Question about Garmin Nuvi 660 GPS Receiver
Nuvi 660 fails to get satellites, resets don't help
HI JIM,
I'M USING ALL CAPS SO YOU CAN READ MY RESPONSES TO YOUR INSTRUCTIONS.
WE HAVE FOLLOWED YOUR ADVICE FOR RESTORING SATELLITE RECEPTION BELOW, TO NO AVAIL. WE GET THE ETERNAL MAP OF GARMIN HEADQUARTERS UNTIL THE UNIT TIMES ITSELF OFF, AT LEAST 30 MINUTES LATER.
(BTW, WE DID ALREADY DOWNLOAD THE LATEST SOFTWARE)
There are a few things you can try to restore satellite reception.
1. place your finger over the lower left-hand corner of the screen and hold it there while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites.
It will however, erase any corrupted satellite data and will default you back to some factory settings. This will clear some of the memory allowing your Nuvi to collect new satellite data. Your Nuvi should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings. Make sure the antenna is up and that you are outside. On the main screen, you will see a satellite bar graph in the upper left-hand corner. Touch the bar graph and you should get a satellite map, showing the satellites. If your Nuvi's receiver is working ok, you should see horizontal hollow bar graphs appear on the right. Eventually they will turn
solid blue. This indicates they have downloaded the proper data from the satellite. When you have (4) solid blue horizontal bars (4 satellites), you will see the top panel begin to show improved accuracy and your Nuvi will then work as it should. This entire process make take 30 minutes or less.
If you don't see any bar graphs, your Nuvi may ask you several minutes later, if you are indoors. If your outside, select no. It will then ask you if you have moved 1000 miles since your last use. Select yes. This will cause your Nuvi to start looking for satellites, trying to locate your new position. When you perform a factory reboot, your Nuvi thinks it's in Kansas (Garmin HQ) and so it needs to be told to look for new satellites.
Now, if you still don't see any bar graphs, then your antenna may have a problem. There Is a known issue with the Nuvi antenna where a part has failed, causing the Nuvi to no longer use its internal antenna and it's now always looking for an antenna at the external antenna port (the gold connector on the side of the Nuvi antenna). If you have a piece of small wire, a couple feet long, you can insert that into the center lead of the
external antenna jack. Most likely, you'll begin to see bar graphs after a few minutes
and your Nuvi will lock.
WE DID THE WIRE CHECK AND IT DID NOTHING
Here's another way to determine if your antenna has failed and will have to be replaced: At the main menu, pres on the "wrench" symbol. Then press the "gear" symbol and then press "about". There is a field marked "GPS S/W". There should be a number next to it. It may be "2.9" or "3.0". That is good. That tells you that the main board in the GPS is communcating with the antenna receiver.
WE DID THE CHECK AND IT SAYS 3.0
Please let me know if I can be of further assistance to you.
- Jim
PLEASE GIVE US SOME SUGGESTION HOW TO GET THIS $800 TOOL TO WORK AGAIN. THIS IS THE SECOND ONE THAT FAILED, FIRST ONE WAS DURING WARRANTY, THIS ONE IS BEYOND THE 1 YEAR WARRANTY SO GARMIN JUST WANTS US TO SEND IT IN WITH $225.
THANKS, ANXIOUS TO HEAR FROM YOU
ELLEN
  • 4 more comments
  • Ellen Ransom
    Ellen Ransom Jan 05, 2009
    Where does one buy flip-up antena assemblies?
  • Ellen Ransom
    Or will an external antenna solve the problem?
    I did a search but could not find a place to order a new antenna assembly. Are they difficult to replace?
  • Ellen Ransom
    Ellen Ransom Jan 09, 2009
    I ordered an external antenna and it did indeed fix the problem, so we must not have had the wire placed properly when we tried that test. An antenna costs about $25, much better than Garmin's $225.
  • harleyday May 05, 2009
    1. Failed - Experienced failure to acquire satellites from my Nuvi 660 after 2 years usage.
    2. Failed - Updated the firmware to version 4.7 without restoring satellite acquisition.
    3. Failed - Applied the maintenance reset procedure as described without success.
    4. Succeeded - Tested satellite acquisition by inserting a single strand of approx 24 gage wire (about 12" long) into the antenna jack and was able to acquire satellites almost instantly.
