Question about Goodman CLQ36AR49 Air Conditioner
How to test capacitor
I was reading that to use a Audible Ohmeter to a Capacitor on a fan motor. I have a regular Ohmeter can I use it and how?
    Sergeant:
  • 311 Answers
Watch out for those caps.you use the ohms setting ,may have to go to higher setting in ohms,but take your probes place on cap terms.the cap will read closed for a few seconds then go open,then reverse the probes and do again same result.if only open then may be bad,if your meters reading fine.i have only ever used a regular meter in all the years gone by.God bless,tom
Posted on Jan 02, 2009
AC CAPACITOR 50+6uf,ac fan not runing...Is capacitor not working and required to change ?
Hello, it is possible that the capacitor is bad and must be changed. You can test it by using a ohmeter, if the numbers on the meter ramp up and down then the cap is good, if not then it must be replaced.
May 08, 2012 | LG LW7000R Air Conditioner
Uaka 024JAZ condensing unit comes on, fan and compressor start up, fan remains on, compressor shuts off in appx 1 min , pressures appear to be headed to normal op range. I did not see a run cap for this...
This unit uses a dual run capacitor. There is no start capacitor involved.
The dual run capacitor is possible weak, also check all the electrical connections for tight fitting connections with can cause motor/compressor overheating.
To test a capacitor properly you need the proper test meter capable of reading uf readings(within 6% of the stated rating on the capacitor) "C" common to "F" fan and "C" to "Herm" terminal, the higher rating for compressor and the lower for the outdoor fan. [(example= 25/3uf 370v) 25uf=compressor, 3uf=fan motor.]
Oct 01, 2011 | Ruud UBHC Air Conditioner
Ducane Furnace; AC condenser runs but blower fan in furnace won't turn on
The blower motor could be bad or the motor run capacitor may be bad. If you have the proper tools you can test the run capacitor yourself and replace it.
***CAUTION*** Anytimeyou are working on or around electricity you run the risk of shock and ordeath. Please consider consulting an expert before you open an electrical panelor appliance. ***CAUTION*** Capacitorshold a large electrical charge and will discharge upon contact with your skin.This is enough to stop your heart and cause death. If you are not confident ofyour abilities around these devices then please leave any testing or repairs toa professional. The capacitor is inside the unitand you have to remove the cover to see the inside of the electrical compartment.You will need to discharge the capacitor before you start working around it. Todo this take a screwdriver or other long metal tool with an insulated handleand cross both terminals on the capacitor to ground. You then remove both wiresgoing to the capacitor terminals, which on fan motors are typically brownwires. Capacitors are rated in MicroFarads (marked by a µF symbol) and have a voltage rating as well which istypically 370 volts or 440 volts. Youmust have a multimeter that can read micro farads to check a capacitor. You do that by placing one probeon the one terminal and the other probe on the other terminal and it shouldread the number of the rating, for example if your capacitor is rated likethis: 7.5µF then the fan rating should read 7.5µF (seven and a half MicroFarads). If the reading is more than 6% lower than it is supposed to be, thecapacitor is weak and needs replaced. If you read 0 (zero) then the capacitoris bad and needs replaced. Take the old one with your to match up at your localhvac supplier. A typical motor run capacitorrated at 5 µF +-6% at 370 Volts ACshamoke_0.jpg
Jun 18, 2011 | Heating & Cooling
Hayward pump hums a few seconds before it starts..what can I do to fix the problem..it has been doing this for a while and it seems to take a longer time to start now.
It is very likely the start capacitor, or start windings. (If it's the windings it's pretty much shot.) If the motor has been running hot the windings could be going bad, if not it is most likely the capacitor. It is possible that the bearings, or something clogged in the impeller could be affecting it but not likely. (just something to keep in mind). The capacitor is fairly easy to test if you have an analog meter, and easy to replace as well. Without knowing the exact motor model. I can't give exact directions. Before I give you more details, you may want to just take the motor down to a pump repair shop they should test it for free. If you want to tackle it yourself, then continue on. You may have start, and or run capacitors. The capacitor(s) is either under the big metal hump protruding from the side of the motor, or in the tail end with the wiring. (or both) Either way it looks like a black or silver canister. At this point you should obviously have removed power to the motor. If you remove or check the capacitor remove the wires carefully and discharge the capacitor by shorting the two leads. To check the capacitor you need a special capacitance meter or an analog ohm meter. Some capacitor testers give a reading, some just an audible tone. To check with a meter it has to be an analog meter. Set the reading for ohms, and set for the lowest setting, maybe 1 ohm, or 10 ohms. When you connect across the terminals you should see the needle flick upwards then slowly drop. This is only a generic reading but gives you an indication the the capacitor is functioning. If the needle doesn't move, then it's probably open (bad) or if the needle moves all the way up and stays, then it's bad (shorted out) if you get a reading needle flicks and drops, you'll need to short the leads to test again. Replacing the start cap is cheap ($10-$20) compared to a new motor. You can usually find a replacement cap at Grainger, a pool pump repair shop, or sometimes at a local pool supply retailer. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 12, 2010 | Hayward Pool Products Hayward Power Flo LX...
