Question about Microwave Ovens
Grill not working on defy dmo 336 microwave oven, microwave oven works fine, convection oven works but grill element does not work.
  • 883 Answers
SOURCE: Oster Microwave/Convection/Grill
first, get your money back or get a replacement for no charge. now, unplug the oven for 15 minutes and try again. if no-go, then some device is faulty that only a tech can find
Posted on May 28, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
WhIzAtIt
  • 136 Answers
SOURCE: Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Posted on Sep 24, 2008
ginko
  • 19396 Answers
SOURCE: microwave not working but oven and grill do
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on May 21, 2009
najah
  • 180 Answers
SOURCE: sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
Posted on May 30, 2009
My panasonic NN-8500 microwave/convection oven the microwave part is working fine but,the convection grill defrost is not
Possibly the defrost heater element has failed. You will need to strip the cabinet off and use a multimeter to test the element. May also be the overtemp safety thermostat may have failed.
Nov 19, 2016 | Panasonic Microwave Ovens
Microwave trips and switches off within 2 seconds
We regret reading about your microwave. At this time we recommend you have the unit evaluated by an authorized service center.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-S254BF Microwave Oven
Panasonic microwave grill not working
I would call customer service with the model number to see if this is a known issue. You might also call a authorized Panasonic repair center and chat with them to get some idea of what a possible repair might cost.
Dec 04, 2012 | Microwave Ovens
Microwave working but grill and convection not working? any help will be a great help. thank you.
It is most probable that the element has failed stopping the heating process.
I would call an engineer to replace the element.
Mar 19, 2011 | Microwave Ovens
Smeg fmc24x oven and grill work turntable and microwave dont
I have a simular model and I found that the circuit board has three black relays, one for the grill one for the convection and one for the microwave. I found that the microwave one wasnt working so by swaping the microwave one with the convection one I got it to work and then replaced the faulty one with a new one at a later date.
Dec 03, 2008 | Microwave Ovens
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
