How do I set the clock on British gas model up 2
Cannot change the day and date
5 Suggested Answers
SOURCE: Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Posted on Mar 08, 2009
SOURCE: Emerson Research SmartSet Clock Radio
I forund a solution at http://www.emersonelectronics.ca/emerson/en/product/view/14383
Posted on Apr 06, 2009
barblewis66
SOURCE: GE CD/clock model # 7-4901A
I LOST MY MANUAL AND I CAN/T SET TIME/DATE/AND OTHER FEATURES
Posted on Oct 28, 2009
SOURCE: alarm clock settings need changing, no instruction manual
In the top left corner there will be some bars showing that the hour anouncement is on. Simply press the minute button and these bars will go, leaving you in peace and quiet.
Posted on Mar 04, 2010
How to change clock on a kindle fire to british summer time
Step 1: Pull Down upper Status Bar - More +
Step 2: Select Date and Time
Step 3: Select Change Timezone
Step 4: Change to your preferred Timezone (British Summer Time is +1 GMT)
Mar 31, 2013 | Amazon Kindle Fire HD
Tip
How to set the time/date (you have to do them both together)
To set the time and date (you have to do them both together):
  • First press and hold the 'CLOCK' button until it beeps then let go.
  • You will then be required to select the year by scrolling up or down with the 'TIME SET' rocker switch on the right hand side.
  • Once you have the right time, press the 'ENTER' button, to the right of the rocker switch once.
  • You will then be required to select the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
  • You will need to repeat this to select the date (day).
  • You then use this same process to select the time, starting with the hour and then the minute.
  • After you have finished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
REMEMBER to press the 'ENTER' button after selecting each thing to move you on to the next thing to set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from British summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on British summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
on May 23, 2009 | Sony ICF-C273 Clock Radio
Tip
How to set the time and date (you have to do them both together)
  • You will then be required to select the the month. Do this by once again using the 'TIME SET' rocker switch and then pressing 'ENTER'.
  • After you have finnished selecting the minute, press the 'ENTER' button once and then the set time, with the day in the top left corner will be shown. You do not need to press anything else. Your clock is now set.
TIP; Beside the 'CLOCK' button there is a button which says 'D.S.T SUMMER T'. This is the button which automatically switches your clock from british summer time to winter time and back again. It means that you do not need to reset your clock every time. Make sure that it is in the right setting when you set the clock otherwise it could get confusing. You will know if it is on british summer time because a small sun with a clock face appears in the top right corner of the screen.
Good Luck x
How to set date
from the manual:
"4. to change the calendar, press and hold the date/7-5-2 button until the display shows the flashing year.
5. Press the Reverse and Forward buttons to set the current year. When you have selected the year, press the Enter Button, then use the Reverse and Forward Buttons to set the month/day.
6. After you have set the date, press the Enter button or wait for the display to beep twice and lock into place."
Hope this helps. My model is T307
Sep 15, 2011 | Timex T307ST Clock Radio
I'm tryng to set the date without changing the day and time. I've tried to just pull the pin out half way but its not working. How do I do this? My watch has three dials on the face - 1)date, 2) day and 3)...
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
Jul 04, 2010 | Bulova Watch
NO INSTRUCTIONS ON SETTING CLOCK
Good Luck x
Apr 11, 2009 | Sony ICF-C273 Clock Radio
How do you set the time
Good Luck x
Apr 04, 2009 | Sony ICF-C273 Clock Radio
Set time and date on bt synergy 3505
to set the time the instructions are on page 9 of the instruction manual in the getting started section.
in case you no longer have the manual....
1. press the tick/menu button twice.
2. press 0 and you hear 'to set the day and time press Star, to hear the day and time press Square.
3. press star. you hear 'please enter new day and time after the tone' enter the day (1=sun, 2=mon etc) enter the time using 24hr clock.
4. press the X/security button twice to exit.
hope this helps.
Sep 26, 2008 | British Telecom Synergy 2110 Cordless...
Bose wave 2 .
Hi - You can download the manual from the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 17, 2008 | Sony ICF-C273 Clock Radio
Need operating instruction
I dont know where to find an instructions booklet but I can help with setting the time/date:
Good Luck x
Mar 16, 2008 | Sony ICF-C273 Clock Radio
450 people viewed this question
 Grubhead
Grubhead
