Question about Acer Aspire One AO532h2DGbk 101 LED Netbook Atom 450 166 GHz 1024 x 600 WSVGA Display 1 GB RA
Use synthetic division to solve for x^3-9x^2-18900=0
  • Jose Diaz
    Jose Diaz Oct 25, 2012
    What? GL with that.
  • joecoolvette
    joecoolvette Oct 25, 2012
    Have a product support problem with a laptop, Jane?
How to do Order Of Operations and algebraic expressions with division and multiplication and subtraction and addition for 6th grade ONLY
here you go.
Grade 6 Math Circles Algebra Order of Operations (BEDMAS) - CEMC
www.cemc.uwaterloo.ca/events/mathcircles/2013-14/Fall/Junior6_Oct8.pdfGrade 6 Math Circles ... Suppose you are asked to evaluate an expression that looks something like this ... When an expression contains many operations, we must be careful of what order we do ... sion and multiplication, and finally addition and subtraction. ... According to BEDMAS, division is a higher priority than addition. How to do Order Of Operations and algebraic expressions with division and...
Apr 24, 2017 | Office Equipment & Supplies
Tip
Share hidden division of rapid delete
Several ways of rapid delete hidden division
We install the system, may encounter this problem computer can install Vista or install version of Windows xp, a Ghost installation of xp not contain is constantly to restart. The cause of the fault is that a series of PinPaiJi cabin hidden division. Sometimes the technical personnel to help us system, also can be in a hard disk, and you will see division, also not afraid you miss delete their recovery operation convenience. How to delete the hidden division, I collected many operation method, are as follows:
1, delete the ordinary hidden recovery
Disk management, drawing on disk partition in hidden division, right click delete disk partition ".
2 the notebook, delete Lenovo 42T3403 Laptop Keyboard LEOS
The new generation of LENOVO laptop, called "using a key LEOS" hard to restore technical data backup, restore, this function is integrated in the BIOS by a program and WINGDOWS one under the interface of software interaction, namely on disk to establish a division of division, the implication of the backup, (which is also usually say the disk C), in order to destroy a key file system, ordinary operation of the C can modify the area before 5G) to (approximately delete it, actually not difficult, first appeared in LENOVO reboot your computer, interface into the corner by the keyboard "resume/custom" button will appear a key recovery of concise interface, here only two options, one is the system restore, another is the software and drive, then click "order", and the Shift + B input password "LENOVO" will appear a key recovery in the interface standard interface, select uninstall backup. If the above methods cannot be solved, can use to start running under the Dos, CD LEOS management software. LEOSTOOL/DB, typing, then turn backup LEOSTOOL/DLEOS "type" can put lenovo backup system deleted.
3 and delete IBM Thinkpad G41 Laptop Keyboard HPA's
Currently the notebook HPA mostly by Phoenix First EareRecover - established in software, software component to delete, for a series of notebook, ThinkPad Recovery of Recovery CD directory is the component -- Fwdelete, want to delete HPA, must First in the BIOS setting, enter the BIOS ThinkPad notebook, select "Security -- Predesktop Area" will "Access" to "PredesktopArea IBM Disable". Then use CD to DOS, in Fwdelete input "DOS interface DRV = 0all" and enter, can be deleted, HPA stubborn zoning after you can use all the hard disk space.
4, delete the notebook HPA associations
Some of the Dell Inspiron 1501 Laptop Keyboard notebook to associate the hidden division by lenovo Hddfunc tools HPATool/unloading unloading, Hddfunc use simpler, with CD to DOS mode, and then run in the DOS commands "Hddfunc/d" can be hidden disk backups unloading, for Hddfunc not delete HPA zoning, need to use HPATool, under HPATool type "in the DOS CLR", can/could have removed the module record.
on Aug 09, 2010 | Computers & Internet
Draw a flowchart that accepts two number and checks if the first is divisible by the second
I think the big question here is how do you determine in the first number is divisible by the second number. With a calculator, try various combinations of number to see when the first number is divisible by the second number and when it is not divisible. How are the results different from when they are divisible from when they are not divisible?
