Question about Acer Aspire 9410 Notebook
Trouble starting the pc
Every time I restart my computer I get this message.
Acer edata security management
file access error - the file may be accessed by another program. Please refer to online help for further assistance.
that is when it actually boots up. When it doesn't I just get a blue screen and I have to manually shut the computer off and try again.
Can somebody PLEASE help me with this!!
  • bmckenzie40 Jan 02, 2009
    I don't get an error message. When I restart it just hangs at the beginning and I have to power it down and try again
  • Dan rogers
    Dan rogers May 11, 2010
    what is the error code on the blue screen?
The eData security management of my acer aspire 5315 has got removed while formatting the system. My encrypted files have thus become inaccessible. What do I do to be able to access them again? Also I am...
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Aug 07, 2010 | Acer Aspire 5315 Notebook
How to reinstall the acer edata security data management.
To reboot the system click on Start and then on the shutdown menu choose restart or shutdown.
If this error happens with a bluescreen and white writing then you will have to press the power button for about 5 seconds to force it to shutdown.
To reinstall the eData software use the Acer software CD that came with your computer to reinstall it or download it from Acer :
http://support.acer-euro.com/drivers/notebook/as_5520.html
Select it from the Empowering Technology and Utilities section.
Good Luck
Jun 16, 2009 | Acer Aspire 5520-5908 Notebook
Pop-up acer edata security management each time open laptop
I would go to the program file itself (it might be on the desktop, might be in the start menu, or might be in a folder in C:\Program Files) open up the acer e-manager and look for an option for settings.  You should be able to un-select options for security notifications and automatic updates.  I do not have the program on this computer, but I have seen it before on other laptops.  Most all programs like that will let you change the settings.  The security updates are not entirely necessary, so long as you have an anti-virus program installed on your computer.  So just turn off the auto-updates and the notifications through the program itself.
Mar 26, 2009 | Acer Aspire One PC Notebook
I have an Acer 5100. Freq. I have an error message. Reinstall
the eData security mangement is for security such as parental controls.u must have deleted it ,or possibly corrupeted the file you can find the neccesary downloads at acer pan am america,,steve
Feb 10, 2009 | Acer Aspire 5050-3242 Notebook
When I restart my computer I get Acer edata Security Management system error - file access error - the file may be accessed by another program. Please refer to online help for further assistance. That is...
have you considered using the e recovery,and put it back to factory condition? make sure you save all the files you don't wish to be erased, saved if you can. you may have a bad driver or hardware-software issue,or a system restore may help, if the problem just seemed to come out of nowhere. hope this is helpful.
Jan 02, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer eData Security
Most of the time this means there is a problem with the filesystem or possibly bad sectors on the hard drive. If you are running windows 2000, XP, or Vista, follow these steps:
Click on Start, go to Run, type in "cmd". In the command prompt, type "chkdsk C: /r /f"
That will tell chkdsk (Check Disk) to fix the filesystem and locate/repair any bad sectors. It won't be able to run while you are using the computer, so it will ask to run on the next startup. Be sure to say yes, then restart the computer and let chkdsk run.
As for why it happens on system startup is a little more bothersome. Unless you are trying to delete something, I would suggest getting and running Spybot Search & Destroy and if you don't have any antivirus, AVG Free (http://free.grisoft.com). Both are free and quite effective.
Oct 18, 2008 | Acer Aspire 3690-2196 Notebook
Acer eData Security Management
Well, reinstall eData Security Management.
Aug 04, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Everytime I open certain docs. I get told that "eDataSecurity was not properly installed! Please re-install the software" I then click Ok and the it says Windows explorer has stopped working.
It's becoming an anoyence considering I can't use my windows2007 anymore :(
Is there anything I can do to re-install eDataSecurity,so I can live out happy days with my computer and not decide to throw it out my window??
Jul 02, 2008 | Acer Aspire 5050-3242 Notebook
Trying to restore my system
Just use original OS and repair OS
Dec 07, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 9410 Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
