Question about Vizio VP422 42 in. Plasma TV
Visio vp422hdtv10a,relay clicks twice,visio logo is amber,have stand by voltage of 5.3v
Ckecked all fuses,ok checked all capacitors,visually ok,has a micon board with a flashing green led,flashed 2 times. (D5V / VG / A12V) but now is on steady.tried pressing ch+ and ch- and then power on nothing. on power supply PS ON voltage is .494vdc AC detect volatge is 5.18vdc and 5VSB is 5.3vdc.
3 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: when I plug in the power, my vizeo logo
This problem indicates that your power supply is faulty it produces dc supply but not enough to transfer other parts. The cause of this is the capacitor or the transistor. If your power supply has a bulge up in the top of the capacitor or not perfectly flat like the others you should replace them because it cannot filter the dc supply and low dc output. Next is the driver transistor if they are leaky it will do the same problem to your power supply. try to test the small transistor beside the regulator. I hope that this may help you regards.
Posted on Jul 10, 2011
jdvillanueva
  • 2098 Answers
SOURCE: Amber Visio light comes on
Hi dezrl,
Check the fuse on the y-sustain board. If you they are open replaced it with same current(ampere) ratings and try again if the symptoms still there. Check the voltages at connector (P3). Let me know the reading to asssist you further.
Jdvillanueva
Posted on Aug 07, 2011
Hi I have a Visio e420-VSE 42" lcd tv. I have no back lights, no logo lights up but it does have sound. Getting voltage out when testing stand by to the main board. No burn marks or bad capacitors
Check your 24 volt line that goes to the inverter board, if that is good then replace the inverter if its not good replace the power board
Jan 24, 2018 | Televison & Video
Visio Model E470i-AO TV power and sound work, but no display. Display will come on after TV is off for over 24hrs. Display will go black after a couple of minutes.
I would look at the power supply voltages for starters, make sure they area all ok, also visually check the capacitors for bulging
Dec 06, 2017 | Televison & Video
How do I repair my Vizio VP422HDTV10A?
What have you done to address the issue? Confirm that power is reaching the PS? if there have you replaced the PS or made repairs to it?
Unless you make specific inquiries you make it difficult if next to impossible for anyone to help you. Keep it up and all you will have is a big, wide paper weight.
Mar 12, 2016 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My LG Plasma TV will not power on.
- You still have an problem on the power supply, most likely one or more other capacitor that are bad but can only be verfied with a capacitor checker. They may not show any signs of damage or bulging but still internally damaged.
-may be more time savings to just replace the entire power supply
Jun 24, 2015 | LG Televison & Video
I have no headlights or tail lights..but my fuse isn't blowen on my fireblade what could it be?
could be several faults, use a volt meter to do the following ,check for battery voltage at the headlight switch. if ok switch on and check voltage on other terminals, if ok check voltage on headlight relay, some relays have a fuse check, the relay should click when turned on, check voltage on relay terminals going to head lights, if ok check voltage at headlight bulb holder, if ok check bulb filament.
May 21, 2015 | Cars & Trucks
Dead set toshiba mod. no. 52xv540u no bad caps,no clicking,no led lights on front
Hi, First check that you have good power coming in from plug.
If that is good check out power board (capacitors Bad) replace if oozing out or bulging out. If you are good with soldering then do so.
Replace with same capacitors or better ones.
Jan 13, 2014 | Toshiba 32AV502R LCD TV
I have a Vizio VP422HDTV10A tv that is dead. My local power company dropped a power line on the one leading to my house and tv has not worked since. When I plug the tv in, I can hear the relay click and...
this tv was working well but allof saddent one day it was rainning then it black out just like that the n i took to technician and diagonise it the told me it was the integrated circuit foulty number 2A10709 HELP with thsolutions.
Sep 11, 2013 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Visio VP504 fhdtv10a - When I plug it in, it has an amber logo light and makes a click noise (like a relay). When I press the power button nothing happens.
These are problems gradually developed in TV over the years. You may have to look for any dry solder, change the capacitors that look 'puffy' and try.
Jul 30, 2012 | Televison & Video
Vizio VW37L no power
Check for bad capacitors in power supply, check voltages coming out of the power supply, if voltages are good, bad main board.. Vizio's are notorious for bad main boards.
Nov 23, 2011 | Vizio VW37L 37 in. LCD HDTV
Vizio VP422 42 in. Plasma TV Logo
56 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
