Question about RCA RS2652 Shelf System
RCA RS2654 we are not able to open the drawer to insert discs. Can you help? Thanks you!
There were 2 problems that I found with my daughter's rs2654, which wouldn't open. The first is that a 2.2 ohm resistor opened up near the IC that drives the motor that opens the drawer, so no voltage to the moter. The second was that the grease in the gears was so stiff that the motor barely turned the larger pulley. Changing the resistor and cleaning up and regreasing the gears fixed it.
Posted on May 20, 2010
RCA 5 disc changer MOD@ RS2767iFE drawer want open
Mechanical fault. Contact any service technician to get it repaired. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 22, 2016 | RCA Audio Players & Recorders
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
Nov 24, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
How to turn on rca cd player
Hello
1. Press 'SOURCE' repetedely to select 'CD' mode.
2. Press "Open/Close" button to open the drawer.
3. Insert disce and press 'Open/Close' again, and the inserted CD will play automatically. OK.
Jul 29, 2011 | RCA RS2635 CD Shelf System
Sometimes Xbox 360 won't read disc
Hi...
Get a can of "Dust-off" from radio shack or walmart
It has an extension tube for the can . Use it and spray into the drawer slot with the drawer open. Swish it around a bit and wait for things to warm back up.
Also check your game disc for extra smudges or scratches that might need to be polished out
If this help,please rate my help
Thanks
Jan 26, 2010 | Microsoft Xbox 360 Console
Cd drawer
there is a little pin hole on the front of the cd/dvd draw, insert a pin or sharp object and it will eject.
Sep 17, 2008 | Computers & Internet
Dvd player
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Jan 14, 2008 | Televison & Video
Stuck disc drawer rca model drc8312n
If there is a tiny pin hole in the front a straightened paper clip does wonders. Simply insert to release the drawer. At least that's how it works on computers ;)
Mar 28, 2007 | RCA DRC8312N DVD Recorder/VCR
Drawer came off track
You need to open it, lift two tabs at the back of the tray on each side to allow you to remove it, then re-insert making sure it's back on the rails.
Mar 10, 2007 | RCA CDRW120 2-Disc CD Recorder
RCA RS2652 Shelf System Logo
373 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
