Question about RCA F36650 36" TV
HOW TO MAKE X BOX READY HOOK UP TO WORK on my rca f36650 tv.
I do not have a glink must i have this to use dvd or vcr? even the xbox ready plug in will not respond or work but the tv is clear in picture and color,works great!
Using a universal remote my 13 yr old son found a button which showed dvd/ vcr/aux this is what we needed. these channels are not assesable using channel up/down buttons.
Posted on Jan 03, 2009
My t.v. whines when innitially plugged in. no picture (rca f36650) guide plus gemstar xbox ready entertainment series
The tv have a dead part call the FBT-Flyback transformer,a big black block of plastice with a red wire with a black cap hook it to the CRT-(Tv picture tube).The FBT-give the tv highvoltages to the CRT(Tv picture tube).This tv is old model of an analog tv probally can't find part for it anymore.
Dec 08, 2010 | RCA F36650 36" TV
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Apr 13, 2010 | iLO DVDR05 DVD Recorder
The inputs on my tv arent workin, how can i hook my xbox up to alternate sources in order to play?
Well you need a TV. What happens when you connect check the switch on the AV cord that plugs into the 360. If you have no RYB or rca ports that work on your tv buy a nice used CRT tv from cragis list for 20-40 $
or check http://rns-systems.com/ for a used LCD
Oct 16, 2009 | Microsoft Xbox 360 Console
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have the RCA RT2500 model and I am looking for directions to connect tv, DVD, gaming, Cable Box, etc are there anywhere on line I can find it? thank you
the back should have a squared in box around the inputs like dvd vcr sat tv cd, dvd and sat have svideo and component a/v plugs, the vcr just has component rca a/v ports, tv and cd are just for audio, then you also have the option to hook up optical for dvd and sat. just plug your vcr into the vcr box and hook up svideo or the yellow monitor out plug to your tv, hook in the speakers and turn that baby up.
Jan 07, 2009 | RCA RT2500 System
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Rca vcr
there a a bunch of different ways. 1) if you don't have a cable box hooked up to this tv,plug the main cable wire into the vcr input then the vcr outout to the tv.2) if you do have a cable box, plug the main cable into the cable box input, then the output to the vcr input, then the vcr output to the tv. put both the tv & vcr on channel 3 for this connection. [ you must have the vcr on channel 3 to record from the cable box!] 3) if you have aux line/video or source inputs on the back of your tv,you can hook up rca cables [ red, white,& yellow ] from the rca outputs on the vcr to the tv inputs.
hope this helps
wg
Feb 04, 2008 | RCA VR637HF VHS VCR
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Rca 36" tv
are you on outside antenna or cable? does vcr or dvd do the same?
sounds like tunner in dvd or vcr works.
Dec 03, 2007 | RCA F36650 36" TV
Xbox
this 360 or original?
anyhoo, check the yellow video cable for any cuts, pinches, etc and if you can borrow a mates and test it on your box, aso try plugging your xbox into a DVD/BR or even VCR and then the DVD/BR VCR into the TV.
GOOD LUCK.
Oct 10, 2007 | RCA P52926 52" Rear Projection Television
RCA F36650 36" TV Logo
96 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
