburp
  • 416 Answers
SOURCE: I have a Toshiba Rear Projection 51H83 & I
On a scale of 1 to 10, 10 being the hardest: 9. This is the heart of the TV. You will need to make several adjustments to the TV once you reassemble the TV, most time consuming will be the convergence adjustments. This can take hours just to learn about. I hope this was helpful, best wishes.
Posted on Apr 22, 2010
50hm66
Some possible reasons include: New lamp is generic and or has a issue----excessive dust or dirt inside the unit on fans etc.
Some of these units had a feature in the menu for quick on where lamp is lit at low level all the time---this shortens the life of the lamp etc
If you did not have this issue before lamp replaced I would suspect a generic cheap bulb may have been used instead of the Toshiba cartridge / lamp combo which costs more.
With the quick on if the set has it normal time is 20 seconds for screen to light----set WILL DETECT IF LAMP IS NOT COMING UP FAST ENOUGH OR BRIGHT ENOUGH.
Generic lamps (cheap) will never be as bright or last a long as a OEM lamp unit.
Just some thoughts based on your question.
Aug 28, 2012 | Toshiba 50HM66 52" Television
Keeps shutting Down
Have to start at the beginning---Lamp? Ballast? Color wheel?
Jun 07, 2012 | Samsung HL-R6167W 61" HDTV
I have a Toshiba 51h83. Everything works fine except there is an issue where the colors are slightly lighter on both the left and right sides of the screen.
this is normal with rear projection tv's its from long usage when the tv isnt always in full screen mode. you can sometimes fix this by replacing the bulb/ or the color board for the projector. also you can replace the screen as it seems like it may also be do to image burn in if it wasnt always in full screen mode. (did this for my uncles Mitsubishi projection tv)
let me know if that helps!
Mar 16, 2011 | Toshiba 51H83 51" Rear Projection...
No video, sound only. Not moved or anything, just picture stopped.
I am not familiar with your TV, but I might be able to help. Sounds like the lamp blew! These lamps only last about 4 to 5 thousand hours. There should be a lamp access on the back of your TV. unplug your TV and remove the lamp housing and inspect the bulb. Be sure not to touch the lens. If it is blown, replace with a new one!
Jan 06, 2011 | Toshiba 51H83 51" Rear Projection...
I have a Toshiba Rear Projection 51H83 & I think the lamp needs to be replaced. I was trying to find the lamp part number & how hard it is to replace.
Apr 22, 2010 | Toshiba 51H83 51" Rear Projection...
Tv goes off after about 5 seconds
Bulb replacement is a good try, I would also have them come out to look at the set again as I am sure there is some kind of warranty on the parts.
Apr 17, 2010 | Toshiba 51H83 51" Rear Projection...
Lamps burned every 6-9 months.
This is indeed a very common problem with the Toshiba products. The reason I asked about the time is that the television bulbs are estimated to last on average 4,000 viewed hours, which you are only coming up short of 50%.
Toshiba is offering an extended warranty free on the product that does cover the bulb replacement.
http://www.tacp.toshiba.com/tacpassets-images/notices/dlplamp.asp
is the link for this extended warranty.
After researching your particular make and model, I have found that the average span for a bulb is indeed 9-12 months. Beyond this extended warrant, Toshiba is offering no further assistance, and will only replace it once. They have also been having issues with the color wheel going out at an average cost of $750.00 which under warranty they will replace one time only.
There is nothing you can do beyond replacing the lamps, however my suggestion would be to replace the television itself, and stay away from Toshiba.
Jan 19, 2009 | Toshiba 46HM95 46" HDTV
Color quality
The lamps may not be the problem; it would be highly unusual for two of them to fail at the same time.
I don't think (unless it is a familiar problem to someone here) that you will find a good answer here.
It sounds more like a house call for a tech.
Sorry -
Jun 18, 2008 | Toshiba 51H83 51" Rear Projection...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
