Question about Mustek Computers & Internet
Problem with Mustek UPS 636
From the time I attached the Mustek UPS 636 on my computer, it is hapening that computer is sometimes starts working without that I start computer. I checked and there is no any scheduled task in UPS software. What can I do to prevent that kind of computer start?
Thanks and sorry on my bad english.
Greatings
4 Suggested Answers
SOURCE: Mge nova avr 1250 problem
ups charged for 8 hrs .No alarms but on powerfail no output to connected device
Posted on Jun 20, 2009
SOURCE: Problem with Compaq UPS T1000h
I had a problem like this one, check the voltage from the generator , if the output from the generator is to high (over 240 Volts european standard voltage), the voltage protection (VDR resistors ) will brake the fuse to protect your UPS.
and also check the frequency of the generator, it has to be very stabile around 50HZ (european standard frequency)
Posted on Sep 20, 2009
tech240
  • 169 Answers
SOURCE: Problem with APC Pro 420
If the unit works ok on mains power, then it is the usually the batteries causing this, New battery i think you need.
Testimonial: "Thank you very much for your answer"
Bypass the max backup time.
ther is no program to multiply battery capasity.if you conect another identical batery in paralel you might get dubble the time. but some peaple sai that this methot is dangerus for transformator .but you can conect some fans to cool it douwn.
Jan 01, 2012 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
Hello. I have a Mustek PowerMust USB 800 device. Few times a day (2-3 times) it shuts down my computer. It appears the red light instantly and it starts to make a sound. Even after i press the button and...
Did you read the manual for your UPS ?
I read it - there was something about lamp ledding - different ledding of lamps and different frequncy of noisy sound can mean different problems - try read manual.
I think, your description means that you need to change battery.
Battery work 2years +- .
Jul 05, 2011 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
Need upsmon software for windows 7
Go to this link: http://www.nodevice.com/driver/company/Mustek/UPS.html
It lists a few model numbers for Mustek UPS system, select the model that is the same as yours and follow the download instructions.
Rate me high if you found this helpful.
Thanks.
Nov 01, 2010 | Mustek Computers & Internet
I have changed the backup battery, i have charged it for about 22 hours, but when i turn off the electrical supply, it goes off! ( the ups) MUSTEK POWERMUST 800
Remove batts, Check battery connector, fuse and batt volts, if you have dummy load (car headlight etc) check batts are working and measure voltage under load.
Also check if UPS needs to be told there are new batts read manual or check support for maker.
Let me know what you find, hope this helps
Thanks for using FixYa
Jul 30, 2010 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
Hi!i can't find the serial number of my Mustek powermust 800 and I need to install the monitoring system of this ups thanks
The serial number locating in the one of manual pages.
Looking in there.
If you bought you device not on black market - you must have those manual.
Jul 12, 2010 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
Ups doesn't work properly.my bateery is down.isn't working.
All UPS batteries go bad over time. It's time to replace yours.
Oct 25, 2009 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
My mustek powermust 600 usb is not working
Hi! Have you found the schematics ? I have the same problem.
Jul 09, 2009 | Mustek (MUSTEKUPS600) UPS System
Powermust 600 USB 5 minutes shuting down problem
Load is the problem. Too low load on UPS will cause that on almost all Musteks.
Dec 12, 2008 | Mustek UPS 600 (POWERMUST600USB) UPS...
Computers & Internet Logo
99 people viewed this question
Top Mustek Computers & Internet Experts
David Payne
David Payne
Are you a Mustek Computer and Internet Expert? Answer questions, earn points and help others
