Question about Garden
Ride on mower will not start off battery.
Fitted new battery. Solaniod tested OK Solanoid only klicks when trying to start off battery. No problem starting, when jump starting off a power pack.
    Problem Solver:
  • 7 Answers
Make sure your terminals and cable ends are clean and tight. check your battery ground cable is tight. they make a wire brush to clean
cables and terminals but you can also use a pocket knife. make the
contact surfaces shiny.
Posted on Oct 25, 2012
  • 153 Answers
SOURCE: Ride on will not start. B&S motor.
Logic would dictate that the starter motor is burning out, drawing far too much current, and that the current overheated the solenoid and toasted it. Now the starter is almost a short circuit and while it spins it has no power. A spendy part to be sure. Perhaps you can find a used one from your friendly neighborhood repair guy.
A compression release is found on old diesel's, but not on gas engines.
Starters can fail from cranking on them for extended periods. They are designed to handle short periods of use, maybe 20 seconds on followed by several minutes (like 15) off. If you have had starting problems and kept cranking to get it going that would explain the fried starter.
Posted on May 14, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
  • 10 Answers
SOURCE: my westwood ride on mower, model 2012 wont start.
Could be a few things, First, you say it's getting fuel, but is the fuel fresh? It may have water in it and act like your engine. Did this problem just start happening? Did you happen to ride over something that may have sheared the key on the flywheel? This would throw the timing off on the engine. If you can try to start it while spraying gas into the carb throat and it keeps running, then it could just be a dirty caburetor or a misadjusted carb float. Good luck, Bill
Posted on Dec 21, 2009
  • 41 Answers
SOURCE: Kubota T1560 ride on mower will not start,
have battery tested and replace if needed
Posted on Apr 14, 2010
daneinwv
  • 124 Answers
SOURCE: John Deer F725 won't start
My name is Dane and I am going to assist you in solving your problem. However, I would ask that you do one check for me before we go to the seat switch procedure. Please find the starter solenoid on your mower. Make sure that the large cables coming from the battery and going to the starter are clean and tight. Make sure that your 1 (possibly 2) wires going from your switch to your solenoid are also clean and secure. Use a volt meter on DC volts, or a test light and check the small lead on the solenoid and make sure that when the parking brake is on and the Deck PTO is off, that you aren't getting 12VDC when the key switch is turned to the start position. If you have a 2-wire system, 1 of them is for ground only. 1 of the 2 wires should get 12VDC. If you get 12VDC at the small terminal of the solenoid, but no power to your starter, the solenoid is bad.
But you are probably correct that you have a problem with the seat safety switch on your lawn mower. The seat safety switch makes sure that if you are ever thrown from your mower, the engine will die.
You should check under the seat of your mower and locate a small square box with normally 2 wires connected to the end of it. While looking at the switch, press down on the back of your seat and make sure your seat is activating the switch. If not, you must get the switch correctly positioned so it makes contact and pushes the button. If you found nothing wrong there, go to the next step.
Make sure the 2 wires are connected and the wiring is in good shape. Disconnect the wires from the switch and make sure there isn't any corrosion on the terminals of the switch or the connector. After you have done this, reconnect the switch and try again to see if the mower will start.
If not, disconnect the switch again and place a jumper wire between the 2 prongs of the connector and tape them so they will not ground out on the frame. Start your mower and see if it operates correctly. If so, you have got a bad seat safety switch and it needs to be replaced. This was only a troubleshooting procedure. You should never operate a mower with this switch disconnected, because you could be seriously injured. Go buy a new switch and replace it. You will need the make, model and serial number of the mower in order to get parts.
There is a small chance that either your clutch/brake safety switch or your PTO safety switch could also be at fault. Normally they won't go bad, but will just get out of posistion so that when you activate the clutch/brake they won
Posted on Dec 11, 2010
2013 v-rod. Fitted a new battery but bike keeps shutting off when engine is hot after a ride of 10km. And if I start the bike its OK for short time
indicates an ignition control/ coil problem that is happening when an internal component is breaking down from heat
take it in to a bike shop that handles your make and have it tested and properly diagnosed
Sep 18, 2016 | Motorcycles
Turn key int lights went out starter relay klicking no sound from starter and int lights will not come back on
  1. Check and ensure battery terminals are clean and tight.
  2. check voltage on battery.Should be between 11 and 3 volts.
