Question about Air Tools & Compressors
Can i connect the co2 tank directly to my air rifle using a pressure hose so i can avoid the leaking of co2? My rifle is philippine made ricardo valiente pcp rifle.
2 Suggested Answers
SOURCE: Was working normal suddenly will not build pressure
Maurader1 an apprentice has this problem solved and is spot on. All these gurus and wiz need to stick to the basic and common sense. The first place your pump will give out after use or abuse is the gasket. All this garbage about defective reeds and defective pressure switch is a lot of nonesense if you first don't rule out the most common problem the head gasket. I'm cheap and this thing has paid for itself 10 time over. You can get a gasket kit for $7, but I fabricated a gasket out of the back of my notebook and sprayed some gasket spray and been working like a charm ever since.
Posted on Jan 04, 2010
How to fix the leak on my c02 .22 air rifle
There is a tiny spanner nut over the tiny "O" ring seal for the CO2 cartridge. You must find a tool to remove that, it is pinned in there and it will likely break when you try to remove it, if so sorry but the gun is then just so much junk.
Aug 19, 2016 | The Optics
Where can i purchase the threaded part that goes into the gun and punctures the co2 this is my second request
Direct, eBay possibly or direct from Daisy.
  • Daisy Outdoor Products - Official Site www.daisy.com CO2; Optics; Accessories; Collectibles; Info. ... Winchester Air Rifles ' Where to Buy ... © 2013 Daisy® Outdoor Products ...
  • daisy bb gun parts ' eBay www.ebay.ca > Search > daisy bb gun parts Find great deals on eBay for daisy bb gun parts and daisy ... Vintage Daisy Powerline Model 44 Co2 Innertube Nut BB Gun ... New listing DAISY AIR RIFLES AND BB GUNS ...
  • Air Gun Replacement Parts - AirGun Warehouse www.airgunwarehouseinc.com/repa.html Air Guns. Air Rifles; Air Pistols; BB Guns; ... Whether you are looking for Daisy BB gun parts or you ... we carry a wide range of air gun replacement parts that let ...
  • Apr 01, 2016 | Daisy BB Gun Pistol CO2 BB Gun Repeater...
    I used a dozen or so air tanks and now when i screw the tank down ---- i loss the air. what is the problem?
    The rubber O ring needs to be replaced. You might have a plastic one though. Still needs to be replaced.
    Feb 27, 2015 | Crosman Optics
    I have a daisy powerline 990 air rifle, I need to know how to repair this gun. It will no longer pump up air or hold pressure.
    You might have a bad O ring. I keep hearing a leak out of 990 and i think its from the coldness of the Co2. Every time i put Co2 in it it gets worse.
    Apr 23, 2011 | Daisy Toys
    Air leaks out when installing co2
    The Phantom Break-Barrel does not use CO2. It is a spring-loaded break-barrel weapon. If you really do have a CO2 gun, check the rubber seal around the outside of the cartridge puncture needle.
    Feb 18, 2011 | Crosman Phantom .177 Caliber Break Barrel...
    98 Custom Act Paintball Gun: i have just brought a 98 tippmann custom and it ha...
    Basically speaking, air is air. Now it's the pressure that's the concern. co2 bottles use a regular valve that has a pin in it and opens to allow the gas through. High Pressure Air - HPA is the same concept but since the pressure with co2 is built up by expanding gas, HPA has to do it with pressure only. So the tank is pressurized a LOT higher than co2, but there's a regulator on the tank valve to bring the working pressure into the marker to the proper level.
    So yes, you can use "air", but you need to make sure it has the right output for your marker. (i.e. not a low pressure HPA valve.).
    You'll have the same problem though, getting someone to fill the bottle. Check with your local airsmith and paintball fields and stores. If they have co2 they would have HPA, but some do only deal with HPA since it's "easier" in some cases.
    You may have to check around. Sometimes hardware stores have a small section in back, or you can check with the paintball places around to see if anyone in your area is equipped. Some teams have their own tanks, especially if there's not a place to get fills locally.
    There's also online communities like Brigade and various paintball sites where you can check around for other players. Someone may have a co2 fill tank, a scuba tank for HPA, or a group that gets tanks together to make a run and get them filled somewhere.
    Play hard, play safe, play with honor!
    8^)
    May 18, 2010 | Tippmann 98 Custom Act Paintball Gun
    After inserting and compressing the CO2 cartridge, the CO2 leaks
    You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
    Jul 12, 2009 | Crosman Phantom .177 Caliber Break Barrel...
