Question about Roper REX3614KW Electric Dryer
Cant get blower wheel off
Need to replace motor
  • 76 Answers
Ok, you have to be careful here if you don't want to but another blower wheel.....the threads on the motor to the blower wheel are in reverse...take a pair of vise grips and put them on the part of the blower wheel thats attched to the motor...looking at the motor the vise rips should be going to the right, let them rest against the base of the dryer, now take channel lockes, or what i use is a pipe wrench and while the visegrips are tighted and resting on the dryer base, place the pipe wrench on the front of the motor(the six sided piece, and turn to the right, it takes some pressure, but it will come off
Posted on Jan 03, 2009
How do you remove the wheel off the blower motor on a 1991 GMC 1500
Is your cage held on with a spring clamp or a Nut? Is it rusted on? They will pull off but sometimes you need a little pent. oil and a hammer. Or you can return the motor and ask for one with a blower cage. Some cages are mounted on the shaft and are not removeable
Feb 16, 2013 | Cars & Trucks
Blowing fuses on blower motor 2006 e250 econoline
Both are possible.But it can be blower motor issue mostly.Its taking too load and that's blowing the fuse.How to Test and Replace Blower motor on car? How to Replace Blower Motor Wheel?
Also more help solutions recommended. Click the link below :---
Blower motor replacing for all vehicles?
----------Blower motor Resistor shorting problem?
--------This will help.Thanks.
Jan 25, 2012 | 2006 Ford E-250
Air is not coming out of vents like it should. Could I possibly need a new blower motor?
Hello, it is possible that either the blower motor is running slow due to a weak capacitor or the blower motors bearings are giving out. I would replace the capaitor first since it is less expensive and see if it helps, if not the motor will need to be replaced. Also, make sure the filter is clean, blower wheel is clean before replacing the capacitor. Sometimes dirt will cause the wheel to turn slower.
Aug 03, 2011 | Heating & Cooling
Need to replace ac blower motor
  • Disconnect the negative battery cable.
  • Disconnect the blower motor lead connector from the wiring harness connector.
  • Remove the blower motor cooling tube from the blower motor.
  • Remove the four retaining screws.
  • Turn the motor and the wheel assembly slightly to the right so that the bottom edge of the mounting plate follows the contour of the wheel well splash panel.
  • Lift up on the blower and remove it from the blower housing.
  • Installation the new blower motor by reversing the removal steps.
  • Connect the negative battery cable.
  • Dec 12, 2010 | 2005 Scion xB
    Need to replace heater blower motor. How do I get to it?
    Behind the glove box. Please see my tip at . These are generic instructions. If you get stuck, please get back to me.
    See instructions from below.
    With Air Conditioning
    See Figures 1, 2 and 3
    1. Disconnect the negative battery cable.
    2. Remove the glove compartment door and glove compartment.
    3. Disconnect the blower motor wires from the blower motor resistor.
    Fig. Fig. 1: Disconnect the blower motor wires from the blower motor resistor-1988 Escort
    1. Loosen the instrument panel at the lower right-hand side prior to removing the motor through the glove compartment opening.
    2. Remove the blower motor and mounting plate from the evaporator case.
    3. Rotate the motor until the mounting plate flat clears the edge of the glove compartment opening and remove the motor.
    4. Remove the hub clamp spring from the blower wheel hub. Then remove the blower wheel from the motor shaft.
    Fig. Fig. 2: Unbolt the mounting plate from the case
    Fig. Fig. 3: The motor can now be removed from the case
    To install:
