Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
Can't turn off answering machine or change from 2 rings.
We have voice mail and do not want the answering maching to answer. The answering maching is picking up after 2 rings even tho it is set at 6.
Can't find owners manual.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download the manual.
Posted on Dec 02, 2012
  • kakima Dec 02, 2012
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Posted on Oct 19, 2008
SOURCE: Voicemail picks up too soon and New voice mail message always on
Check call waiting feature with mobile provider on number of rings to voice mail. Many problems repaired with booting phone (holding on/off button down till screen logo comes on & removing charged battery cleaning contact connections on phone and battery with DRY SYnthetic NOT cotton cloth ideally clean battery with alcohol swab let dry before returning to phone
Posted on Aug 07, 2009
  • 34 Answers
SOURCE: we donot subscribe to voice mail,but every time a
contact your phone co
Posted on Nov 16, 2009
consultel1
  • 860 Answers
SOURCE: dont have a problem I am looking to by a VTech
Yes, there is an on/off for the answering machine portion of the phone. On default it's set to off til you set your settings and record your greeting.
Posted on Dec 15, 2009
micromatikal
  • 2777 Answers
SOURCE: we can call out but
Very strange, when someone calls in, even though it doesn't ring, can you answer it? If you have called ID enabled does it indicate that someone is calling?
Give me a bit more info here and I can definitely help, thanks!
Tim
Posted on Oct 22, 2010
DON'T NO WHY MY ANSWERING MACHINE IS NOT PICKING UP MY CASLLS
You need to program the internal voice mail to pick up calls after 6 rings , or program your answering machine to pick up sooner, perhaps 3 or 4 rings.
Mar 02, 2015 | Panasonic KX TG4021 Cordless Phone
Voice Mail
go iin option under ringers cheak to see whats its on before voise mail picks up 1 3 6 10 ? isnt it in the optimns menu or if u have seprate unit for voise mail cheak setting on that beofre it grabbs the call does that help
Jan 07, 2008 | Lucent 1872 Corded Phone
Why won't the answering machine, when set to 'answer on' not record a message?.It goes to voice mail. Is my machine defective?
Maybe the answering machine is set to pick up at say"5 rings" and the voice mail is set to pickup at "4 rings" . Change the voicemail setting to a higher setting than the answering machine. That may be the problem.
Aug 26, 2014 | Lands Phones
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
Fax won't answer
If you have an answering machine connected to the same line as your fax:
If you have a voicemail feature associated to the same line as your fax:
I hope this helps.
Should you need further assistance, please contact Lexmark Technical Support Center.
Feb 14, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Even though my answering machine indicates it is on, noone can leave a message.The response is that the mailbox has not been set up.Can you help? Thank you.I have had this system for quite a while and have...
A "mailbox not set up" message is coming from your telephone line voice mail system, and not from your telephone answeringmachine. What this means is that the voice mail on the phone line is picking up before the answering machine has a chance, and since the mailbox hasn't been set up it can't take any messages. So there are two things you'll need to do.
First, you'll need to set up your voice mail. You may need to contact your telephone service provider for setup instructions since not all systems are the same, but here's how it usually works. From your home phone, call your own number so you reach your voice mail. You should get the message that your mailbox hasn't been set up, and will be prompted for an access code to get to the setup menu. The access code is usually the last four digits of your phone number, and you'll be prompted to change it to something else as part of the setup. Through the setup main menu you can record your greeting and set up other options like the ring count before the voice mail answers. Set it for a number larger than the setting on your telephone answering machine. (I have my answering machine set to 4 rings, and voicemail set to 6.)
Step two is to verify the ring setting on your answering machine. Four rings is a common default setting, but it's adjustable on the phone. Most newer phones have menus that you access from the handset to set change settings, while older models have a switch on the base unit.
Once the mailbox is set up and you have your answering machine set to pick up first, everything will work as you want.
Aug 14, 2011 | Uniden DECT 6.0 Cordless Phone
Can I change the ring count for voice mail to three instead of 2 or 4 OR6
Sorry you cannot set ring count for voice mail to 3.
It has settings to set for 2,4 and 6.
Thanx
Jul 04, 2010 | Uniden TRU8885 Digital Answering Machine
Machine is picking up after 2 rings with man's voice.
problem solved, grandkids used other phone with answering machine and left it in different mode "7" so it was picking up after 2 rings...thanks for answering my request.... solution solved... Thanks, Netta
Aug 07, 2009 | Casio TA-111 Digital Answering Machine
Set number of rings before answer machine pick up
From the main menu select the Voice Mail option in Voice mail select Ring Delay in Ring Delay you can choose the delay time before Answering Machine pick up the phone from 0 to 30 secend.Reza from Iran
Oct 01, 2008 | Siemens Gigaset S455 Cordless Phone
Number of rings
It should be under Menu, 2. Set up recieve, 1. Ring Delay.
You will have upto 10 rings.
Feb 19, 2008 | Brother IntelliFAX 885MC Plain Paper...
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
129 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
