Question about Linksys Wireless-G WRT54GS Router (e125894)
I need help with my Xbox forwarding setup - Linksys Wireless-G WRT54GS Router (e125894)
  • 88 Answers
First you need to go into your router, get on your computer and type in 192.168.1.1 this will take you inside the router, go to gaming and applications. Go to port forwarding, enter the name xbox open the ports
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • Find out what the ip address of your xbox is set at, this is done in the xbox control panel. Open up those ports to that ip address of your xbox. you will probably have to enter more than one entry for all those ports, make them x1, x2,x3 an so forth. save settings. and then go to your xbox and try to get online.
    Here is a link that might help more.
    http://support.microsoft.com/kb/908874
    Posted on Jan 09, 2009
    Xbox360 live setup
    You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
    • Port 88 (UDP)
    • Port 3074 (UDP and TCP)
    • Port 53 (UDP and TCP)
    • Port 80 (TCP)
    You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
    Listed ports need to be forwarded when connecting to XBOX Live
    A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
    Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
    I got a Motorola wired modem and it dosn't let me play xbox live why?
    you may have to open a port that you xbox can use to connect to xbox live
      • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
      • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
      • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
      • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
      • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
      • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
      • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
        TCP 80
        UDP 88
        UDP 3074
        TCP 3074
        UDP 53
        TCP 53
        Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
      • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
    Jun 04, 2011 | Video Game Consoles & Games
    How do I get two xbox 360s to have an open NAT on a Cisco Linksys WRT160N V2 wireless router?
    you need to setup both your xboxes with a static IP address for example
    192.168.1.50 xbox 1 192.168.1.51 xbox 2
    on your linksys router you will need to setup port forwards for both xboxes
    Click the Applications & Gaming link near the top of the page.
    You should now see a new menu. In this new menu, click Port Range Forward.
    requires you to forward the following ports: 53,80,88,1863,3074
    Mar 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
    I'm trying to play my xbox, and the message keeps saying to go to the router configuration web page to make sure port 3074 is open in my firewall... But I can't find it anywhere, the port OR the web page.
    You have to go to the router setup page and go to port forwarding menu. Forward means "open" in router terms. So just forward the ports you need so your xbox will be able to communicate to the internet via the router.
    Feb 07, 2011 | Computers & Internet
    I have a BEFSR41 Lynksis router and when i try to connect to xbox live it tells me my NAT type is Moderate and it should be Open. How do i change it to Open?
    Xbox LIVE has default ports that needs to be forwarded on the router.
    To forward the ports, access the setup page of the router. In your internet browser's address bar type 192.168.1.1.
    Leave the username blank and then the password is admin.
    Go to the Applications & Gaming tab, click Port Range Forwarding.
    In the application field, type XBOX LIVE.
    Start End Protocol
    53 53 Both
    3074 3074 Both
    80 80 TCP
    88 88 UDP
    In the IP address field, type the IP address of the XBOX. Check the enable button. Then save settings.
    Sep 26, 2009 | Computers & Internet
    I have an ativa router and i need to open the nat on it so i can connect to other ppl on xbox live.
    You must access the router's setup page and look for port forwarding feature. There you can open the port for xbox live. Go to portforward.com for more information on how to do port forwarding
    Jun 10, 2009 | D-Link Xtreme N DIR-655 Wireless Router
    Change NAT from strict to open
    You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
    Jun 01, 2009 | Zyxel P660HW-D1 Router
    Network address translation [nat]
    Depending on your router, you will need to go to its setup. Go to the link where you can forward ports. (Port range forwarding). Then you will enter the information that you recieved when you called Xbox Customer Support. (Call them for it, it is free) Enter the information and you will be good to go.
    Jun 23, 2008 | Microsoft Xbox 360 Console
    Xbox live connection: My NAT
    its likely your router needs to have port forwarding setup on it, or you could try setting up your Xbox ip address as a DMZ on your router.
    however some routers simply wont work, I had a voyager 105 using port forwarding but it still never worked till i changed to a Draytek
    post more details of your router and what you have tried.
    also you cant go far wrong visiting here
    http://www.xboxlivetheguide.co.uk/XBoxLiveTheGuide2.php?department=Home
    Mar 10, 2008 | Microsoft Xbox 360 Console
    Xbox live NAT
    Has your Xbox IP changed any?
    Your on a DHCP right?
    Oct 19, 2007 | NetGear WGR614 Wireless Router
    Linksys Wireless-G WRT54GS Router (e125894) Logo
    67 people viewed this question
    Top Linksys Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
