GE Profile Spectra JGBP90 Gas Kitchen Range
Problem for GE Profile Spectra JGBP90 Gas Kitchen Range
Digital Control (for oven temp and clock adjustment) not working
By puzzled1 on May 12, 2007
My problem with GE Spectra XL44 gas range/oven is that
I cannot raise the temperature setting to higer than 350 degrees.
The digital control for raising ("+" button) numerical settings doesn't seem to be working, either for clock adjustment or for raising temp setting.
When I press "BAKE" button to use the oven, I see the temp setting at 350 degrees.
As I press "+" button to raise the temp setting to say 400 degrees, The "+" button simply does not cooperate and I cannot raise the temp setting.
I have no problem lowing the temp setting by pressing "-" button, though.
In short, the "+" button seems to be DEAD!!
Comments:
May 17, 2007
- After "SF" apeared, I pressed broil pad, expecting to see C or F. However, I saw no response (No C or F).
Again afer "SF", I pressed "+", and saw no response (this was no big surprise, for I have never seen any reaction from pussing "+" since the problem was discovered). I pressed "-" and saw numbers go down to 4, to 3, 2, and finally to 1 (Now I cannot go back up; kind of stuck at 1). As to the cables, everything looked very clean. I removed 5 or 6 pin connector and plugged it back in. I saw no obvious ribbon cable that I might be albe to clean. No change in problem status ("+" seems dead)...
May 17, 2007
- BINGO!!!
Good News!
I think I have the unresponsive "+" pad problem resolved. I figured that I had little to lose in applying some physical force(bump) to "+" pad.
So I touched "+" pad with permament marker, and
gave a little punch to the end of the marker with the heel of my palm. And Voila!
The numbers started going up !!!
Thank you Mr. Catriver for all your attempt at helping me, and finally inspiring me to punch the key!!
Best Solution
posted on May 12, 2007
Helpful)
catriver
Rank: Guru  GE Expert
Rating: 94%, 3179 votes
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Was this helpful?
Yes
No
Popular Solutions for GE Profile Spectra JGBP90 Gas
Questions and Unsolved Problems for GE Profile Spectra JGBP90 Gas
Do you recommend GE Profile Spectra JGBP90 Gas Kitchen Range?
Answer
Answer
Stove gas turns on and off when preheating. Takes forever to heat oven to desired temp. What do... (More)
Answer
my ge profile gas locked door is blimking after I perform a self clean for the 1st time and I tried... (More)
Answer
I just did a cleaning cycle and the door will not open, oven is still hot...the lock seems jammed
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile Spectra JGBP90 Gas...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
