Question about Kenmore 64902 Electric Dryer
Will not stay on
When I try and start the dryer it will not stay on. It will run if I hold the start button down but will not continue to run once I let go.
  • Anonymous Mar 28, 2014
    yes only stays running if start button held in
  • 5,911 Answers
Your problem is usually associated with the small micro-computer board located inside the control panel. You can access the inside of the control panel by following these simple steps: 1. Unplug machine. 2. Remove the end caps of the console. This can be done by inserting a flat blade screw driver into a groove at the top of each end cap on the back of the console and lifting up slightly. The end cap should just pop loose. 3. After the end caps are out of the way, loosen the two philips screws on each side of the console. 4. Once loosened, the console should flip back by pulling slightly towards you, then up. Inspect the control board for burned components. Even if you don't see anything obvious,the board could still be bad. I still recommend replacing it. I have repaired this problem before and it had nothing to do with the start switch. Good luck. I hope this helps you.
Posted on May 13, 2007
  • Jeff Rockwell
    Jeff Rockwell May 18, 2007
    Forgot to mention: If the control board isn't the problem, there's also a centrifugal switch located in or near the drive motor that can go bad giving the same indications.
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | Kenmore 63942 Dryer
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
We have to hold the start button down when for
if you have to hold down the start button to keep it running then the motor is shot-mike
Jan 29, 2010 | Kenmore 63952 Electric Dryer
Clothes Dryer won't stay on after switch is depressed.
some of them dryers have a switch other than the push button located behind the console. it also has an identical heat switch beside it. if that holding switch is bad it will not stay running. of the two identical switches the run switch is on the left. good kuck.
Jan 20, 2010 | Kenmore Dryers
Dryer button will not stay down. When you let go of the dryer button it stops. If I were to stand there and hold the button down it would stay one. While on it clicks
There is a centrifical switch in the motor that will only close once the motor is up to speed, the start button you push energises the starter winding, and once the motor is up to speed the run windings are energised by the centrifical switch.
The switch is not hard to replace but you will need the correct one, take the old one with you unless you'v got the complete model number from the motor.
Aug 14, 2009 | Dryers
Dryer starts but doesn't stay on
HI, this is a simple fix. replace the start button. the circuit has failed. it is no longer able to hold a closed circuit.
Jul 26, 2009 | Kenmore 63942 Dryer
Dryer won't stay on unless I hold the start button down. When I let go of the start button, it stops.
most likely the evenheat board is bad, but it could be the motor relay, get under the console and check the trouble shooting wiring diagram. there are several checks you can do to narrow it down.
May 24, 2009 | Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Kenmore 64902 Electric Dryer Logo
98 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
