Question about Epson TM-U220 Matrix Printer
Printer prints garbage...
Repaced my old Epson RP265 serial printer with newest model TM-U220 printer. My system is DOS based "BusinessVision II" software that uses Decimal codes to send to printer. My new user manual didn't indicate any decimal codes...the printer prints basically garbage when I try to print.what goes on???
  • golscamp Jan 03, 2009
    Port and cable are the same as I used for old printer. Remember
    my system is DOS with commands, not Windows!
    Thanks for trying.
  • Anonymous Mar 19, 2014
    the printer indicates print error at the start of printing
    Genius:
  • 1,447 Answers
Hi
make sure it is configured to the right port and using the epson driver. go to printer and faxes and properties then ports. check of the correct printer driver is check. what type of cable are you using anyways? com for serial, LPT for parallel.
Hope this help
Posted on Jan 03, 2009
Can i install two(2) EPSON TM-U220 printer on a terminal?
You can have as many printers as you want but each has to have a port defined. When you installed the driver, you must have defined both as one printer and now it's confused the system. Uninstall ALL printers and start again making sure each has a unique port.
Sep 13, 2014 | Epson Tm-u220 Pos Printer Serial Black
Epson tm-u220 not printing receipt info, but printing random symbols
Hello
Try to re install the drivers. Uninstall the old drivers first
Oct 03, 2012 | Epson TM-U220 Matrix Printer
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Epson TM-U220 not working with window 7
download this driver APD-406aE i did it and it is working perfect with my windows 7 on a TM-U 220B
Jul 07, 2010 | Epson TM-U220 Matrix Printer
Epson TM-U220PD printer network card problem - recognition
Did you change the dip switches? I believe that for the serial printer to work with ethernet, you need to have switches 2 and 4 on bank 2 set to on.
Jul 13, 2009 | Epson TM-U220 Matrix Printer
Problem in Chinese chacracters printing , prints only junk !
there is nothing wrong with the printer ... the issue is the support in your computer for those languages...
May 29, 2009 | Computers & Internet
Can u give a download driver for pos printer
www.barcodesinc.com/epson/tm-u220-drivers.htm
Oct 03, 2008 | Epson TM-U220 Matrix Printer
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
How to eject cash drawer pos
Open the Cash Drawer
Hex code
<1B><70><30><40><50>
Apr 03, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Nov 27, 2007 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
815 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
