Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
New refridge i just brought a new whirlpool side by side how long does it take to get the ice maker to make ice and what temperature sould be on
  • 37 Answers
The book says it can take 24 hours to start making ice, but normally only a couple of hours. Make sure the you have water coming to the fridge, then check on any warranty. Your fridge has a energy recomended setting that will be fine.
Posted on Jan 03, 2009
Have installed a new ice maker, it still will not work.
Soulds like the your model has a electronic eye that monitors the ice level has failed. Page 6 in the Click Here=> GD5SHAXKQ00 Parts List Location number 38 is the 2198585 Ice Level Control Board
Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here should you have questions, Thanks Sea Breeze
Apr 15, 2013 | Whirlpool GD5SHAX Side by Side...
Freezer is icing up we have already vacuumed the vents in teh front and the back of the refridge and it is still icing up
Hello, This is a common problem, the first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35-42 degrees.Here are some things to try:
  • If your refrigerator temperature is closer to 25 degree try turning the temperature up slightly.
  • If you find the temperature varies a lot from the top shelf to the bottom(where it is coldest) try putting produce or other sensitive product on a higher shelf
  • If the temperature is too low and you cant make it warmer by adjusting the thermostats, you probably have a defective thermostat. If so you need to replace it because they cannot be repaired. Other possible problems are a leak in the seal(refrigerant) system, cold air migration(in side by side models) or a defective air damper.
Thanks
Jun 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
Apr 04, 2010 | Hotpoint HSS25GFP Side by Side...
Ice maker works but water dispenser stopped working
There sould be a set of water control valves on rear of refrigerator and where the water comes into refrigerator dispenser and ice maker. When one goes bad you replace both. You can test the windings in each coil or test for voltage while someone presses dispense water.I will ty to locate one set with your model number. Sea Breeze
Mar 20, 2010 | Refrigerators
Side by Side refrig. ice maker has water in tray but does not dispense ice.
Check to see if the coils under refridge are clean . If they are , replace the icemaker . An icemaker has to be 5 degrees to dump the cubes . Dirty coils can raise the temperature to 6 or even higher , therfore the icemaker will make ice , but not dump them .
Aug 26, 2009 | Whirlpool Refrigerators
Whirlpool side by side (106.56692501). Refrig was not cooling but freezer is. Freezer is slowly heating up though. Unit is still running. It just isn't blowing air into the refrigerator.
You have ice in freezer fins. You need to remove back panel inside of freezer, melt all the ice replace panel, plug refridge back in. The ice causes bad airflow to the refridge side, causing to heat up.
Jul 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not working,water pours from dispenser side
it could be water valve or ice maker that has gone bad.check all connectins to icemaker and tubing to icemaker and water valve.
Mar 20, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Ice maker not working now refridge seals are hot, but still cooi
okay....i used to be an employee at Vinothque and these piece of **** units are always and I mean always running low on refrigerant, due to a slow leak in the system. You will have to get tech to come out and recharge the unit
Dec 29, 2008 | Refrigerators
Whirlpool gold ice maker problem
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker leaking a lot of water
could be your water valve is stuck open its located at back of refridg.
Dec 14, 2007 | Whirlpool ED5VHGXM Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
74 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
