Question about IBM ThinkPad G41 Notebook
System Board Part Number Location
I am tring to locate the system board P/N for my IBM Thinkpad G41 Notebook. I've looked along the topside edge and the bottomside edge but have not yet found it. The only identifier clearly noted in large print on the board (and not on the edge) is DAOBF4MB6D2 REV:D any suggestions?
  • dghubb1 Jan 05, 2009
    I have Thinkpad 2886-XX1. I followed your link, but here's the rub....
    the system board part #'s listed don't match what I finally found FRU 27R1870. I searched the web with that system board # and found some matches from various vendors. Maybe there was an engineering change which never got recorded in the IBM/Lenovo manuals. I've found prices ranging from $115 to $235 for the board. Should I expect the board to be populated with relevant ports and modem card (not RAM or CPU) or would it be "bare bones".
    Thanks, Dave
  • JDTec
    JDTec May 11, 2010
    Do you see a # that starts with FRUxxxx(x=numbers) ?
  • IBM Master
  • 4,338 Answers
Here is the service manual. On page 145 in the reader (141 in the actual manual) you will see the part numbers(FRU) for your system board. You will have to look on the bottom of your laptop and note which Machine type you have. It will be a # like 28xx-7xx
(not necessarily these numbers)
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/39t6188.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 02, 2009
  • JDTec
    JDTec Jan 05, 2009
    The board will come with everything but the Ram and the CPU.
    Lots of luck..
Bad home key on thinkpad g41 keyboard is there an alternate way to increase brightness?
Try using Thinkvantage Application to adjust as follows:
ThinkVantage Control for Display Brightness
  • 4 Click the "Start Menu," then click "All Programs" and locate the "Access IBM" program group.
  • 5 Click "Thinkpad Configuration" and click "LCD" to open the brightness control dialog. Select the brightness from the drop-down menu and click "OK."
  • 6 Click the red "Exit" button in the upper-right corner of the Configuration utility to close it.
Read more: How to Adjust the Brightness on an IBM ThinkPad Display ' eHow.com http://www.ehow.com/how_5818403_adjust-brightness-ibm-thinkpad-display.html#ixzz277iQ4g48
Sep 11, 2012 | IBM ThinkPad G41 Notebook
3 series of 4 beeps on ibm thinkpad t41
The closest diagnostic code that matches what you're saying is the 4 (continuous beeping). This is a video module failure or system board failure. The T41 does not have a separate video module which indicates system board failure.
If you can locate a T41 with a good system board on eBay for less than $50 then you could attempt a repair on the system. Otherwise the system is dead and its cost is greater than its value.
Oct 17, 2011 | IBM ThinkPad T41 Notebook
IBM r41 thinkpad makes one long beep and two short beeps when starting but the computer then stops and only the power light and the light to the left stay on
There seems to be a slight problem here as there is no R 41. There is a G41 and a T41. They both have the same beep code and symptom. One long and two short is:
1. System board
2. LCD assembly
3. Dimm
If you copy and paste this link it will take you to the support page for think pads. Use the complete model number on the bottom of your machine and select users guides and manuals and you'll be able to download a copy of the HMM (hardware maintenance manual) used by IBM techs.
May 07, 2010 | IBM ThinkPad T41 2373 Notebook
IBM G41 turns on but has no video output and gives a three beep sound? What could this mean?
this could be the problem of ur vga card which is on board(built in).to check it just press the keyboard at the space button hardly and then turn your machine on.
Oct 07, 2009 | IBM ThinkPad G41 Notebook
Where is the location of the memory stick on ibm thinkpad t30?
you will have to take the back off then you should see the memory attached to the m/board
Jul 31, 2009 | IBM ThinkPad T30 2366 Notebook
Trouble resetting error code on my t-30,error code reads 0176
Error code 0176 concerned with System Security. The system has been tampered with.
Try to enter the bios setup. Save the bios setting and exit. Lets see if it resolves your problem
Nov 25, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Graphics
Graphics cards on laptops cannot be changed or upgraded. In order to do this, I believe you have to change out the screen, because graphics cards in laptops are within the screens.
May 22, 2008 | IBM ThinkPad G40 Notebook
IBM G41, Can't load fresh Windows XP OS
You will get a better response if you pay for the expertise we have to offer!
May 08, 2008 | IBM ThinkPad G41 Notebook
IBM ThinkPad G41 Notebook Logo
177 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Michael Vincent Cruz
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
