Question about Maxent MX-50X1 50 in. Plasma Television
My T V is not working correctly!
Message comes up that says "The HD content Protection of your display has been compromised please use your Component connection" Then the screen turns green, but you can still hear the sound.
We changed to a HDMI cable. After doing that, every time we wanted to watch tv, we had to power the tv before the cable. If we did not, it would flash a green screen. We never had to do that before until we switched cables out. Today, I was watching tv and a blue screen with a message that read " Your HD content protection has been compromise, please switch to the _____ cable (not sure exactly what it is called but the 5 cord cable)". Is there certain HDMI cables that are not completely campatible with certain tv's? Please help.I get the same message when using my cable box with an HDMI cable but NOT with my DVD player. I do NOT get the message with cable box and component cables. Would love to know what's going on. Have a Samsung 50" DLP (HLS5087W) TV.
    Novelist:
  • 163 Answers
Try changing the wire one to another.
note only audio and video wires.
Posted on Jan 02, 2009
What does 'this tv dose not support this programs content. Replace HDMI with component cables to view' mean?
The message has appeared because the TV can not display the hdcp signal that is now used to enable copy protection over the HDMI cable due to the TV being older than the hdcp encryption system (the hdcp is not fitted to your TV )
The two options open to you are
Replace the TV with a hdcp compliant TV
Get a component lead set up
Apr 01, 2016 | Sylvania Televison & Video
When trhing to watch Netflix I get an error message"this content requires HDCP for playback" on my LC320EMX
HDCP- High bandwith digital content protection is something that would be built into your tv. it prevents you from copying programs to another device. You have two options- one use a different type of cables like say rca red-white-yellow cables or for hd video. component blue green red cables and red and white cables for sound
Oct 19, 2013 | Emerson LC320EM8 32 in. LCD TV
DHCP
Hi Harryward_26, my name is Cheri Torres and I work on the Social Media Team at DISH. In order to comply with movie industry standards, DISH network, as well as all TV providers, must enforce content protection standards when required. This message indicates that your TV or connection is not High bandwidth Digital Copy Protection (HDCP) capable. It is likely your TV was manufactured before industry standards required HDCP. In order to resolve this issue you would need to replace your HDMI cable with component cables (red, green and blue). Once you do this you will be able to view the content. If you have any further questions or concerns feel free to email me direct at Cheri.Torres@Dish.com. Thanks!
May 05, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
I have a pioneer vsx-30 with hdcp error on the face i see it when a scientific atlantic cable box is connected through a componet connection
Component cables don't have the ability to carry decrypted HD info.
HDCP is "High Definition Copy Protection"...In theory, it prevents you from running the HDMI cable out of your receiver, and into a recording device, thereby recording HD content without a license for it.
HDCP handshaking is done between devices that run HDMI, or DVI.
If you're running component from your Cable box, and then HDMI out to your TV, then the content you're carrying from the Cable box may not be getting decrypted properly when it gets upscaled onto the HDMI port from Component.
IT could also simply be that you're using an HDMI 1.1 or HDMI 1.2 cable, which may not be able to carry the high bandwidth stream of your Receiver and TV.
Please be sure that all HDMI devices can support the same HDMI version, and also be sure your HDMI cable is labled "HDMI 1.x compliant". . .e.g. if your TV and Amp support HDMI 1.2, make sure you're also using an HDMI 1.2 Cable.
Apr 21, 2011 | Pioneer VSX-305 Receiver
Cant get hd to work
What is HDCP?
HDCP stands for High-Bandwidth Digital Content Protection, a copy protection scheme to eliminate the possibility of intercepting digital data midstream between the source to the display. The format designed by Intel and licensed by Digital Content Protection, LLC using an authentication and key exchange procedure before video and audio is presented. Products compatible with the HDCP scheme such as DVD players, satellite and cable HDTV set-top-boxes, as well as few entertainment PCs requires a secure connection to a compliant display, the process often described as the handshake. Due to the increase in manufacturers employing HDCP in their equipment, it is highly recommended that any HDTV you purchase is compatible. Although most video devices support high-definition video over component output, analog connections are scheduled to phase out in the future or possibly forced to limited resolutions output.
Why is it important to me?
Although manufacturers are still making most products with at least component HD output, new generation of products like HD-DVD and Blu-Ray devices will limit the analog output resolution (Analog defined as Component or RGBHV). The highest resolutions these devices can output (720p/1080i/1080p) will be available on via the digital (DVI or HDMI) connections that employ HDCP encryption. Any new HDTV purchase should have a digital HDCP compatible input.
It is important to note that HDCP is currently not a standard used in PC monitors, and almost none of these displays have Component inputs. Although PC monitors are HDTV capable, HDCP encryption limits this type of use. If you use an HTPC and want to ensure dual use of your new flat panel display, look for HDCP compatibility.
How does it work?
A simple answer is that an HDCP session will result in the exchange of keys between the source and display device. The source device will query the display to make sure that the equipment is HDCP compliant before video is shown. Non-HDCP devices such as PC's and older model DVI products will work with any DVI compliant display, but the HDCP compliant boxes will show an image only on HDCP compliant display.
Other products affected by HDCP are scalers, switchers, and splitters (distribution amps). While these devices do no authentication for key exchange, they must be able to transmit the presence of HDCP if the video is handled (processed) in any way. Due to the two different formats of digital connections, occasional inability for proper communications may result in loss of interoperability. The newer format, HDMI was designed to be backwards compatible with DVI and in most instances, the two signal types are easily adaptable, but older devices may not always work well with in-line devices like scalers or switchers. These problems can sometimes be fixed in "firmware' although that is not always the case. Incompatibility is often displays on-screen as a snowy image or an error message.
Hope this explains it for you.
Jan 08, 2011 | Televison & Video
No video at all!
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues, including HDCP (High Def Copy Protection) through HDMI issue. Component cabling should eliminate this problem.
I hope that helps.
___________________________________________
Download Bose LifeStyle V30 User Manual
May 31, 2010 | Bose Lifestyle V30 Home Theater System -...
Two Apple 23" Displays (Switching Parts)
Look for puffy electrolytic capacitors on all the boards. If the tops are not flat they need to be replaced. Sometimes they will expand and shed the plastic covering or expel its contents through the bottom which can be easily seen. The fuse and power supply boards should swap.
May 10, 2017 | Apple 23" Flat-Panel TFT-LCD Cinema HD...
Unable to display HD device (PS3) on HDMI screen
Press the INPUT button on the remote or TV control panel until you find HDMI.
When you turn on the PS3 keep your finger on the power pad until an HDMI message apears on the screen.
This should FixYa.
Let me know and please rate this solution.
Lone99star
Feb 10, 2009 | Olevia LT42HVi 42 in. LCD Television
Toshiba 52hm84 DLP-HDMI Component has been compromised?
This is a wild guess, but I believe that you are being **** by the movie industry. The HDMI protocol includes a form of DRM (Digital Rights Management) for high resolution content called: High Bandwidth Digital Content Protection Basically this means that the media (disk or broadcast) instructs the player (in your case the cable box) to insist that any downstream devices (your TV) is industry and DRM compliant. Specifically this evil protection scheme is designed to plug the analog hole and make it impossible for you to record or copy the movie by using an analog output from your TV. This even restricts the size of the TV you can play the movie on, thus preventing pubs and bars from displaying the content on big screen TVs without paying royalties. The message means that the manufacturer of your TV has refused to toe the industry line. 1984 Anyone ? Martin
Apr 24, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Maxent MX-50X1 50 in. Plasma Television Logo
70 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
