Question about Hayward H-series Electronic Gas Pool Heater H400
Hayward h series h 250 Ed 2
Water leaking
3 Suggested Answers
john224
  • 1378 Answers
SOURCE: My hayward sand filter pro
Thank you for posting your question here on Fixya.com.
You need to replace the gasket inside the valve to stop the leak. The gasket kit is pretty cheap and not too hard to replace. We can try to get you the part number if you can post the valve brand and model. You should be able to call any local pool store with the brand of filter and get the part you need without any trouble.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Jul 09, 2011
  • 368 Answers
SOURCE: I have a Hayward RS
If you bring it to Leslies they should be able to fix it. If not, then shame on them. At least where we live they charge only for the parts and they install the parts for no additional charge. Try to go when they are not very busy so they can fix it while you wait. I hope this helps.
Posted on Aug 24, 2011
Hayward h series heater+water flow sensor leaking
either take out and reinstall with teflon tape or replace with new using teflon tape on threads
Jul 19, 2014 | Hayward Pool & Spa
Hayward 220T pool filter is leaking water; could it be the multi-port valve needs to be replaced?
if coming out of top where handle is yes if out backwash line yes make sure unions are tight also
Dec 30, 2013 | Hayward SAND FILTER, PRO SERIES
Drain leak
The spider gasket in the valve needs to be replaced. It is underneath the handle assembly.
Aug 26, 2013 | Hayward SAND FILTER, PRO SERIES
My wife left the pool cleaner out of the water and the pump ran for 8 hrs without any water now it leaks
Well, that would be a starting point. It is possible that the over heating of the unit caused some warping but that would take some investigating.
Sep 20, 2012 | Water Pik Flow Valve Assy. Series II...
I have a Hayward RS Replacement Pump 3/4 HP that works, but it has a small water leak from the middle of the case. Can I fix this with a o-ring or gasket? If so where can I get it? This is Leslies...
Aug 05, 2011 | HAYWARD GASKET HOUSING
I have water leaking from under my hayward pool filter...any suggestions?
Try consulting the the owners manual for these pool filters. They have a pretty good trouble shooting guide and it should be able to help you correct your problem.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 29, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward Model H250IDL is leaking water from drain valve.
Water leaking from the heater is not a good sign. This is an indication of a leaking heat exhanger. The heat exchanger will have to be replaced and the part is made of copper. It is very expensive, depending on the age, you may just want to replace the entire heater. Exchangers usually leak due to bad water chemistry.
May 09, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward 250 heater won't fire up
Check the control circuit, specifically the pressure switch, for continuity with an ohm meter....any reading over 2 ohms needs to be investigated
Jun 27, 2009 | Hayward H Series Millivolt 250,000 Btu...
No power
Ed,
I have this same problem. Did you ever solve it?
Jun 24, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward H-series Electronic Gas Pool Heater H400 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
