Question about Sony FWD50PX2/S 50 in. Plasma Television
Sony fwd50px2/s hi I would like to know what kind of audio cable do I need to connect input 1 or 2 of the plasma to the cable box. input 1 is dvi connexion and input 2 component (pin). thank you
The sound went out on the tv
Posted on Dec 23, 2009
  • 4 Answers
The monitor should have come with several cables and adapters. One adapter converts the stereo RCA plugs to a stereo 1/4 inch plug that connects next to the dvi outlet.
Posted on Dec 14, 2007
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I want to hook up a blue ray dvd player they told me to m=buy HDMI cable and this only goes to the tv, but doesn't have to go hooked up through the cable box
If you want to connect your blu-ray player to your tv, use the HDMI cable.
If you want to connect your cable box to your tv, I'd use component cables or get another HDMI cable.
You're right, you don't have to use your cable box to use your blu-ray player.
Mar 10, 2011 | Insignia 50 in. Flat-Panel Plasma HDTV
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
Where is the HDMI cable connection port?
This model has a DVI connection. You will need to install a cable as shown. This will only carry the video. For the audio, you will need to use a pair of RCA cables, the same as those which are used for all other connections. Theses connections are located on the back of the TV, along with the cable RF jack. The DVI connection is normally the last input (ex: input 6 or 7).
Mar 15, 2010 | Sony WEGA KE-37XS910 37 in. HD-Ready...
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
HDMI to DVI-D conversion problem. Not in compliance?
It souunds like te TV is having problems with the streaming data being applied Most plasmas with DVI connections were actually designed for PC type input signals  Unfortunately the TV's input may not be able to stand up to the stream of signal the DVD or cable box wants to display. You can try and lower the output of both devices to 720P Good luck to you
Feb 17, 2009 | Televison & Video
Wgere are the video outputs at on the sony fwd50px2/s 50 plasma
Tv's usually do not have VIDEO outputs, some have audio outputs so you can connect to a reciever.
Do you need help with a connection? Let us know what you are trying to do and I will be happy to help.. lone99star
Jan 21, 2009 | Sony FWD50PX2/S 50 in. Plasma Television
No audio on pasma when cable set box set to certain channel
In that case two things might be happening. 1. HDMI/DVI cable you using might be faulty you want to change that or 2. The HDMI input of your TV set might be the problem. I will suggest you use component cable instead, I am talking about the 5-color-coded (green, blue, red and red/wihte) cable to connect the set top box to your TV.
Jun 15, 2008 | LG 50PX4DR 50 in. Plasma TV
Hdmi/dvi
Here is the link to the user manual for the TV if you need it; http://www.haier.com/admin/en/product/upload/42EP24S-UM.pdf Check page 7 - The DVI input has next to it an audio input - DVI does not carry audio as HDMI does - you need to plug a seperate mono audio cable from your cable box to the TV at the DVI Audio input (top of page 12). The Audio needs to be in the one next to the DVI socket in order to work at the same time as the picture from the same "source" selection. Check page 18 "CATV Type" and make sure this is set to the correct one for your cable box Check page 21 that all the audio settings are logical and nothing is turned right down or muted. If none of this helps then please post back. What make and model is Your Cable box? Hope this helps :)
Aug 21, 2007 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Sony FWD50PX2/S 50 in. Plasma Television Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
