Question about Campbell Hausfeld Air Tools & Compressors
Campbell Hausfield model # WL651500AJ runs but will not build pressure
rayname
  • 70 Answers
SOURCE: wiering
look at the motor nameplate it should have voltage and fla which is full load amps this should be calculated by an electrician for wire size hope this helps
Posted on Jan 09, 2009
  • 140 Answers
SOURCE: Air Compressor won't go over 35PSI
Hello, Your air compressor is leaking in the cylinder and is unable to produce more than the 35psi. Unfortunately oilless air compressors do not last very long. The rings and cylinders wear out. I have successfully repaired some units but, I usually recommend buying the oil type compressor. They last forever. If you want to try and repair it let me know and I'll help you. Good luck.
Posted on Jan 22, 2009
  • 89 Answers
SOURCE: compressor runs hot and won't build pressure
THE COPPER LINE IS SUPPOSED TO GET HOT, SCALDING HOT ACTUALLY. THE MOST COMMON REASON FOR COMPRESSORS NOT BUILDING PRESSURE IS CLOGGED AIR FILTER OR THE VALVES IN THE HEAD ARE BROKEN OR NOT OPENING AND CLOSING CORRECTLY. YOU MAY POSSIBLY HAVE A BAD AIR LEAK DOWNSTREAM BUT YOU CAN CLOSE THE DISCHARGE VALVE ON THE TANK TO ELIMINATE THAT PROBLEM. HOPE THIS HELPS OR GET YOU STARTED.
Posted on Apr 03, 2009
  • 98 Answers
SOURCE: campbell hausfeld 20 gal compressor builds
Needs pressure switch adjusted or new
Posted on Jul 21, 2009
  • 10 Answers
SOURCE: i need to get an operators manual on campbell
It's a "6" series
http://www.chpower.com/webapp/wcs/stores/servlet/XItemDocuments?storeId=10051&langId=-1&catalogId=10001&findModel=WL6515
Posted on Oct 16, 2009
Campbell Hausfield Electric Pressure Washer 1350 handle leaks
You are probably missing the washer or O-ring. Loosen and separate then check. It may also be a broken O-ring.
Oct 17, 2014 | Campbell Hausfeld PW135000AV 1350 PSI...
I have a 26 gal 5 hp upright campbell hausfield air compress. it will not buildi up air all of a sudden. it is building some as when i pull the pressure relief some air comes out. Any suggestions.
Hi, my name is John. Welcome to FixYa. check all your air lines for leaks, check the valve at the bottom of tank, check the line coming form the pump to the tank. You may have to remove it to inspect it. I find this one always is over looked. Thanks for choosing FixYa...John
Nov 15, 2010 | Campbell Hausfeld 2 Gallon Air Compressor
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
Wanting to adjust my cut off pressure down...its at 135 now but have in line tank, campbell switch 60 gallon
If I read your problem you would like to decrease your pressure setting on a campbell hausfield compressor, this usually can be done by turning the 3/8" nut (typical) counter clockwise which decreases the spring tension on the pressure plate allowing less pressure to break the points. Hope This Helps Don
Dec 02, 2009 | Campbell Hausfeld Air Tools & Compressors
I need to get an operators manual on campbell hausfeld air compressor model WL651500AJ
OKGO TO CH POWER.COM PUT IN THE FIRST 6 NUMBERS OF THE MODEL AND IT WILL SHOW UP
Oct 15, 2009 | Campbell Hausfeld 26 - Gallon Air...
Wont come on when switch is pushed to on
looked up Campbell Hausfield service on internet. found dealer within 1 mile of home.
Sep 11, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Sep 04, 2009 | Campbell Hausfeld PW2102 Gas Pressure...
I have a Campbell Hausfield wheelbarrow type compressor model #vt617206aj that will not stop making air, just builds and builds until emergency relief vave opens. please help
It sounds to me that you have a defective regulator valve assembly.
This is not a trivial problem. It should be repaired and NOT used until it is repaired.
The emergency relief valve is there for a reason --- to prevent an explosion of the pressure vessel if the regulator does not shut it off.
This is not a do-it-yourself type of repair. A machine shop, or even a welding shop could probably do this repair for you.
If the compressor is an older one or a low value compressor, deep six it and get a new one.
May 17, 2009 | Campbell Hausfeld Adjustable Pressure...
Jan 22, 2009 | Campbell Hausfeld 26 - Gallon Air...
Campbell hausfield power washer Model #pw175500le
Hi
First priming hte engine(put some gas in the plug hole)and start the engine for few times until the engine runs constantly.If not there is a fuel delivery problem.Check the air and fuel filters,the fuel line,the muffler and screen inside.Disassembly the carb,check and very carefully clean it with compresed air.
best regards savumihai71
Nov 02, 2008 | Campbell Hausfeld Garden
Air Tools & Compressors Logo
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