    Co2 leaks from chamber on crossman modle400 rifle how do i fix it
    Check thare is a rubber o ring missing or broken in the air chamber
    Mar 29, 2009 | Crosman Phantom .177 Caliber Break Barrel...
    Beer dispenser
    Shut of the CO2 tank, then hit the pressure release valve on the side of the beer tap. Make sure there is a grey check valve in the tap where the red hose (co2) is connected. Also make sure the white ball in the tap where the white hose (beer line) is not stuck. You can remove this, it isnt really necessary. Once all checks out, open the tank and readjust the co2 regulator. The reading should not be more than 12 PSI. Everything should work just fine after this. Make sure the glass is as close to the faucet as possible (slanted is better) when dispensing beer. Hope this help :)
    Jan 21, 2008 | Haier (HBF05EAVS) Beverage Dispenser
    Put together
    1 Chrome Rail (for attachment to Worktop)
    4 Self-Tapping Screws (to attach chrome rail)
    1 CO2 Cylinder Support Stand
    1 CO2 Cylinder (empty)
    1 CO2 Regulator (high/low pressure gauges)
    1 CO2 Air Line Hose (red)
    2 CO2 Air Line Hose Connectors (black)
    1 Beer Keg Coupler
    1 Beer Tower Unit (complete with faucet, hose and wing nut)
    1 Rubber Washer (to be installed inside wing nut)
    1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
    4 Machine Screws (to attach bayonet to beer tower)
    1 Gasket (beer tower base)
    1 Pull Handle (beer tower faucet)
    1 Beer Keg Stand (required for 30 liter keg installations only)
    1 Protective Plate (refrigerator cabinet floor)
    2 Cantilever Wire Shelves (conversion to all refrigerator application)
    1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
    1 CO2 Air Line Hose Plug (located exterior rear cabinet)
    1 Plastic Drip Tray (2 piece)
    1. Remove Worktop: Using a Phillips Screwdriver, remove the
    three screws located on the front underside edge of the
    worktop and the three screws located at the rear (back)
    side of the worktop.
    See Fig's. 1 & 2
    Remove the worktop from the cabinet and position the
    worktop on top of the cabinet so that the front corners
    are staggered across the front corners of the cabinet.
    2. Installation of Top Rail: Attach the chrome rail to the work
    top using four self-tapping screws from the underside of the
    worktop through the pre-drilled holes. (attach the front ends
    of the rail first)
    3. Re-Install Wo r k t o p : Install the front of the worktop onto the
    cabinet, then lower the rear side of the worktop over the
    backside of the cabinet. Secure using the same screws
    removed earlier. (the smaller screws at the front the larger
    screws at the rear)
    4. Installation of CO2 Cylinder Support: Install the cylinder
    support onto the four studs located on the exterior back
    wall of the cabinet. (no tools required) Align the holes in
    the cylinder support with the studs and push down firmly.
    See Fig. 3
    5.
    Installation of CO2 Cylinder: Install your " fully charged"
    CO2 cylinder into the support stand. IMPORTANT NOTICE:
    ALWAYS EXERCISE EXTREME CAUTION WHEN
    HANDLING PRESSURIZED C02 CYLINDERS:
    6. Installation of C02 Regulator:
    Attach the CO2 Regulator to
    the C02 cylinder by screwing the regulator nut onto cylinder
    valve and tighten (snug) using an adjustable wrench.
    7. Installation of C02 Air Line Hose to Regulator: Attach one
    end of the (red) air line hose to the hose barb connection
    on the CO2 regulator. Secure hose by using one of the two
    (self locking) black plastic snap on clamps provided.
    (use pliers to snap the clamp tight to assure that there are
    no leaks)
    See Fig. 5
    Fig. 1
    Fig. 2
    Fig. 3
    Fig. 4
    Fig. 5
    CHI
    See Fig's. 1 & 2
    of the rail first)
    screws at the rear)
    See Fig. 3
    5. Installation of CO2 Cylinder: Install your " fully charged"
    6. Installation of C02 Regulator: Attach the CO2 Regulator to
    no leaks)
    See Fig. 5
    Fig. 1
    Fig. 2
    Fig. 3
    Fig. 4
    Fig. 5
    LL'N TAP ACCESSORIES (included with this unit)
    Jan 07, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
    Air Tools & Compressors Logo
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
