Question about Digital Blue EasyShare MD1063 Digital Camera
Camera Kodak md1063.
When I turn on my Kodak MD1063 the lense comes out but then retracts a little and turns off . What may be the problem ?
  • 3 more comments
  • Anonymous Mar 11, 2009
    I have the same problem Im trying to find answers.
  • Anonymous Mar 30, 2009
    mine is doing the same...i was wondering if it a bad battery??? im calling kodak in the morning..i have had this camera for only 2 months.
  • kidcrombie Apr 05, 2009
    ours does the same after a full night of charging when we turned it on the lens came out a little then turned off. We cant get it on again.
  • Anonymous May 05, 2009
    i have the same problem and i only had it since march
  • Anonymous May 21, 2009
    Same problem
    President:
  • 2,761 Answers
This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. Before you purchase new batteries, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Posted on Aug 16, 2009
  • 3 Answers
Step #2 solved my problem (I brought my Kodak MD1063 to the beach) from this post below (thank you!):
http://www.fixya.com/support/t4337995-try_turn_kodak_camera_tries
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 04, 2010
    Problem Solver:
  • 5 Answers
Clean the contacts of the battery because zooming in the lenses takes up more power. so without enough power it has to turn off(but make sure that u dry it afterwards
Posted on Aug 11, 2009
4 Suggested Answers
  • 67 Answers
SOURCE: Kodak Easyshare camera model MD1063 wont turn on
hi,your camera needs a servise , its a lance problem just open your camera and remove the lance assembly and servise it properly , otherewise contact authorised person,
Posted on Aug 30, 2009
  • 5 Answers
SOURCE: my kodak md1063 digital camera switches on then
My kodak Easyshare C653 camera is 2.5 years old when suddenly did this a few times then completely refused to turn on at all. Research showed me that this is a firmware issue in Kodak cameras. Kodak website said it will look at it and try to fix it for minimum $70 which is not worth it in my case as I paid $130 for the camera brand new 2.5 years ago. So either pay the $ for kodak to fix or buy a new camera is the solution. I am buying a new camera but it won't be a kodak this time as I want a camera that last years and won't go dead after warranty runs out.
Posted on Sep 20, 2009
reitann
  • 214 Answers
SOURCE: Transfer problem with kodak MD1063
With the cam connected , open the easyshare software ,bypass the transfer window then click on the ADD PICTURES icon on the top left,under SELECT A LOCATION click on the model no. of the cam. Tag all the pictures you would like to add, then click on ADD PICTURES. Click on DONE once finished.
Posted on Jan 12, 2010
Jan 07, 2010 | Digital Blue EasyShare MD1063 Digital...
My kodak md1063 digital camera switches on then straight of,have fitted new battery no difference.
Sep 01, 2009 | Digital Blue EasyShare MD1063 Digital...
Aug 29, 2009 | Digital Blue EasyShare MD1063 Digital...
My kodak md1063 won;t turn on
replace rechargable batteries with regular AA alkaline and see if it will turn on, if it will you need a new battery pack
Jun 21, 2009 | Kodak EasyShare M1033 Digital Camera
Doesnt stay on, tried new battery, it just switches off
Get Kodak or SanDisk SDHC 2 or 4 GB memory card.
Format Memory Card.
Make sure it is charged 3 hours minimum.
Vitally
Apr 27, 2009 | Kodak EASYSHARE M1063 Digital Camera
I have kodak md1063 memory card will not format
Hi there
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Apr 16, 2009 | Digital Blue EasyShare MD1063 Digital...
    My kodak 10.3 megapixel md1063 is showing very blurry and when you take a picture they are all blurry also
    Auto focus not working - Under warranty? One year from date of purchase. If not, take it to your Authorized Service Center. I know of one in Florida, I don't know where you are located
    Apr 13, 2009 | Cameras
    Kodak md1063 cant upload pictures
    Try NOT connecting your camera to your computer.
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
    Organize edit and share your photos
    Jan 18, 2009 | Digital Blue EasyShare MD1063 Digital...
    Digital Blue EasyShare MD1063 Digital Camera Logo
    708 people viewed this question
    Top Digital Blue Cameras Experts
    Are you a Digital Blue Camera Expert? Answer questions, earn points and help others
