Question about Brother IntelliFax-2820 Laser Fax
What we can do for brother fax-2820 " DRUM ERROR"
  • twister8th
    twister8th Oct 31, 2012
    i have change new drum and new toner but still apper the DRUM ERROR.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 31 Answers
Open front cover with the machine on and press the options key.message will appear replace drum unit then select 1 for new.close cover
Posted on Oct 26, 2012
Testimonial: "Thanks a lot. The solution is works. My machine now is working back. "
    New Friend:
  • 25 Answers
Hi, I had the same problem with this machine. After going through the manual (you can find it here - Brother IntelliFax 2820 manual), I figured that I need to open the front cover, press the 'options' button and select 1. That did it for me, I hope it will work for you as well ;)
Posted on Nov 20, 2013
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
iservice
  • 318 Answers
SOURCE: can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Posted on Sep 15, 2009
  • 148 Answers
SOURCE: Replaced drum fax 2820
Hi, #'s 6, 7 and 8 below explain how to reset the drum indicator.
Hope that helps...
Lbcoaster
How do I replace the drum unit?
Description:
Follow the procedure below to replace drum unit.
CautionDo NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
spray1.gif Caution
    Just after you have used the machine, some internal parts of the machine are extremely HOT! Never touch the shaded parts shown in the illustration.
  1. Open the front cover and pull out the drum unit and toner cartridge assembly.
Caution
    To prevent damage to the printer from static electricity, do not touch the electrodes shown below.
  1. Hold down the lock lever on the left and pull the toner cartridge out of the drum unit.
Note
    • Discard the used drum unit according to local regulations, keeping it separate from domestic waste. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. If you have questions, call your local waste disposal office.
    • Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the plastic bag.
  1. Unpack the new drum unit.
  1. Reinstall the toner cartridge into the new drum unit. If you put it in properly, the lock lever will lift automatically.
all-ug-16.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Install the drum unit and toner cartridge assembly in the machine.
  1. Press Options.
  1. To confirm you are installing a new drum, press 1.
  1. When the LCD shows Accepted, close the front cover.
Related Models FAX-2820, FAX-2910, FAX-2920, MFC-7220, MFC-7225N
Posted on Aug 02, 2008
PORRATEC
  • 25 Answers
SOURCE: FAX SAYS TO CHANGE THE DRUM SOON
Open the front couver as if you are about to change the drum unit. With the couver still open, press the options button for a while and in the display will apear a message asking if you want to change the drum unit. Choise the yes option and close the front couver. GOOD LUCK.
Posted on Nov 13, 2008
SOURCE: need drivers for Brother fax 2820
Need drivers for Brother fax 2820
Posted on May 03, 2009
IntelliFax-2820 Plain Paper Laser Fax: We have a Brother intellifax 2820 and it's aking t...
You need to take out the cartridge and slide the tab on the top right from right to left about 20 times
May 16, 2010 | Brother IntelliFax-2820 Laser Fax
HOW DO YOU TURN OFF DRUM LIGHT ON BROTHER 2820
Open front cover....press 'options', and select 'new drum'
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Dust on the drum carona wire loated on the drum
hey vinny, check out solution #1 on post above labeled "DRUM ERROR". and try that procedure.
good luck,
razors
Mar 30, 2009 | Brother IntelliFax-2820 Laser Fax
Brother 2820 fax machine
THE DRUM AND THE TONER CARTRIDGE IS IN SIDE OF THE MACHINE.OPEN THE COVER AND YOU WILL SEE THE DRUM CARTRIDGE,TTAKE OUT THE DRUM UNIT. ITTELLS YOU ON THE DRUM UNIT THE NUMBER DR    IT IS SOLD IN OFFICE DEPOT OR OFFICE MAX OR STAPLES, MAKE SURE THAT YOU ONLY USE BROTHER PRODUCTS. GOOD LUCK BROTHER SR TECH
Feb 02, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Error message won't go away.
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
May 16, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820
The toner cartridge is in the drum unit. push the blue lever and the toner pops out, make sure you have a toner cartridge in the drum unit. Lawrence
Apr 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax 2820
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
Jul 18, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
1,060 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
