Question about AT&T BlackBerry Curve 8310 Cell Phone - Red
Camera doesnt work or bluetooth
Blackberry 8310...camera says close other applications before entering when all other applications are closed. the bluetooth is disabled and when i click enable it stays disabled.
  • 2,359 Answers
This is the initial sign of the camera coming loose from the socket on the main board.
If it still in warranty then send it out for repair.
If it's out of the warranty then you can put a foam or plastic spacer to under the battery cover.
Just like the battery foam pad under the battery cord to give it firm support.
Place few tab of supporting material under the battery cover. Make sure they does not cover the lense or the flash.
Next time the camera give you the error message again or ghost like image.
Take the battery out and press the camera and flash area firmly until you hear a soft plastic snap sound.
YOU MAKE HAVE TO DO THIS MANY TIMES
Once the camera contacts snap back in place then your are back in business.
Do a firmware update from Blackberry.com support page should fix the bluetooth problem.
It's a 15-20 minutes job, Once you start,it CAN NOT abort.
Posted on Sep 19, 2009
BlackBerry 8310 when i open.could not start the camera.Close other applications and try opening the camera again. plz tell me soon whats i m doing
It's basically a memory issue. You need so much available memory for the phone to operate, to run the camera and to store the pictues. Have you changed anything about the phone between the time it worked and when it stopped working? How many emails and txt messagess have you stored on the phone? Check the phone status (menu, options, status) for free memory... recommendation is a minimum of 8-10 MB. I'd also suggest getting a memory card (transflash/micro SDHC).
Check out Blackberryforums.com... there is an excellent sticky in the main section about freeing up memory - removing applications and features that you do not need/want/use to free up memory. Typically, I have about 28MB free plus a 4GB SDHC memory card.
close all apps out also
Dec 05, 2010 | RIM BlackBerry Curve 8310 Smartphone
My blackberry curve can't open the camera cuz it says to close an application that is open. I have gone through all applications one by one closing and it still says the same thing.
The camera module pops out of its socket.
Power off the Blackberry
Open the rear cover of the Blackberry
Remove the battery
Apply GENTLE pressure around the camera
Press around the lens and listen for a POP noise.
Place the battery and cover back and test the picture and camcorder mode.
If you see the pic by distored pic on the LCD then you are half way there!
Please RATE my answer if it's useful to you
Thanks
MUSTGO
Nov 18, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
BlackBerry Curve 8310 camera doesnt work it says close other applications
Download the newest firmware upgrade from Blackberry. In addition to a couple of new apps (movie mode and voice recorder), it should take care of your problem. Of course, this is all free.
Oct 30, 2009 | RIM BlackBerry Curve 8310 Smartphone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My blackberry 8310 camera won't come on, it says close all applications then try again, but i dont have any applications opened. i dont understand
First of all take a backup of all the important data on the handset and then try reloading the OS if this does not help then get in touch with the service provider.
Aug 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
Camera wont work, wants me to close apps and try again
Sounds like you may have a corrupted java system. Try to reload the OS by going to the Blackberry.com website, an downloading the desktop manager 4.7 fairly large, as well as the Blackberry device software. Depending on Carrier it should be the 4.5 version. Install the desktop manager, then install the handset software. Plug the phone in let it detect the settings, and then use the application loader to reload the handset software. It will back up your settings, and applications, and restore them once it's completed.
Jul 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
My camera is not working/ black screen.it tells me to close apps
Alright, I just had this problem. I dont know how this happened, but some settings were changed. If you go to media and press the menu button then go to options. Now change device memory limit to 15mb and reserved picture memory to 2mb. Now try your camera, it worked for me.
Jun 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
My camera on my blackberry curve is not working.
when i try to use the camera on the blackberry 8310 it tells me to close other application, how can this be fixed
Jun 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
My Blackberry 8310 curves camera won't open
OMFG lol!. I just saw this on pinstack.com
My camera had hte same problem for months and this just fixed it!!
1)Remove back cover
2)Press gently, but firmly on lense (you should hear a click)
3)Battery Pull
Apparently if dropped at all, the camera can shift!!
Cheers, Imma go take some pictures after months of not being able to!
Jan 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
AT&T BlackBerry Curve 8310 Cell Phone - Red Logo
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
