Question about Maytag Legacy MAV208DAWW Top Load Washer
How to remove maytag agitator on mav408daww - Maytag Legacy MAV208DAWW Top Load Washer
4 Suggested Answers
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
Posted on Jan 13, 2009
  • 2696 Answers
SOURCE: REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Posted on Nov 03, 2009
Testimonial: "Super fast and accurate info. Thanks so very much."
SOURCE: maytag washer will not agitate during wash cycle
http://appliancejunk.com/forums/index.php?topic=2946.0
Above is a service manual this will show you how to troubleshoot and repair.
Posted on May 04, 2010
How do u replace drum bearings on a may tag washer model # mav408daww
If you have to ask, you probably won't do it. It involves dismantling the machine, removing the drum from the tub and drawing the bearings off the spindle. Refitting the bearings is easier but you still have to put the machine back together. Get a quote from an engineer and if it's less than half the cost of a new machine it may be worthwhile. If it's more than half the price of a new machine get a new one.
May 19, 2012 | Maytag Washing Machines
Is the pulley that is fixed to the motor on my Maytag mav408daww serviceable. It seems that the bearing separted from it.
The pulley is not sold separately. You will have to replace motor which comes with pulley attached.
Jan 12, 2011 | Washing Machines
How to remove the agitator from a Maytag Washer PAVT-1 in order to untangle caught cords
Open the lid, remove the Fabric dispenser, then you will see a nut in the agitator, remove it and lift the agitator out.
Nov 20, 2010 | Maytag Performa PAV2200
How do i remove the agitator
If this is a true Maytag, there is a 1/4 inch hex head bolt in the lower portion of the agitator, on the side. Loosen the bolt and pull the agitator off. If not a true Maytag I will need a model number.
Jul 05, 2009 | Maytag Washing Machines
Jan 12, 2009 | Maytag Legacy Top Load Washer
Seal leaking from tub. How do I remove agitator?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
Aug 11, 2008 | Maytag Washing Machines
How do you remove the agitator on a Maytag Dependable Care Washer?
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Aug 09, 2008 | Maytag Dependable Clean Top Load Washer,...
I have a foul smell comming from my washer I want to try to take off the agitator and clean it How? :)
It depends on what model Maytag washer you have. If you have an Atlantis or Performa model Maytag you remove the agitator by, first, pulling the agitator cap and softener dispenser off. Locate the bolt on the center post and and loosen. The agitator will pull straight up to remove. If this is a Dependable Care model Maytag, there's a 1/4 inch screw located on the SIDE of the agitator about 3 quarters of the way down. Locate this screw and loosen. The agitator will pull straight up to remove. I hope this helps you.
Aug 01, 2008 | Maytag Washing Machines
Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Nov 28, 2007 | Washing Machines
Maytag Legacy MAV208DAWW Top Load Washer Logo
227 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
