Question about Crosley Audio Players & Recorders
Tone arm lifts too soon
The tone arm will not run the full length of the record.
5 Suggested Answers
  • 133 Answers
SOURCE: tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Posted on Sep 16, 2009
SOURCE: After playing a record the tone arm lifts too high
small flat head screw in the rear of the arm pivot.
Posted on Jan 10, 2010
dunnbiker
  • 8546 Answers
SOURCE: dual 1218
What happens if you lift the tonearm and slowly move it over its travel in toward the label area past the expected point at which it should cycle? There should be a mechanical click as it engages the lift / return cycle. If so, the mechanism works but might be out of adjustment due to wear and tear.
Perhaps cycling the Record Size switch a few times might have a positive effect on the function. There doesn't seem to be a user adjustment for the end of play cycle.
You can get the manual for free after you register at:
http://www.vinylengine.com/library/dual/1218.shtml
If you decide to venture into the mechanics be cautious, always protect the tonearm from damage and make sure you rotate the platter only clockwise as there are mechanical interlocks that could get damaged if you turn it the wrong way.
Posted on Mar 10, 2010
SOURCE: My record spins fine when
It would appear you have a problem with the "Cuing mechanism" this is quite a common problem. This link below will assist you to understand about it.
http://www.turntablebasics.com/advice.html
What you need to do is locate a service manual for your exact make and model, in there you will find the necessary troubleshooting steps to take to isolate and cure your issue. However I have had a look and have been unable to locate any, perhaps a direct approach to the manufacturer may yield one?
It can often simply be a faulty switch, the "Mode Switch" this is simply replaced, however to obtain this one ,must have the parts number, the ONLY place this is available is in a service manual. Sometimes it is the belt or drive? it is usually something quite simple, often it's obvious once the TT is disassembled.
should you not wish to DIY, simply find a competent Turntable repair place and ask first for a "Quote" once appraised of the costings etc, then go from there.
http://www.ehow.com/how_2086746_troubleshoot-turntables.html
http://www.audiokarma.org/forums/showthread.php?t=37752
below is a link for the user manual...
http://www.crosleyradio.com/Manuals/CR249_Manual.pdf
http://www.vinylengine.com/library.shtml
Above are a couple of sites that may help you if you wish to DIY?
Posted on Aug 18, 2011
How can I stop the tone arm from returning too early on smaller records?
The adjustment for auto return position is normally at the tone arm base on the left side under a rubber grommet. Use a flat blade screw driver to move adjustment screw, then test. Keep fine tuning until arm lifts at desired position. Cheers John. Stylus City NZ
Jun 14, 2014 | Crosley 0187SST Turntable
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Tone arm not lifting when record is over
Hello Caufield,
Ideas... Yes, indeed,
But without a MAKE or MODEL they focus
a lot on ESP & other psychic capabilities...
(Mind reading: The lack thereof)... Sorry...!!
In ye olden daze...
when I was young the (stacked record CHANGERS &
simple turn table) TONE arms were largely Rube
Goldberg
electro-mechanical thingy-ma-call-it...
that triggered off of the wag action of the center grooves ...
(in all 78, 45 and 33 rpm records (once upon a time)).
Rube Goldberg Wikipedia
Without BENEFIT of year, make or model... ONE
might ACTUALLY look at the mechanical MECHANISM
and SEE the broken or missing spring, link or cam...
The very first/last action of ARM CONTROL was
the lift/lay action of the tone arm..
Without that FUNCTION "working" you are just
ruining records & needles...
My best advice would be to REPOST with
a hint of the proper nomenclature... I'm pretty sure
an appropriate volunteer expert will step forward.
Try it... you will like it and it is still totally FREE
Carnac the Magnificent
Aug 07, 2017 | Audio Players & Recorders
Turn table doesn't start when tone arm is lifted
Did it used to start when you lifted the tonearm?
Many turntables start when the arm is moved over the record.
Jan 29, 2013 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
Tone arm will not move over on self-start unless
Hi, they are not an auto start model turntable. To start lift tone arm off rest and move into position at start of record. It will automatically lift and return to rest as well as shut off at end of record. cheers john ,, Styluscity.com
Feb 21, 2010 | Thorens TD-190 Turntable
I have an old Califone 1400 all records skip new needle
There's not enough pressure to keep the stylus down in the grooves. Increase the weight (on the end of the arm).
Feb 10, 2010 | Audio Players & Recorders
Tone arm comes out and touches record, then goes back to cradle
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Audio Technica AT-PL50 Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
104 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