  3. try jump starting vehicle and proceed to nearest opne auto parts store so they can test your charging system.
Jan 04, 2016 | Jeep 2012 - Liberty
I charged the battery on my yard machines 12.5 riding mower but when I tried to start it I get nothing. The lights don't even come on in the accesory position
Did you charge the battery while stick conected to the mower? you may have blown the fuse that comes of the solanoid that will cut all power off usually founf under steering compartment
Dec 17, 2010 | Yard Man Yardman Riding Lawn Mower 38in...
Hi, I have a Stihl/Viking MT412 ride on mower
Your safety switch may be dead but it is not extinct as a dodo!The switch is only an on off switch, not much can go wrong with it.Try the fuse. You can find the fuse on the wiring loom next to the solenoid.
Oct 30, 2010 | Garden
There is power to Lights ect but when u press the starter button there nothing Honda ntv600
3 things spring to mind
1, the starter can jam- this can be checked by taking jump leads and battery or a starter pack connect the neutral lead to the body of the starter and touch the live to the main terminal on the motor it should spin the engine over makesure you are not in gear
2, starter solanoid- again an easy check there are 2 large terminals on the top, bridgeing these with a heavy duty screwdriver ( it will spark when arked) will by pass the solaniod spinning the motor there is also an indipendant fuse on the side of it. If this works unplug the conector then you need to touch both of the expodes spades with a 12 volt supply this will involve useing two screwdriver blades ensure you get the terminals correct by checking the live terminal.
3, now is the difficult bit, if both of the first parts allow the motor to spin over it is a wiring fault the most likly fault is the starter button they can burn out unfortunatly if this is the case you will have to ether rebuild the switch involving making new brass contacts or replace the entire switch unit much easier but more expensive, again if the switch is ok you are now into checking plugs for damage and corrosion als check each cable for conductivity with a multimeter.
NB if the starter works on direct contact but not on the bridging of the solanoid chech the master earth and live terminals on the battery and the earth terminal to frame.
Oct 11, 2010 | Honda NT700V Deauville Motorcycles
Engine starting problem
The battery still may be bad. The fact that it "warmed slightly when being charged" doesn't suggest it to be good - instead it could have high internal resistance in one or more cells. A battery with this failure still measures a good 12V until you put a load on it. I'd take the battery to a battery store, not a lawnmower dealer, and have it tested there with an actual battery tester. If it's bad, replace it. If it's good, then it's probably the solenoid and that means you'll have to replace the starter/solenoid assembly.
Jul 05, 2010 | Garden
Husky ride on mower will not start.
Sounds more like a safety switch problem, first verify the seat switch then the mower switcher and make sure it's not in reverse.
Sep 04, 2009 | Garden
Remote start (posibly)
Your battery is almost certainly flat.
When you start the engine, the starter motor takes a large bite of power out of the battery. It takes a long time to put that power back.
So, you tried to start with remote start and it did'nt fire up. This took a big bite.
Then you started manually. This took another big bite.
The engine started though, and the alternator began the mamoth task of putting two start attempts worth of power back into the battery.
After 5 minuites, you interupted the alternator and switched off.
Now the battery will be really ill!
You really need to get a jump start from a vehicle with a battery which is about as big as yours.
Connect the leads from the good battery to yours, making sure that the donor vehicle is running. Then walk away and have a coffee. Come back and try your truck again. It should start ok.
If your battery has done this even once, can it be trusted again? If its more than 3 years old, get a new one fitted.
Hope this helps!
M3ODQ
Jan 31, 2009 | Directed Electronics 1100f Ford Pats...
Wd63 washer dryer when complete when i open the door alot of hot steam comes out
your water supply to the machine has been turned off, or the triplewater valve has gone open circuit on the condensor solaniod if you have a multimeter you can test the valves unplug the machine from the mains and turn the cold water supply off , take the back panel off take 2 wires off at a time and test each solanoid they should read around 3800 ohms if you nget no reading on 1 of the solaniods thats you problem change the complete valve. good luck
Jul 14, 2007 | Hotpoint Aquarius WD63 Front Load...
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
