Question about NaceCare TTQ 1535 4 Gal - 15" Cylindrical Scrubber with Grit Brushes
Instruction for ttq 1535s scrubber - NaceCare TTQ 1535 4 Gal - 15" Cylindrical Scrubber with Grit Brushes
I HAVE A DIRT DEVIL SPOT SCRUBBER & HAVE NO USER MANUAL & NEVER USED BEFORE. CAN NOT FIND INSTRUCTIONS ONLINE. CAN ANYONE PLEASE TELL ME HOW TO FILL THIS MACHINE & USE PROPERLY? THANKS!
Hi ramond745...
Go to the following webpage and view the operating instructions for your Dirt Devil Spot Scrubber, you can also print the page/s on your printer for later reference.
Please take time to rate me
http://www.ehow.com/how_7830177_operating-dirt-devil-spot-scrubber.html
Aug 16, 2011 | Vacuums
Is there a simple way to explain how to delete unwanted portions of a video clip?
well depending on the software you are using,might be able to highlight a section of the scrubber bar by pressing the space bar and with the mouse drag the scrubber head across till selecting a portion of the scrubber bar, then you can just hit delete.
I use a number of different video editing software so if you tell me which one you are using I can get you specific instructions.
Mar 22, 2010 | CyberLink Computers & Internet
Help!!
Look up instruction manual at
http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=325fa4dd-0a38-48aa-b0b0-516143a0875a
Aug 23, 2008 | Dirt Devil SE2800 Spot Scrubber Handheld...
Uninstall Problem
If you are installing the software using Windows and the software was not successfully installed or the uninstaller could not be found, run the Scrubber Utility to perform a clean driver uninstallation Use the Scrubber Utility Use the following steps to run the Scrubber Utility.
  1. Disconnect the printer from the computer.
  2. Restart the computer.
  3. Insert the Starter CD into the CD drive. If the CD menu displays, close the CD menu.
  4. Locate the Utils\Scrubber folder on the Starter CD.
    • For Windows 98 and Windows Me, use the scrub9x.exe file located in the Utils\Scrubber\Win9x_Me folder.
    • For Windows 2000 and later, use the scrub2k.exe file located in the Utils\Scrubber\Win2k_XP folder.
  5. Double-click the file to run the Scrubber Utility.
  6. The following message will display: This utility will attempt to remove all HP DeskJet 460 Series devices from your system. It is recommended that you disconnect the device and restart before continuing. Do you want to continue without rebooting?
  7. Click Yes . A message stating Successfully removed the devices(s)! This system is ready for installation displays after the scrubber utility finishes running.
  8. Click OK .
  9. Restart your computer, and then reinstall the printer software
Apr 27, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Nilfisk advance floor scrubber vacuum problem
CAN YOU HELP? I AM LOOKING FOR A SMALL FLOOR POLISHER AND SCRUBBER FOR MY OWN USE AT HOME. i SHOULD HAV TWO 5_6" SCRUBBER PADS AND FLOOR POLISHING PADS. THANK YOU AND GOD BLEES. NORSANRAIDERS@MSN.COM LOWTON , OK
Mar 12, 2008 | Vacuums
Need owner manual
Depending on the revision date of your scrubber, here are the manual(s) you seek located on this page: http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=5457 Good Luck
Jun 17, 2007 | Dirt Devil SE2800 Spot Scrubber Handheld...
NaceCare TTQ 1535 4 Gal - 15" Cylindrical Scrubber with Grit Brushes Logo
32 people viewed this question
Top NaceCare Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a NaceCare Tool and Hardware - Other Expert? Answer questions, earn points and help others
