Question about Homelite Garden
Looking for a gas and a chain bar oil cap #'s 70701-a and 70702-a for a homelite xl 104564
Gas/oil cap and bar oil cap
  • 35 Answers
SOURCE: Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: Homelite XL 101, what are cc's?
cc stands for cubic centermeters..It is a measurement of the chamber that the piston resides in when totally expacted
Posted on May 10, 2009
  • 583 Answers
SOURCE: Homelite Textron chain saw UT 10403A ...need
25to 1 and .025 thou
Posted on Aug 06, 2009
  • 597 Answers
SOURCE: old homelite XL chainsaw pumping bar oil into engine while runnin
Check that the oiler hole and the hole in the bar that it pumps into aren't clogged. The sawdust running under the chain and be deposited in the oiler hole in the bar until it plugs it solid. That will keep the oil from havintg a place to go and build up pressure.
Posted on Sep 23, 2009
dontbother10
  • 2220 Answers
SOURCE: automatic oiler on homelite super xl ao does not
Please see the clarification. Lou
Posted on Oct 05, 2009
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
https://www.youtube.com/watch?v=PnNTJ3xI_wo
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
HOW TO REPAIR CHAINSAW OILER - YouTube
? 6:38
https://www.youtube.com/watch?v=kmUkieIP-vw
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
Where can i get a replacement bar oil cap for a homelite xl chainsaw
http://www.ereplacementparts.com/homelite-chain-saw-parts-c-18807_21362.html?gclid=Cj0KEQjwpM2pBRChsZCzm_CU0t4BEiQAxDVFmuNsj0j4bpQsjOchGGvSh6DD6vZJIlALn6tjvNPauLIaAnUS8P8HAQ
Apr 19, 2015 | Homelite Garden
I need a parts diagram of the homelite xl 12 with a ut number of 104564 serial number 790291696.
There seems to be 1 to many numbers in the model # UT104654 is it possible that it reads UT10465A.
If so here is a link to the parts diagram for a Homelite XL12 UT10465A ,
http://www.jackssmallengines.com/help.cfm#/Homelite/XL12_Chain_Saw_UT-10456-A/Engine_Internals/1010129/0609011010046
Aug 06, 2011 | Homelite Garden
Does a homelite chain saw have a crank case youn put oil in homelite xl
Hi, it needs a two cycle mix at a ratio of 25 to 1 in the fuel tank and bar and chain oil in the oil tank. Hope this helps, regards Phil.
May 31, 2011 | Homelite Garden
I have a HOMELITE XL-12 chain saw. Web sites say it takes a mix of oil and gas. But mine has a place to put oil in. Which should I do?.
The mix of oil and gas should be a 32:1 ratio which is 4 oz. of oil to every gallon of gas. I am assuming that what you are seeing is the oil tank for the bar oil. You need to use bar and chain oil for this tank as it is what keeps the chain lubricated. Do not use two cycle oil for the tank marked oil.
Apr 15, 2011 | Homelite Garden
Gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
I have a Homelite Super XL chain saw model 100454. Gas leaking around cap when turned on side to cut. Cork gasket look fine and surface is flat where cap in screwed on. Any help?
Just because that cork gasket "looks fine" does not mean it is working properly. Replace it with a polypropylene (oil and gas resistant rubber) gasket. That will clear up your fuel leak problem.
Dec 15, 2009 | Garden
Garden Logo
54 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
