Question about Poulan Pro 25CC 2Cycle Gas Blower
Can I use AMSOIL Interceptor synthetic 2 cycle oil as mix at 40:1 in my poulan pro 25cc leaf blower? (type . API-TC.JASO FC)
Can not locate any Poulan Synthetic Oil like the product included with the blower when I purchased it.
5 Suggested Answers
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
  • 252 Answers
SOURCE: what type of oil does
use - husqvarna , sthil brands high quality 2 stroke oil
as directed on bottle 50:1 that is 20 mils of oil for every 1.0 litre of petrol that you use
if you want 2 litres mix put in 40 mils of oil into petrol container
then put in 2 litres of petrol only and give good shake and fill the blower
cheers
Posted on Sep 01, 2010
#1 Taper
  • 1040 Answers
SOURCE: wanted to know the 2
40:1 3oz. of cycle oil to 1 US Gallon of gas.
Jim
Posted on Aug 11, 2011
2strokeJim
  • 577 Answers
SOURCE: I need to know the setting between the coil and the flywheel on a poulan 25cc 2 cycle leaf blower?
thickness of a bussiness card
Posted on May 23, 2012
My blower poulan pro BVM210 was running good and then just stop and cord got stuck. what`s wrong with it?
if your saying that motor was running then shut off and now the motor wont turn over with pull cord , then you might have a frozen motor , this mostly happens when one runs a two cycle engine on an improper fuel/oil mix , if this happend there is only a slim chance that engine can be saved by a qualified service tech , but there also is other reasons as well that an engine could freeze up , again a service tech would know for sure
Mar 10, 2015 | Poulan Pro BVM210VS 25CC Gas Leaf...
What type of oil is used for my 2055 2.O CI woodsman chain saw?
This engine is certified to operate on unleaded gasoline.Before operation,gasoline must be mixed with a good quality synthetic
2-cycle air-cooled engine oil designed to be mixed at a ratio of 40:1.Poulan/Weed Eater brand synthetic oil is recommended.Mix
gasoline and oil at a ratio of40:1.A 40:1ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline.
As far as bar and chain oil:
Genuine Poulan R bar and chain oil is recommended to protect your unit against excessive wear from heat and friction.Poulan R oil resists high temperature thinning.If Poulan R is not available,use a
good grade SAE30 oil. Never use waste oil for bar and chain lubrication.
Oct 20, 2014 | Garden
What is mixing ratio for weedater
The ratio is generally 40 to 1. That is all I have ever used. It depends also though on the quality of the oil you use. Synthetics can use a different ratio than mineral oils.
Sep 19, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What oil goes in crankcase of poulan leaf blower
Are you sure this is a four stroke engine, i thought all the small blowers were two strokes in which case there is no oil in the crankcase, the lubrication is mixed with the fuel
Feb 19, 2013 | Poulan Bvm200vs 200mph 25cc Gas Pro Leaf...
New poulan pro 25cc chokes out after if I give it full throttle. Runs ok except it wont stay running on full throtle.
I find with my Poulan Pro that you need to let it warm-up abit before applying full throttle, I live in Upstate NY where the weather has bee great lately,however, it stalls easy ..I mix 1-pint of 3 stroke oil to 1-gallon of gas for my weed eater and have no problem
Nov 05, 2011 | Poulan 25CC Gas BlowerVac
Dont know what the oil gas mixture is suppose to consist of
Your manual (from Sears) states that your mix ratio is 40:1. You will need 3.2 ounces of Poulan "Pro" synthetic 2 stroke oil mixed in 1 U.S gallon of gas or you can mix 1.6 ounces of the oil in a half-gallon of gas. They suggest using the Poulan "Pro" brand synthetic oil. I do also. Synthetic oil significantly reduces wear, allows the machine to run cooler, and burns cleaner with less by-products and emissions. You can view a PDF file of your manual here:
http://www.managemylife.com/mmh/owner_manuals/133702/POULAN-Blower-Gas-1009868L?brand_name_search=952711923++
May 01, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
How do u mix the 50/1 ratio oil and gas mixture
Mix 2 1/2 oz of 2 cycle oil into 1 gal of gas
Nov 25, 2010 | Poulan 25CC Gas BlowerVac
What type of oil does the poulan pro BVM 200 EL use and is the gas:oil ratio 40:1?
cheers
Sep 01, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a Poulan Pro Leaf Blower, Model No. BVM200VS. (25CC). What is the spark plug gap and also, what is the mixture for the gas and oil? Thanks! Bob
Oil to gas.
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
Plug gap
0.025 inch (0.6 mm)
Or you can get the manual on the link below.
http://www.mowersdirect.com/manuals/BVM200VS_Man.pdf
Good Luck and please rate 4 thumbs up for free answer
Jun 13, 2010 | Poulan Electrical Supplies
Poulan Pro 25CC 2Cycle Gas Blower Logo
35 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
