Question about Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP
How to close hayward ec75 pool filter
How to winterize the filter for the winter
4 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: no suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
Posted on May 24, 2010
StepehnD
  • 78 Answers
SOURCE: I just purchased a home with the Hayward EC75
I take it this a cartridge filter. Might be the filter is clogged if the pump is operating ok. I would remove the filter (be sure to shut off the valves), and clean it. Degrease is first with a filter degreaser. If there are mineral deposits on the filter, give it an acid bath. Be sure to rinse the filter THOROUGHLY before reinstalling. Since this is a new home for you, I would check the pump impellar, basket and skimmers for debris too...
Posted on Jun 18, 2010
kebah
  • 683 Answers
SOURCE: Does the Hayward perflex ec75
Perflex ec75 are designed for installation 2 feet above the pool water line. For pump selection and other pionters, you can refer to the owner's manual, visit http://www.hayward-pool.com/pdf/manuals/Manual257.pdf
Posted on Jun 04, 2011
I have a Haywood pump and filter - S180t - I started it up after winter and I have no backwash or rinse pressure??
Did you drain it completely before Winter? If water was inside the pump, it could have been damaged by expanding freezing ice. The impeller could be trashed (i.e. ''physically broken'').
May 18, 2015 | Hayward Industrial Products Hayward Pro...
Winterizes ia filture
winterizing a filter is easy. turn pump off, remove the drain plug at bottom of filter. if its a cartridge filter, remove the cartridges and clean before reassembly. on a sand filter, put the dial valve in the 'close/winterize' position.
Jun 13, 2014 | Hayward Pool & Spa
Closing inground pool
Question:
How do I close my pool for the season?
by Osko Pool n Spa Information
By following the provided instructions, you will be able to professionally close your pool for the winter season. Additionally, you will protect it from winters abuse and make opening it next season...simple.
Required Tools
a) Standard Screw Driver
b) Phillips Screw Driver
c) Ratchet Set
e) Plumber Pliers
f) Sump Pump
g) Extension Cord
h) Garden Hose
i) Five Gallon Bucket
j) Air Pump or Shop Vac
k) Pool Vac & Accessories
Required Chemicals
a) Pool Shock
b) Algecide
c) Chlorinating Tablets
Required Accessories
a) Winter Cover
b) Pool Pillows or Inner-tubes
c) Chlorine Float Dispenser
d) Water Bags (for ingrounds only)
Step One - Debris & Chemicals
Remove any debris from pool water by use of a leaf rake attachment.
Add the appropriate amount of shock treatment to the pool water, as prescribed on the packaging.
Add the appropriate amount of algecide to the pool water, as prescribed on the packaging.
Run your filter for the appropriate time to circulate all water once.
(see your filter documentation for your size pool)
Install your floating Dispenser and winterizing tablets.
Step Two - Vacuum & Water Level
Vacuum your pool while setting your filter to the "back wash" or "waste" setting.
(this will help lower your water level)
After vacuuming, install the sump pump and drain pool to about 6 inches below your thru-the-wall skimmer.
Step Three - Parts Dissassembly & Cleaning
Disconnect all ladders, filter systems, hoses, solar reels and/or other accessories.
Using standard household cleansers, thoroughly clean all ladders, solar reels and/or other accessories.
Dissassemble filtration system.
Remove sand, cartridge or DE powder from your filtration tank.
Thoroughly clean all filter system parts.
Allow all items to dry.
Store all items in an area that will not be subject to freezing temperatures.
Step Four - Pillow & Cover Installation
Inflate all pool pillows or inner-tubes.
Install one pillow for every 15' of linear water surface.
(example: a 15' x 30' would require at least two pillows)
Tie pillows to pool area via nylon rope and place equally with respects to pool walls and each other.
(this is extremely important! This prevents freeze damage)
Install winter cover as prescribed by the covers manufacturer.
Step Five - Winter Tips
During the winter months, remove any excess snow from the winter cover.
(If you have a solid cover, this will prevent excessive weight form tearing you cover)
(If you have a mesh cover, this will prevent excessive water build up)
Hey, Your Finished! Congratulations, you just saved money while doing a professional job
Nov 11, 2013 | Hayward SAND FILTER, PRO SERIES
Cannot get filter apart, all 12 bolts are removed but i still cannot get it apart??
This is called Vacuum lock. You need to open up the purge valve if there is one, and if not, you must let air into the system somewhere. Try opening the pump pot or loosening any close by pluming unions
Sep 24, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Instructions for putting Hayward Model EC-75 filter on pump for a inground pool
Here is a copy of the users manual for these pool filters. It should give you detailed instructions about installing the Hayward Perflex.
http://www.backyardcitypools.com/images/hayward/perflex-system-manual.pdf
Aug 30, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I just purchased a home with the Hayward EC75 perflex system the water isn't returning to the pool what is wrong I am used to owning low maintenance quality filters is this one a dog? what do I need to do...
Jun 18, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
How does heater work to keep freeze off pool in winter
What state do you live in, what is the brand name and model number of the heater. If you live in a state that gets cold during the winter, call you local pool store and schedule a closing. If the pump is running and water is not circulating, most likely the pump lost prime or your filter needs to be backwashed, or there is some debris in the impeller.
Nov 25, 2008 | Hayward H Series Pool & Spa Heater 400k...
Open Questions:
See all Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP Questions
Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM W/1HP PUMP Logo
18 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