    1. If removed, assemble the blower wheel to the motor shaft and install the hub clamp.
    2. Install the motor and blower wheel assembly.
    3. Secure the instrument panel at the lower right-hand side.
    4. Connect the blower motor wires at the blower motor resistor.
    5. Install the glove compartment door and the glove compartment.
    6. Connect the negative battery cable.
    7. Check the system for proper operation.
    Without Air Conditioning
    2. Remove the air inlet duct assembly.
    3. Remove the hub clamp spring from the blower wheel hub. Pull the blower wheel from the blower motor shaft.
    4. Remove the blower motor flange attaching screws located inside the blower housing.
    5. Pull the blower motor out from the blower housing (heater case) and disconnect the blower motor wires from the motor.
    To install:
    1. Connect the wires to the blower motor and position the motor in the blower housing.
    2. Install the blower motor attaching screws.
    3. Position the blower wheel on the motor shaft and install the hub clamp spring.
    4. Install the air inlet duct assembly and the right ventilator assembly.
    5. Connect negative battery cable.
    6. Check the system for proper operation.
    Nov 05, 2010 | 1989 Ford Escort
    How to replace a blower motor in a 1996 ford thunderbird lx
    1. Remove the glove compartment liner to gain access to the heater blower motor and blower motor wheel assembly mounting screws.
    1. Use a small screwdriver to remove clip retaining hydraulic damper strut.
    1. Remove four screws and remove the heater blower motor assembly and blower motor wheel assembly from the heater blower motor housing.
    1. Using a new seal, position the heater blower motor and blower motor wheel assembly to the heater blower motor housing with the flat side of the flange near the heater blower motor switch resistor (18591). Install the four retaining screws.
    1. Tape the heater blower motor power lead to the air inlet duct to keep the wire away from the blower outlet during installation.
    1. Install the heater blower motor and blower motor wheel assembly in the vehicle.
    1. Install the glove compartment liner.
    Oct 07, 2010 | 1996 Ford Thunderbird LX
    How do I replace the ac/heater blower moter?
    Hope this helps....please don't forget to rate...thank you:
    Removal & Installation
    1. Before servicing the vehicle, refer to the Precautions section.
    2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
    3. Disengage the wire harness connectors from the retainer.
    4. Disconnect the blower motor electrical connector.
    5. Remove the motor cooling hose.
    6. Remove the screws and remove the blower motor.
      Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
    7. Remove the wheel from the blower motor as follows:
      • Remove the push clip.
      • Remove the wheel from the blower motor.
    Blower motor cooling hose
    Blower motor mounting plate
    To install:
    1. Install or connect the following:
      • Wheel to the blower motor, if removed.
      • Blower motor and securely tighten the screws.
      • Motor cooling hose
      • Blower motor electrical connector
      • Wire harness retainers
    Sep 15, 2010 | 2005 Mercury Grand Marquis
    Replacing AC blower motor
    ITS CALLED SURGERY take picture as ya go and have a big bucket for screws. make sure you have your motor and capacitor tested first before you replace it unless you know its bad (hp,sf &rpm must match !!!! on new motor ) little guys are real expensive and are a three speed motor and must be hooked up right or you will burn it UP ! do this in the shade cuz it aint no fun in the hot sun(me Florida) the first thing i would do is oil the motor then have the capacitor checked , the motor may not need to be replaced just serviced ?.. hay now if'n i was any help write a review of thanks or just VOTE,, MOTORWIZJ ..FL
    May 28, 2010 | Dometic Rooftop RV Air Conditioner
    The blower wheel is loose ,how do i get it off
    the wheel is a real pain to take off. you actually need to break it off. whenever i change out a motor, i always order a blower wheel. Good luck :)
    Jul 14, 2009 | Kenmore 63012 Electric Dryer
    Need blower wheel replaCDED?
    If it was your blower wheel it would not make that noise first cheak and see if thewheel has play on the shaft if so then it will need to be replace second turn blower wheel by hand back and forht if there is a screaching sounds if is a dry bearing on the motor .If so if you can live with the sound it will not go right away if not remove motor and replace.If there is play on the wheel you will need clip pliers and normal pliers and remove both clip[ on shaft and clip on shaft revers after install new blower wheel good luck:)
    May 07, 2009 | Maytag PYE2300AY Electric Dryer
    Roper REX3614KW Electric Dryer Logo
    66 people viewed this question
    Top Roper Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Roper Dryer Expert? Answer questions, earn points and help others