    5. Called Garmin 800-800-1020. Their solution, give us $110.00, obtain a return authorization number and send my Nuvi 660 to them to be fixed. My 660 would receive a 90 day warranty.
    6. My solution: I ordered a new Garmin Nuvi 660 010 00540 00 Gps Antenna from Biznet.com at a cost of $10.99 – URL: http://www.bitssite.com/garmin-nuvi-660-... This antenna is designed for external use, but fits nicely on the dash of my car with the wire lead tucked neatly beneath the dash.
    7. Conclusion: Garmin Nuvi 660 internal (flip-out) antenna is a known product fault. Considering the high initial cost of a Nuvi 660, Garmin is not acting responsibly with their $110.00 return program. Customers should only be required to pay the shipping to have the unit repaired.
    8. My long-term solution (after having purchased or influenced the purchase of at least five other Garmin GPS units), buy Tom Tom next time!
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Hi Ellen,
    If the wire didn't help, then an external antenna won't help you.
    The antennas are not hard to replace but involve taking your Nuvi apart and you need the right tools to do it.
    I've received numerous emails from people who have damaged their Nuvi by trying to take it part.
    Try this link for more help. Too much info to cut and paste here
    http://www.sharc.net/nuvi_antenna_repair...
  • SHARCNET-USA
    Hi Ellen,
    It sounds like you need a new flip-up antenna assembly.
    - Jim
    SHARCNET-USA
Iwas able to "fix" my Nuvi 660 by simply jumping the external coaxconnector to the internal antenna. The fix is detailed by ernesas here:
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=114405&whichpage=2
Heincludes a photo of the circuit board with instructions. (Note that itis the second photo on the page, not the first one!) The downside tothis quick and easy fix is that you will probably lose external antennafunctionality. I never used an external antenna so no big deal.
Posted on Oct 20, 2009
  • Garmin Master
  • 2,130 Answers
Glad to hear you got it working Ellen. Please rate my solution & assistance if you found it helped you resolve your problem.
- Jim
SHARCNET-USA
Posted on Jan 09, 2009
    Scholar:
  • 40 Answers
Try this and see if it fixes your problem...first disable bluetooth then follow these steps.
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the problem.
Will not aquire satellites
This is a common problem on the Nuvi 3xx and 6xx series and is caused by a failed component. Please see this link for troubleshooting information.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Nov 23, 2011 | Garmin Nuvi 660 GPS Receiver
I have garmin nuvi 660 sometimes my screen is not responding at all and my battery is not charging. what is the solution.
Please see these links:
http://www.sharc.net/gps_LCD_repair.htm
http://www.sharc.net/gps_battery_repair.htm
Don't try to fix these problems yourself. Read some of the failed repair attempts on this site.
Take it to a professional.
- Jim
Sep 11, 2011 | Garmin Nuvi 660 GPS Receiver
Trouble acquiring satellite
Please see this link:
- Jim
May 23, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 shut itself off and will not turn back on
Hi Sherry,
The unit should not get warm, unless the battery was fully discharged or maybe shorted out. Most likely a part has failed on the main board.
Please see this link about a Dead Nuvi:
http://www.sharc.net/gps_dead.htm
- Jim
Mar 10, 2010 | Garmin Nuvi 660 GPS Receiver
Lost satellite connection
Please see this link for more information on this problem. Too much info to cover here:
- Jim
Aug 05, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 touch screen freezes up. Soft
I sat on the phone for 30 minutes waiting for Garmin support when my Nuvi suddenly had no touch screen response. They had me delete a file on the device (with it hooked to my computer) then reboot and it went thru a touch screen alignment and it worked.
Sadly, it has frozen again and I don't recall the file (it had been a GCD file in all caps, that is all I know and I don't see a file in all caps any more). I will be calling support tomorrow.
My take is that it *is* a firmware thing *and* there is some way to reset the firmware.
May 01, 2009 | Garmin Nuvi 660 GPS Receiver
Gps garmin nuvi 660
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Oct 26, 2008 | Garmin Nuvi 660 GPS Receiver
My Nuvi 660 powers on but fails to locate satellites. I have updated the machines but alas no workie. Please help
Best wishes,
- Jim
Oct 22, 2008 | Garmin GPS
Intermittent satellite loss after upgrading Maps to the latest NA version.
same problem after updating type G GPS firmware 2.90 to 3.0..
Feb 08, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
1,410 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
