Question about Sony Playstation 3 (PS3) Console
Picture/sound cut out
This is a 4 day old t.v. and has had very little use in those 4 days (damn work) i also have an 80 gig PS3 hooked up to it via HDMI . when i play games or dvds after a few min of playback the picture and sound cut out some times returning a few sec later. now at first i figured it was just the PS3 and it could very well be, but the controller still responds to what is going on in the game (ie.the rumbling when i get hit in game) i have tested the HDMI cable and its not that and i've checked all the connections and everything was solid please help so i know what to box up and take back:)
My old 40 gig ps3 died, so we bought an 80 gig, but when 40 gig hdd is inserted in place of 80 gig hdd, it wont accept the hdd, and i had 9 months worth of saved games on 40 gig hdd. how do i get game...
Unfortunetly the HDD's can't be swapped like that. The only way to get the old stuff is to some how get the 40gb working so you can back up your system. Tell me what happend to the 40 and I might be able to help you get it up long enough to back it up so you can get all your stuff transfered. Another way is if you can get the 40gb machine to work the PS3 has a mode to hook a CAT5 cable from the new to the old and transfer that way.
A little more on the HDD swap. The HDD's are machine spacific and can only be recognized by the machine they were in and any other PS3 you try to put them in won't recognize the device without a format will saddly enough wipe the drive clean.
Let me know what's wrong with the 40 and I will see if I can help getting it back up so you can get your saved stuff off of it.
Sep 25, 2011 | Sony PlayStation® 3 (80GB) Console
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
Ps3 80 gig pixalated on hd screen beond reading.
That is usually a problem with the motherboard graphics chip. You would need a motherboard gpu reflow. To check this, connect a non dhmi cable to see if the same problem occurs,
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
Our playstation 3 won't read games but will play regular DVD's and CD's
I have the same problem. My games freeze after 5 minutes. Same with blue rays but dvds play fine. I have reformatted the hard drive and formatted the file system. Nothing has worked. Hearing through multiple sources the blue ray laser is going out or the latest firmware update could be causing this. Hard to know for sure ... major disappoint. I have the 80 gig. 2 years old just starting doing this three days ago. Any other suggestions?
Dec 26, 2009 | Sony Playstation 3 (PS3) Console
My samsung LN37B550k1fxza, Has Sound But no picture! day old!
While it is playing, sound that is, try holding a flash light right up next to the sceen, preferably in a dark room, and see if you have any picture. You really have to focus on it and watch closely. If you can see any picture, you probably have a bad inverter. The inverter lights the back lights in the panel to illuminate the picture. The flash light basically does the same thing from the front. The inverter is the board on the far right with several of the same kind of wires disapearing down the side. Thanks. Let me know what you find.
Nov 11, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
My ps3 wont play ps2 games. it is an 80 gig
well it needs to be backwards compatible mine is an 80gig and it has 4 portholes for usb if your only has 2 portholes (btw thats where u plug in wired controllers) then its a regular and not backwards compatible i no it sucks that happened to me and i just sold mine and bought a backwards compatible one. if u just got it in a matter of days you can go to wheere you bought it and ask them to exchange it for a backwards compatible one BUT THATS ONLY IN A MATTER OF A FEW DAYS
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
Went from HMDI to standard cables=no picture and no sound
reset your settings on the ps3 on your old tv using the same set up then go to the new tv and it will come on. I had the same prob
Apr 27, 2009 | Sony Playstation 3 (PS3) Console
PS3 is not reading discs
There is a common problem with the Blue-Ray players in the PS3. There is not anything that i know of that you can do other than have your PS3 worked on
**Warning** If you have the old 80 or 60 gig ps3 that you are able to play PS2 games on and you are trying to go through sony for repair they may just give you a new 80 gig ps3 in which you will not be able to play PS2 games on any more that feature has been taken away
Dec 03, 2008 | Sony Playstation 3 (PS3) Console
Disc read error
Hey, i bought a ps3 almost 2 years ago now, its been more reliable for me than my old ps2. i would try and phone them again if you aint recieved the case soon,
it does sometimes take a while for them to repair it and send it back ie if its the same console, they might just swap it for another ie once u get it sent away :-).
sounds like a problem with the laser, im sure you will see the case soon, and touch wood have no problems with the replacement ps3.
Jul 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
