Question about Intex 1500 Gph Swimming Pool Filter Pump Above Ground
3 meter intex pool has 3 hose outlets - Intex 1500 Gph Swimming Pool Filter Pump Above Ground
  • 76 Answers
SOURCE: I have an intex 15 x 48 pool. The old pump wasnt
check the intex site for adapters and other parts you might need.
I don't think you should buy new pool .
Posted on Jul 15, 2009
  • 297 Answers
SOURCE: Hayward pump hose and intex pool
Im thinking that hot glue would not harden completly in a direct sun situation not to mention the potential mess
What I did was go to my local hardware store and bought rubber o rings ( sorry dont remember what size) put them on the fitting slipped the hose over it and clamped on top of that area. Has been fine all summer
hope you figure it out
Posted on Aug 05, 2009
  • 8 Answers
SOURCE: hose hook ups
If you look at the chlorinator you'll see an arrow pointing in the direction of the flow. Basically the water coming out of the pool should be going through the filter tower first and then through the chlorinator and ultimately back into the pool.
Posted on Jun 16, 2010
  • 22 Answers
SOURCE: what size hose can I use when vacuuming the pool I...
you can use the standard 2" hose. i would get one atleast 20-25 feet long though
Posted on Jun 17, 2010
  • 12 Answers
SOURCE: where does the hoses go and in what order do they
The two hoses are interchangeable...one to each hole, it doesn't matter which. Make sure you do this before the water level reaches the holes, but don't start the pump until after the water clears the intake hole.
Posted on Jun 30, 2010
I have forgotten what hose connects to what from pool to pump. above ground simple pool pump.
Discharge of pump goes into inlet of filter, outlet of filter goes back to pool.
Line from pool skimmer or bottom goes into inlet of pump.
Dec 21, 2010 | Intex 1000 Gallon Easy Set Swimming Pool...
Water flow seems to restricted and the hose caves in
I FOUND ON MY INTEX POOL WHEN HAVING THE SAME TROUBLE IT HAD BLOCKAGE BETWEEN THE 1 1/4 HOSE ADAPTER ON THE INLET SIDE OF THE CONNECTION SUPPLYING THE PUMP AND THE BLUE FILTER SCREEN BEFORE THE OUTLET VALVE. MIGHT BE WORTH CHECKING THERE AS THE STRAINER BASKET WILL NOT CATCH ALL THE FINE DEBRIS. TAKE YOUR OUTLET HOSE OFF AND OPEN THE VALVE AND SEE IF IT IS RETRICTED.
Jul 01, 2010 | Intex Plunger Valve & Straniner Basket set...
Low flow indicator on
  1. Plug your inlet and outlet openings so that you can do the next steps
  2. Assuming you have checked your outlet for blockage (skimmer, screen, etc.) take the hose off the end of the chlorinator (goes to the pool inlet) and check the elements for buildup. If all clear
  3. Take the hose off the pump inlet (comes from the pool outlet) and check for hair, grass, etc. clogging the inlet.
Jun 28, 2010 | Intex Automatic Salt Water System for ...
Which hose goes where when hooking the pump up to the pool?
The outlet from the skimmer goes to the pump inlet the pump outlet goes to the filter inlet the filter outlet returns to the pool
Jun 19, 2010 | Intex 1500 Gph Swimming Pool Filter Pump...
How do I hook my 633T intex pump to my 15'x42" pool? The strainers do not attach to the black things inside the pool.
We just cut the holes bigger in the side of the pool, it works great now. Just got to make sure you do not cut it to big! I do nnot understand why they can"t make it standard.
Hope this helps!!!!!!
May 18, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Aug 04, 2009 | Intex Automatic Salt Water System for ...
New Intex FP621 4000 Pool Pump Noisy
I have a 16 x 48 intex pool with the 1inch inlet and outlet. I purchased the intex 4000 pump. The attachments are too big for the inlet and outlet so i then purchased the adapters. The plungers are very noisy and allow air to get into the pump. I removed them and hooked the hoses up to the adapters directly. That worked as long as the adapters were new. This year the seal comes loose and allows air to get into the pump. I even tried allowing the top nut to be loose to allow air to escape. This year nothing works. The pump is just too strong for the holes. I was considering cutting the holes bigger and glueing seals on there but i was concerned about creating weak spots in the pool. I am tired of spending money on it so i did the redneck thing. I can say that because well, you might consider me one. I took the inlet hose off the connector and plugged the hole with one of those little black things. I took the hose and run it up through the hole in between the liner and the poles and down into the pool. If you run it over the top it will not work correctly. Take the hose and tie them together between the two sides as best you can to keep the hose in the pool. If you look at the smaller intex pools that dont have holes, that is how they have the pump hooked to the pool. VOILA! You have an airtight inlet to the pump. You do not need to do that to the outlet because its not sucking water its just pushing it. So, just hook the hose up as you wish. When you need to clean the filter, I put wash clothes in the hoses to plug them and voila. No air gets into the filter. Done! It is actually keeping my pool clean this year. Also, i purchased one of those aqua vacuums and it does work great for this pool. Once you get the big stuff, sweep it with a pool broom and the filter will do its job. You can vacuum these pools with the filter type pumps. Next time, i will purchase a sand filter and be done with it. Happy swimming with less work.
Jul 26, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Jun 28, 2009 | Intex 4000 GPH Filter Pump
Intex pool pump directions
from skimmer one hose goes into pump. outlet goes back to pool
Jun 16, 2009 | Intex 4000 GPH Filter Pump
Intex 1500 Gph Swimming Pool Filter Pump Above Ground Logo
22 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
