Question about Panasonic KX-TG1033S Cordless Phone
Light on top of phone is too bright
Is there any way to turn off the chg. indicator? It lights up the bedroom.
A black sharpie pen works well for this. I colored the light on the phone black with one, and it doesn't rub off.
Posted on Jan 04, 2009
How do i fix a running light warning that has appeared on my dashboard?
You find the bulb that is not alight and replace it Claire. Best way is to check it at night with a second person or park in front of shop windows. Check front sidelights, daytime running lights, repeaters, headlights main and dipped, indicators left and right. Then turn the car around and check rear lights, left and right indicator and brake lights. Also pay attention to the high level brake light in the back window. I had that out for 6 months and it drove me mad trying to find out why my warning light was on. I checked all the lights three times with my late wife in the bedroom window and both of us in contact on home phone to cell phone. When I found out the reason, alerted by a friend, I so wanted my wife to know the reason why, but she had died 3 months previously.
May 22, 2016 | Cars & Trucks
Can't turn off bright lights in 1996 e 320 mercedes
the switch is made into the turn signal indicator and the arm swings up and down (backward click up- backward click down)..there is a connector rod between the arm and the switch and it may have broken..this rquires lowering the steering column as the switch is on top of the column under the dash (on most models) some may still have it on the floor up by the upper floorboard left of the brake pedal(where mine is on my 89 ford)...may have to completely disconnect the battery of the car to totally kill the radio,,reconnect and see if it resets itself...good luck...
Jan 19, 2013 | Mercedes-Benz Cars & Trucks
When the ignition is turned on, the light indicating neutral flickers or is not on. All other lights, oil, turn signals and bright/dim work fine. Does the absence of the neutral light indicate an...
No ...There is a plunger switch in tranny just replace the s/w or try cleaning it i think its on top front youll see 2 wires going to it ... good luck ';';'
Jul 25, 2011 | Harley Davidson ST3s ABS Motorcycles
Have 1997 heritage softail classic neutral light will not come on even when changing blubs, other lights seem to still work,oil. bright lights, turn signals. Don,t know whar else to do?
Your neutral indicator switch may be bad. Look on the chrome cover on top of the transmission and you'll see a wire that plugs onto the neutral switch. Disconnect this wire and ground it to the engine. Turn on the ignition switch and the indicator light should light up. If it does, replace the neutral switch. If it doesn't, you've got a wiring problem between there and the indicator lamp.
Good Luck
May 31, 2011 | Harley Davidson FLSTC - FLSTCI Heritage...
How do I reset the change oil soon message in my 1998 Chevy Lumina after changing the oil?
This is done by turning the key on engine off and fully pressing the gas pedal to the floor sloowly three times within 5 seconds, the light will blink and go off then turn the key off for 3 sec and start engine, light should be off if not repeat steps. hope this helps.
Oct 27, 2010 | 1999 Chevrolet Lumina
The power light (bright blue) on my Olevia 26" LCD burns brightly in my bedroom ALL DAY and ALL NIGHT. Is there anyway to dim it?
Had the same problem and took the easy way out: I cut a small piece of electrical tape and covered the LED. There is no way to dim it.
Dec 23, 2009 | Olevia LT27HVX 27 in. LCD Television
Bright indicator on dash on when lights are on. Dim or Bright.
could be light from a separate source. Try turning off the instrument lights and try hi/low again. If you still see the light on both hi/low, it could be in your control arm(turn signal indicator).
Nov 16, 2009 | 1999 Plymouth Grand Voyager
Garmin 530 doesn't turn on
if the light goes off it would indicate that the battery is fully charged.
does the unit function like a phone when charging as in showing a chg indicator even if it is off? If so there are more serious issue than maybe just a bad power switch.
Oct 22, 2017 | Garmin Rino 530 GPS Receiver
Can you turn off the power indicator (Vizio logo) light. It is very bright and is in our bedroom
I just placed a piece of black electrical tape over the logo.
Problem easily fixed.
Oct 07, 2009 | Televison & Video
Panasonic KX-TG1033S Cordless Phone Logo
69 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
