Question about Microsoft Xbox 360 Console
Won't show the picture or sound
My xbox 360 will turn on but wont show any picture or sound. on my tv it says.. mode not supported.
Here's one possiblility.
There should be a switch on the x box cable that goes from High definition output to analog.
Try changing the swith setting.
Posted on Jan 02, 2009
4 Suggested Answers
  • 44 Answers
SOURCE: my xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Posted on May 14, 2008
  • 31 Answers
SOURCE: No picture on TV when Xbox 360 is turned on
For the most part, an XBOX will display a picture on the TV regardless of what the settings are. If there is no picture, it is most likely the cable or the XBOX output terminals themselves.
Since you have said that your friend's AV cable didn't work either, even though it did on his, we must assume that the problem is with the XBOX.
 If the warranty is still on the console, call Microsoft and send it in. If it isn't either call Microsoft and see that they can do, or find an online repair shop that can help you.
If you need furthur assistance, feel free to ask. If this response helped you, please rate it!
Thanks!
Posted on Apr 13, 2009
  • 3 Answers
SOURCE: xbox 360
This problem is covered more extensively here:
http://www.fixya.com/support/t260067-xbox_360_no_video
Posted on Dec 06, 2007
My xbox 360 will not produce picture on the T.V.
I believe your xbox may be heading towards the RROD
(Red Ring of Death) it is due to the graphics card overheating and has now failed but it hasnt caused a total hardware failure which is why you are still getting sound! their are fixes on ebay if you look for RROD repair kits you will come across quite a few, make sure it has a guide, if you are confident you should have no problems, what you will need is T10 and T8 screwdrivers, sellotape, wd40 and a repair kit with thermal paste and about 1 to 2 hrs of spare time.
Hope this helps
Paul
Apr 05, 2010 | Microsoft Xbox 360 Console
Xbox 360, 3-4 yrs old, suddenly no picture, only sound. Can you help advise how to fix it? TV (new, with HD, LED etc), says mode not supported, or No signal found, although connected. Sound comes through,...
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Stop the heat to the scaler chip and you will have it working.
Feb 08, 2010 | Microsoft Xbox 360 Console
My xbox wont show a picture but it has sound
ur xbox is in hd mode.to get it out of it turn ur xbox 360 on with remote than hold ( Y ) and the R trigger together and wait and see if it turns on and if it doesnt ull need a new connection for ur tv
Jul 08, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont show a picture but it has sound
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
please rate my solution :) thanks
May 31, 2009 | Microsoft Xbox 360 Console
Since your sound works, you know the xbox is booting properly.  Check two things: 1) try another television to make sure it's not the tv.  2) try another cable(from a friend?) to see if the cable is bad.
**Also, if the video settings were saved on an unsupported setting, it could cause the screen to not show video.  If you try these 2 things and you think someone might have saved bad settings, I recall a button combination you can use to reset certain things, and I try to help if it comes to that.
May 30, 2009 | Microsoft Xbox 360 Console
My xbox wont show on my tv,cant hear sound but no
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
May 12, 2009 | Microsoft Xbox 360 Elite Console - Black
Thanks!
Apr 13, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
No Screen on the Xbox 360.
i would help you but i have the same thing my did that to but my xbox show me colors then it whent to black screen and says to call xbox/support
Oct 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
329 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
