Question about Canon PIXMA iP2000 InkJet Printer
Canon Pixma iP2000: yellow power light blinks-reset doesn't work
Hello:
My Canon Pixma iP2000 suddenly went weird. Power light blinks yellow 5 times then turns green.
And won't print.
Used reset shown at:
http://www.fixya.com/support/t950159-canon_pixma_ip2000_service_manual
No luck.
Reinstalled driver, USB cable, changed USB port. System settings OK (WinXP).
Any thoughts?
Tks,
pbenesh@cox.net
  • pbenesh Jan 26, 2009
    I found the answer to the problem. It was a poorly-seated ink cartridge.
    Pushed it down a bit and all's well.
    Canon says (below) the problem is the print head.
    Not so.
    Without comment, here is Canon's list of light codes for the Pixma iP2000:
    The POWER Lamp Flashes Orange
    An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
    Two flashes: Out of paper or paper feed error
    Reload the paper correctly and press the RESUME/CANCEL button.
    Three flashes: Paper jam
    If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
    See Paper Jams in the Auto Sheet Feeder, Front Sheet Feeder or Paper Output Slot
    See Paper Jams in the Inside of the Printer
    Four flashes: Ink tanks installed incorrectly
    Reinstall the ink tanks. Ensure that the tanks are firmly seated in the Print Head.
    Five flashes: No Print Head installed or Print Head is defective
    Install a Print Head. If the problem remains, contact a Canon service representative.
    Eight flashes: Waste ink absorber almost full
    Ink used for cleaning is absorbed in the waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
    Important
    If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, printing will no longer be possible.
  • philander Feb 14, 2009
    When I switch on the printer yellow light blinks and i receive a message that the printhead needs to be replaced, which I did. The other problem is that the machine does not run on the ribbon it remains on one place. Please help I need to print urgently.
    President:
  • 8,637 Answers
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Can't print as the Waste Ink Absorber is full for Canon Pixma IP2000
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
May 12, 2010 | Canon PIXMA iP2000 InkJet Printer
My yelow light appears saying waste ink absorber
Hi there try see if this will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 25, 2009 | Canon PIXMA iP2000 InkJet Printer
Exactly what does it cost to replace the waste ink absorber when it gets full? I love my Pixma IP2000 InkJet Printer. I have just purchased a new Canon Pixma IP2600 to replace my IP2000. But before I...
Hello there try see if this will work
Reset ip2000
1. Turn off printer
Oct 18, 2009 | Canon PIXMA iP2000 InkJet Printer
My Canon PIXMA iP2000 photo printer Waste Ink Absorber
Reset ip2000
1. Turn off printer
Oct 10, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma iP2000 wont print black ink?
Canon IP 2000 / reset
1. Turn off printer
Jun 02, 2009 | Canon PIXMA iP2000 InkJet Printer
My printer, the Canon, Pixma Ip2000 stopped printing. It was giving me the message "the waste ink absorber is full". I took it to the only canon dealer in the city, and he reccommended that I replace the...
Reset Printer Canon IP2000 / IP3000
By pelda
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
http://freeresetterprinter.wordpress.com/2008/09/05/reset-printer-canon-ip2000-ip3000/
Mar 26, 2009 | Canon PIXMA iP2000 InkJet Printer
I have a pixma ip2000 printer and the troubleshooting
Reset ip2000
1. Turn off printer
Mar 05, 2009 | Canon PIXMA iP2000 InkJet Printer
Waste ink tank full
You can try this
Reset ip2000
1. Turn off printer
Jan 21, 2009 | Canon PIXMA iP2000 InkJet Printer
Waste ink absorber tray is full, how do I change or fix it?
Ok try this
Reset ip2000
1. Turn off printer
Jan 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
My canon ip2000 won't reset
Canon IP 2000 / reset Hi there you can try this.
1. Turn off printer
All the Best Pineworks
Apr 06, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA iP2000 InkJet Printer Logo
1,298 people viewed this question
old marine
old marine
