Question about Danby DDW2406 Stainless Steel Built-in Dishwasher
Error 004 dishwasher ddw2406bls, tried emptying overflow not fixed yet
5 Suggested Answers
SOURCE: error message 004
i have a euroart ds9000 dishwasher and after much frustration with the flashing 004 error i discovered the best way to fix it was to pull the dishwasher from the hole and lean it to the right and all the water drains onto the floor a messy solution i know. But after holding it on the angle whilst it was turned on as the water drained out the beeping stopped i then stood it back level turned it on and off and it was fixed . hope this helps. dishwasher crusader
Posted on Aug 05, 2007
  • 415 Answers
SOURCE: Error Code: 004
shut off power to the unit first or unplug it after 1 min turn back on this may solve the problem
Posted on Aug 19, 2009
Error code 004 is caused by water being present in the bottom tray of the machine. There is not supposed to be any water there but if there is any the float switch is triggered. Get rid of the water source and the problem is fixed. On my machine the leak was in the feed pipe to the upper dish tray. I replaced the feed pipe and problem solved. Water could be leaking somewhere else however so you will have to find and fix the leak.
Posted on Dec 30, 2009
SOURCE: heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Posted on Mar 11, 2010
Need to reset, can't get it off the error code for overflow
sounds more like the waste hose is blocked or the pump has packed in. If the machine cannot empty the water this will always appear.
Feb 24, 2013 | Dishwashers
Beaumark bm-dw9702-ss dishwasher error code 004??
I had a error 004 on a Beaumark Model: BM-DW9702-WH Dishwasher which caused it not to run. The Manual stated it was To MUCH INLET WATER. I replaced the Inlet Valve with Part#: DW-53. The Dishwasher now runs great!
Oct 28, 2010 | Dishwashers
I have an LSv66 Ariston dishwasher. When it is switched on, no matter what program, the knob just stays in the same position. It sounds as if the dump pump is running constantly.
The dishwasher overflow detection may have triggered. This causes the drain pump to operate.
The overflow float is located at the base of the diswasher and maybe faulty. It is spring loaded float and should move down and up when pressed. If you cannot find this in your model, then water has leaked into the overflow cavity where the motors are located. This could also trigger the overflow protection circuit.
You have to replace the overflow float if it exists or empty the overflow water in the overflow cavity and dry it out. If leak is taking place then the gasket needs replacement.
Hope you are able to fix the problem with some of the suggestions I have made.
Please rate the solution if you find it helpful otherwise post a comment.
Oct 11, 2010 | Ariston Technologies LL64WNA Built-in...
Baumatic WQP12-9213 - Error Code 004?
hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Washing Machines
Heller dishwasher error 004
Cheers....Aldo
Sep 20, 2009 | Dishwashers
Error Code: 004
Aug 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My Danby DDW2406BLS dishwasher have the water level is too low and the upper sprayer don't turn with the water pressure. whose the problem, my water inlet is good
check grease trap [plastic] and strainer on pump with m/c off.you have to take off side and front panels to do this.disconnect electrical power first.!
Jul 21, 2009 | Dishwashers
Danby ddw2406
Simple solution. DO NOT spend the money on a tech coming to the house.
This error code comes from getting too much water in your machine, either from a dish filled with water emptying, or perhaps a clog from the sink that prevents your machine from draining. It is meant to prevent overflows from too much water being in the tub. It is a simple fix though!
First of all you should at least shut the power off on your machine. For the effort of a couple of more steps, it wouldn't hurt to shut the breaker off at the fuse panel. You will have to unscrew the undercounter tabs that mount the dishwasher to the countertop. They are located just under the counter sticking out from the top of the dishwasher when the door is open. Then proceed to pull out the dishwasher from under the counter. You will only have to pull it out about half way and you will find the overflow valve. It is located on the right side of the dishwasher just under the insulation and level with the lower hinge on the door. (Right side when you are looking at the machine.)
There are two overflow valves. One looks like a small cup, the other looks like a cylinder with a float in it like your toilet. Both of them have black rubber covers near the bottom. Take these covers off and about a quarter cup of water will flow out of these overflow basins. Allow them to completely empty, then replace the rubber drain covers and then replace the unit under the counter.
Once you turn the power on, the error code should be cleared and you are ready to use the dishwasher again.
Jun 03, 2007 | Danby DDW2406 Stainless Steel Built-in...
Error message 004
Simple fix for me
Simply look at right side of machine get a flash light pull the insulation away from machine stick the light in look for the white little resovoir and the styrofoam float switch.
syphon the 1/2 cup collection this allows the float in the attached
cup to drop kicking the sensor out....
I dont suggest disconnection the sensor as im sure it will come back to haunt you. =)
worked for me takes 5 minutes
enjoy
Nov 12, 2006 | Danby DDW1805W Designer Series...
Error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Jun 27, 2006 | Indesit 24 in. DE73 Evolution...
Danby DDW2406 Stainless Steel Built-in Dishwasher Logo
85 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
