Question about Maytag Dryers
I have a maytag heavy duty commercial quality / oversize capacity plus / auto dry control / quiet plus / drum light / 12 cycle dryer that does not heat up. what could my problem b.
The dryer does not heat up nor does it shut off. it will run forever.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: there is a knock in the dryer but not constantly
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Apr 28, 2010
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Fix rinse cycle
That sounds like a failed mechanical timer. Replacing that should solve your problem.
Dec 13, 2014 | Frigidaire Washing Machines
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
I have a Maytag Heavy Duty /supersize capacity/Quiet Series 100/ 10 cycle dryer. It is not so Quiet when it is turned on, It has a very loud squeak for about 5-10 min. Then it quits and does not have A...
my daughter had same problem. maytag used to be build to last but no more. the dryer tub sits on the front lip around the door opening the support breaks and then the tub has no support and ride around rubbing on opening lip squeeking and causes a lot of friction and will either break the belt or a plastic piece on the motor. it broke all the above on my daughters dryer. we just junked it good luck
Sep 10, 2012 | Dryers
There is a knock in the dryer but not constantly
heatman101
Apr 26, 2010 | Dryers
Dryer doesn't work.
Dry will not start, light is off. Power is on and working fine to dryer - is there a reset button?
Performa oversized Capacity Plus Model #PYE3360AYW .
Jan 18, 2009 | Maytag MAV3905EWW 13 Cycle Washer
Dryers Logo
122 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
