Question about KitchenAid KHTU100KSS Kitchen Hood
Hood fans not working, but lights do.
I have a kitchenaid hood that won't work. The lights work, and when I put it in, I put a screw through two wires. I have fixed the wires internally, but now I get no response. when the wires were hit, it would blow the circuit like it should, but now I get no response at all. a little red dummy light comes on around the connections of the switch?
Thanks,
-Matt
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: hood fan not working, but lights do.
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Hood lights not working
Faulty switch for the lights? Measure the voltage in the lamp sockets - if you don;t know how, find someone with electrical experience to check it out.
Nov 21, 2013 | KitchenAid KHTU165RSS Stainless Steel...
KWCU405SSS fan motor high speed only
Agreed! It totally works. Our fan and lights were stuck on high. Flipped the hood circuit breaker off for 30 seconds then back on again and all controls are working normally again. Thanks!
Jan 15, 2013 | KitchenAid Architect® II KWCU405SSS...
1993 buick park avenue heater won,t work.checked all fuses an relays
i beleive you did more than that.? you,ll probably find all have a common earth , chech and remove it , clean with a wire brush and replace, also chance the fuse you removed and replacer reguardless of it,s appearence , ensure its put back in the correct location,peter.
Sep 03, 2012 | 1993 Buick Park Avenue
KitchenAid KHTU160KSS Kitchen Hood makes noise
Remove the fan and motor assembly from the hood (the fan motor will plug into the hood housing) and using an electrical motor cleaner (such as CRC electrical motor cleaner available from your local auto parts store) wash the motor and fan as completely as possible, lubricate the end bearings (sparingly) with a very light oil such as sewing machine oil, gun oil or as a last resort 3 in 1 oil. Hope this helps.
Dec 14, 2011 | KitchenAid KHTU160KSS Kitchen Hood
Our Kitchenaid Range Hood model KWCU405SSS has a code "C" in the display. What does that mean?
I just did this and it works.
1.) Make sure to turn off both the fan and the lights. If you skip this step the next step won't work.
2.) Press and hold the + button for 4 seconds until the "C" disappears.
Repeat in another 100hrs of use.
Mar 19, 2011 | KitchenAid Architect® II KWCU405SSS...
Hood fan works but displays the letter "C" ?
wow! finally the solution that works! Holding the '+' sign for 4 seconds. We had our vent replaced by kitchenaid once and were about to call again and complain since our new one did just the same thing without resolution using the 'H' button as indicated in the manual! Thanks for help it's so appreciated!
Feb 22, 2009 | KitchenAid KWCU205HSS Kitchen Hood
Hood fan not working, but lights do.
Jan 02, 2009 | KitchenAid KHTU100KSS Kitchen Hood
Kenmore elite ranghood (series# 550) not working
unplug the unit and unscrew the bulbs. put 2 new in if they still dont work then you may have fried the control. there are usually no fuses between the control and light/fan. well i never saw a fuse between the 2.
Dec 07, 2008 | Kitchen Ranges
Removing the fan
most fans dont come out. but it is not hard to take the hood down. there are most likly four screws in the top going down into the hood. undo them, making sure the hood is proped up. them is should just lift out of the backing plate and there is your bird. to put it back up just put it back on the backing plate then put the bults back in and make sure the vent is on properly.
Jun 18, 2008 | KitchenAid Pro Line KWCU360JSS Kitchen...
KitchenAid KHTU100KSS Kitchen Hood Logo
41 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