When I turn on the pump the motor hums for about 30 sec. then stops. Cleaned out pump basket and put my hand in, did not feel anything clogging it. When I put my hand inside I can turn the impeller...
Most likely either bad start capacitor, or start windings. If it's the windings it's pretty much shot. The capacitor is either under the big metal hump protruding from the side of the motor, or in the tail end with the wiring. Either way it looks like a black or silver canister. If you remove or check the capacitor remove the wires carefully and discharge the capacitor by shorting the two leads. To check the capacitor you need a special capacitance meter or an analog ohm meter. Some capacitor testers give a reading, some just an audible tone. To check with a meter it has to be an analog meter. Set the reading for ohms, and set for the lowest setting, maybe 1 ohm, or 10 ohms. When you connect across the terminals you should see the needle flick upwards then slowly drop. This is only a generic reading but gives you an indication the the capacitor is functioning. If the needle doesn't move, then it's probably open (bad) or if the needle moves all the way up and stays, then it's bad (shorted out) if you get a reading needle flicks and drops, you'll need to short the leads to test again. Replacing the start cap is cheap ($10-$20) compared to a new motor. You can usually find a replacement cap at Grainger, a pool pump repair shop, or sometimes at a local pool supply retailer.
You can check the motor windings by using an ohm meter, but you must remove the power first. That means you need to physically disconnect the wires, not just turn of power. If your not familiar with this best to have a shop test it. Motors can have multiple sets of windings for different voltages, and start vs run.
Sep 18, 2010 | Pentair Pinnacle 1 1/2 - Hp In Ground Pool...
FAN TURNS ON FINE BUT COMPRRESSOR DOESNT CLICK ON. HOW DO I FIND AND REPAIR THE PROBLEM?`
The problem could be the capacitor for the compressor motor or the compressor motor. Use a multimeter with the capacitor test function to check it or take the capacitor to a heating and air supply and they can check it for you. If the capacitor looks swollen then it is bad. If the capacitor is good then use an ohmmeter to check the compressor motor windings. Connect one lead to common then the other lead to Run then Start, reading the meter when you connect the lead. The capacitor is a common failure.
Sep 05, 2010 | Hampton Bay HBLG5004 Air Conditioner
Fan stopped. Turned on and spun blade but nothing, on any of the three settings. Bad capacitor? how do I test switch or motor windings with voltmeter? Thank you, Torrey
you can check the switch or motor by using an ohmeter for continuity test. connect the probes on each switch starting from common to no 1, 2, and so on. if the motor is okay, the capacitor is defective.
Sep 08, 2009 | Vornado Air Circulator - Black
Trane XE1200 Fan Motor
Most likely problem with a not-so-old motor is the run capacitor for the fan.
Some units have fan & compressor capacitor combined into one -- others are separate.
The capacitor can be tested with a multi-meter with an MFD setting -- it should read reasonably close to the specs marked on the capacitor.
Charlie
Aug 19, 2009 | Heating & Cooling
Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heil airconditioner is not cooling? Heater works
If no blowing air is coming out to your ac or evaporator fin,your blowing fan is not working.There are several factor to check qualified electrician or ac techician should do this.If you have knowledge on electricity and motor control,beside you should have clamp ammeter to use in trouble shooting of ac electrical circuit.Unplug your ac If there is an opening of blower fan of your ac mostly the top cover open this one locate the wire connection of blowing fan take the color and size.Open the terminal box below the control panel of ac and locate the wire of blowing fan.Check how many leads make sure to make sketch where it was connected from low,medium, and high there is coded color on it,discannect from the terminal, using clamp ammeter set to ohms probe setting R10 check continuinity of winding motor start at common lines(mostly balck color) of one test rod and the other to starting line(mostly red color)take and read the resistance if has a higher resistance your motor is burn out, also with the running line w/c has multple line for speed.If resistance complied to your motor rating or good,If not or burn out replace fun motor.Check your capacitor,doing this set your ohmeter to a higher resistance,connect one red test rod (+) one terminal of capacitor and one black test rod on (-)the other terminal the pointer will deflect steady to higher resistance then reverse the connection of the test rod,the pointer deflect again to higest resistance it will go slow backward setting to zero if you got this result your capacitor is good.But if it does not go set back to zero your capacitor is short.Replaced capaciter.
Mar 10, 2009 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
281 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