Good luck,
Paul
Nov 17, 2015 | Office Equipment & Supplies
Is 450 divisible by 3 in fractions
450=9*5*10=9*50
9*50/3=3*50=150
To verify if a number is divisible by 3, add the digits in the number. If the sum of digits is divisible by 3, then thumber is also divisible by 3.
Sum of digits in 450 =4+5+0 =9, divisible by 3, so 450 is also divisible by 3.
Jul 06, 2014 | Office Equipment & Supplies
How do i factor numbers on a ti-30xs calculator
This calculator does not have a key that you can use to find the prime factor of an integer.
You can however use the calculator to find the factors
1. If number is even divide it by 2
Keep dividing by 2, while keeping track of how many times you divided by 2.
If you divided 5 times by 2 before getting an odd number, then your first factor is 2^5
2. Now try dividing by 3, keep track of the number of times you divided by 3 before you could not divide by 3 any more. If you divided 0 times by 3, your second factor is 3^0, or 1 and 3 is not a factor.
If you divided 4 times by 3, your second factor is 3^4
3. Divide by 5, until you can't any more. Keep track of the number of times you divided by 5.
4. Divide by all other prime numbers 7, 11, 13, 17, 19, 23, 29, 31, 37, 41, etc. For each prime number, keep track of how many times you divided by it, until you could not any more.
Example: 23100
Division by 2
23100/2=11550 ---------> 1 division by 2
11550/2=5775 ----------> 2 divisions by 2
Note that 5775 is not divisible by 2. No more divisions by 2.
First factor is 2^2
Division by 3:
5775/3=1925 ----------> 1 division by 3
1925/3=641. 66667 Not an integer. No more divisions by 3.
2nd factor is 3^1
Division by 5 (number ends in 5)
1925/5 =385 -------> 1 division by 5
385/5=77 ----------> 2 divisions by 5 and no more (quotient does not end in 0 or 5)
3rd factor is 5^2
Division by 7
77/7=11 --------> 1 division by 7, and no more
4th factor is 7^1=7
Division by 11
11/11=1
5th factor is 11^1=11
Assembling the factors 2^2, 3^1, 5^2, 7, 11
Prime factorization of 23100 is
23100=(2^2)(3)(5^2)(7)11
Dec 18, 2013 | Texas Instruments TI-30XA Calculator
240/20x6-13+41 can't figure out the answer
You'll need to use the Order of Operations to solve this problem. They are Parenthesis, Exponents, Multiplication, Division, Addition, Subtraction (Please Excuse My Dear Aunt Sally). Multiplication/Division have the same weight, so you read it from left to right. Same with Addition/subtraction.
For this problem, you see there are no parenthesis or exponents, so you move right to multiplication/division. Reading from left to right, the first thing you see is 240/20. Evaluating that comes out to 12. Now you have 12*6 (assuming the x is a multiplication symbol), which evaluates to 72. 72-13=59, and 59+41=100.
Written another way:
240/20*6-13+41
12*6-13+41
72-13+41
59+41
100
Aug 29, 2011 | Computers & Internet
List 7 consecutive numbers none of which is prime?
114 divisible by 2
115 divisible by 5
116 divisible by 2
117 divisible by 3
118 divisible by 2
119 divisible by 7
120 divisible by 2
Aug 15, 2011 | Computers & Internet
I am a three-digit number. I am less than 200. I am divisible by 12, and by 9. My units digit is less than my tens digit.
One way to solve this is:
Start at 108, which is the first 3 digit number divisible by both 12 and 9.
Then continue adding twelve until you find a number which matches all your criteria.
You will find the answer to be 180.
180 / 12 = 15
180 / 9 = 20
0 < 8
Nov 13, 2009 | The Learning Company Achieve! Math &...
How to do fractions.
A fraction is just division of the numerator by the denominator.  So all you have to do is enter the division symbol in place of the fraction bar.  If you are trying to enter a mixed fraction: for example 3 3/5 enter: (3+3/5) were the / is the division button or your calculator.
Sep 03, 2008 | Texas Instruments TI-83 Plus Calculator
Acer Aspire One AO532h2DGbk 101 LED Netbook Atom 450 166 GHz 1024 x 600 WSVGA Display 1 GB RA Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
